Cisco Nexus 9336C-FX2 cabling worksheet
Contributors netapp-martyh
If you want to document the supported platforms, you must complete the blank cabling worksheet by using the completed sample cabling worksheet as a guide.
Sample cabling worksheet
The sample port definition on each pair of switches is as follows:
Cluster switch A Cluster switch B
Switch port
Node and port usage
Switch port
Node and port usage
1
4x10GbE node 1
1
4x10GbE node 1
2
4x10GbE node 2
2
4x10GbE node 2
3
4x10GbE node 3
3
4x10GbE node 3
4
4x25GbE node 4
4
4x25GbE node 4
5
4x25GbE node 5
5
4x25GbE node 5
6
4x25GbE node 6
6
4x25GbE node 6
7
4x100GbE node 7
7
4x100GbE node 7
8
4x100GbE node 8
8
4x100GbE node 8
9
4x100GbE node 9
9
4x100GbE node 9
10
4x100GbE node 10
10
4x100GbE node 10
11
4x100GbE node 11
11
4x100GbE node 11
12
4x100GbE node 12
12
4x100GbE node 12
13
4x100GbE node 13
13
4x100GbE node 13
14
4x100GbE node 14
14
4x100GbE node 14
15
4x100GbE node 15
15
4x100GbE node 15
16
4x100GbE node 16
16
4x100GbE node 16
17
4x100GbE node 17
17
4x100GbE node 17
18
4x100GbE node 18
18
4x100GbE node 18
19
4x100GbE node 19
19
4x100GbE node 19
20
4x100GbE node 20
20
4x100GbE node 20
21
4x100GbE node 21
21
4x100GbE node 21
22
4x100GbE node 22
22
4x100GbE node 22
23
4x100GbE node 23
23
4x100GbE node 23
24
4x100GbE node 24
24
4x100GbE node 24
25 through 34
Reserved
25 through 34
Reserved
35
100G ISL to switch B port 35
35
100G ISL to switch A port 35
36
100G ISL to switch B port 36
36
100G ISL to switch A port 36
Blank cabling worksheet
You can use the blank cabling worksheet to document the platforms that are supported as nodes in a cluster. The Supported Cluster Connections section of the Hardware Universe defines the cluster ports used by the platform.
1
1
2
2
3
3
4
4
5
5
6
6
7
7
8
8
9
9
10
10
11
11
12
12
13
13
14
14
15
15
16
16
17
17
18
18
19
19
20
20
21
21
22
22
23
23
24
24
25 through 34
Reserved
25 through 34
Reserved
35
35
36
36
