Cisco Nexus 3232C cabling worksheet
Contributors netapp-martyh
If you want to document the supported platforms, you must complete the blank cabling worksheet by using the completed sample cabling worksheet as a guide. Each switch can be configured as a single 100GbE, 40GbE port or 4 x 10GbE ports.
Sample cabling worksheet
The sample port definition on each pair of switches is as follows:
Cluster switch A Cluster switch B
Switch port
Node and port usage
Switch port
Node and port usage
1
4x10G/40G/100G node
1
4x10G/40G/100G node
2
4x10G/40G/100G node
2
4x10G/40G/100G node
3
4x10G/40G/100G node
3
4x10G/40G/100G node
4
4x10G/40G/100G node
4
4x10G/40G/100G node
5
4x10G/40G/100G node
5
4x10G/40G/100G node
6
4x10G/40G/100Gnode
6
4x10G/40G/100Gnode
7
4x10G/40G/100G node
7
4x10G/40G/100G node
8
4x10G/40G/100G node
8
4x10G/40G/100G node
9
4x10G/40G/100G node
9
4x10G/40G/100G node
10
4x10G/40G/100G node
10
4x10G/40G/100G node
11
4x10G/40G/100G node
11
4x10G/40G/100G node
12
4x10G/40G/100G node
12
4x10G/40G/100G node
13
4x10G/40G/100G node
13
4x10G/40G/100G node
14
4x10G/40G/100G node
14
4x10G/40G/100G node
15
4x10G/40G/100G node
15
4x10G/40G/100G node
16
4x10G/40G/100G node
16
4x10G/40G/100G node
17
4x10G/40G/100G node
17
4x10G/40G/100G node
18
4x10G/40G/100G node
18
4x10G/40G/100G node
19
40G/100G node 19
19
40G/100G node 19
20
40G/100G node 20
20
40G/100G node 20
21
40G/100G node 21
21
40G/100G node 21
22
40G/100G node 22
22
40G/100G node 22
23
40G/100G node 23
23
40G/100G node 23
24
40G/100G node 24
24
40G/100G node 24
25 through 30
Reserved
25 through 30
Reserved
31
100G ISL to switch B port 31
31
100G ISL to switch A port 31
32
100G ISL to switch B port 32
32
100G ISL to switch A port 32
Blank cabling worksheet
You can use the blank cabling worksheet to document the platforms that are supported as nodes in a cluster. The Supported Cluster Connections section of the Hardware Universe defines the cluster ports used by the platform.
Switch port
Node/port usage
Switch port
Node/port usage
1
1
2
2
3
3
4
4
5
5
6
6
7
7
8
8
9
9
10
10
11
11
12
12
13
13
14
14
15
15
16
16
17
17
18
18
19
19
20
20
21
21
22
22
23
23
24
24
25 through 30
Reserved
25 through 30
Reserved
31
31
32
32
