Cisco Nexus 5596UP and 5596T cabling worksheet
Contributors netapp-martyh
If you want to document the supported platforms, you must complete the blank cabling worksheet by using the completed sample cabling worksheet as a guide.
Sample cabling worksheet
Some platforms support more than one 10GbE cluster port connection per cluster interconnect switch. To support additional cluster connections, you can use ports 25 through 40, as well as ports 49 through 80 when expansion modules are installed.
The sample port definition on each pair of switches is as follows:
Cluster switch A Cluster switch B
Switch port
Node and port usage
Switch port
Node and port usage
1
Node port 1
1
Node port 1
2
Node port 2
2
Node port 2
3
Node port 3
3
Node port 3
4
Node port 4
4
Node port 4
5
Node port 5
5
Node port 5
6
Node port 6
6
Node port 6
7
Node port 7
7
Node port 7
8
Node port 8
8
Node port 8
9
Node port 9
9
Node port 9
10
Node port 10
10
Node port 10
11
Node port 11
11
Node port 11
12
Node port 12
12
Node port 12
13
Node port 13
13
Node port 13
14
Node port 14
14
Node port 14
15
Node port 15
15
Node port 15
16
Node port 16
16
Node port 16
17
Node port 17
17
Node port 17
18
Node port 18
18
Node port 18
19
Node port 19
19
Node port 19
20
Node port 20
20
Node port 20
21
Node port 21
21
Node port 21
22
Node port 22
22
Node port 22
23
Node port 23
23
Node port 23
24
Node port 24
24
Node port 24
25 through 40
Reserved
25 through 40
Reserved
41
ISL to switch B port 41
41
ISL to switch A port 41
42
ISL to switch B port 42
42
ISL to switch A port 42
43
ISL to switch B port 43
43
ISL to switch A port 43
44
ISL to switch B port 44
44
ISL to switch A port 44
45
ISL to switch B port 45
45
ISL to switch A port 45
46
ISL to switch B port 46
46
ISL to switch A port 46
47
ISL to switch B port 47
47
ISL to switch A port 47
48
ISL to switch B port 48
48
ISL to switch A port 48
Blank cabling worksheet
You can use the blank cabling worksheet to document the platforms that are supported as nodes in a cluster. The Supported Cluster Connections section of the Hardware Universe defines the cluster ports used by the platform.
Note Switch ports 1 through 24 function as 10 GbE ports. Switch ports 41 through 48 are reserved for Inter-Switch Links (ISLs).
Switch port
Node/port usage
Switch port
Node/port usage
1
1
2
2
3
3
4
4
5
5
6
6
7
7
8
8
9
9
10
10
11
11
12
12
13
13
14
14
15
15
16
16
17
17
18
18
19
19
20
20
21
21
22
22
23
23
24
24
25 through 40
Reserved
25 through 40
Reserved
41
41
42
42
43
43
44
44
45
45
46
46
47
47
48
48
