Migrate from a switched configuration with direct-attached storage by adding two new shared switches
You must be aware of certain configuration information, port connections, and cabling requirements when you are replacing some older Cisco Nexus cluster switches with Cisco Nexus 9336C-FX2 shared switches.
The following switches are supported:
Nexus 9336C-FX2
Nexus 3232C
The switches use the following ports for connections to nodes:
Nexus 9336C-FX2:
Ports 1- 3: Breakout mode (4x10G) Intra-Cluster Ports, int e1/1/1-4, e1/2/1-4, e1/3/1-4
Ports 4- 6: Breakout mode (4x25G) Intra-Cluster/HA Ports, int e1/4/1-4, e1/5/1-4, e1/6/1-4
Ports 7-34: 40/100GbE Intra-Cluster/HA Ports, int e1/7-34
Nexus 3232C:
Ports 1-30: 10/40/100 GbE
The switches use the following Inter-Switch Link (ISL) ports:
Ports int e1/35-36: Nexus 9336C-FX2
Ports e1/31-32: Nexus 3232C
The Hardware Universe contains information about supported cabling for all cluster switches.
See Hardware Universe for more information.
You have configured some of the ports on Nexus 9336C-FX2 switches to run at 100 GbE.
You have planned, migrated, and documented 100 GbE connectivity from nodes to Nexus 9336C-FX2 switches.
The ONTAP and NX-OS versions supported in this procedure are on the Cisco Ethernet Switches page. See Cisco Ethernet switches.
You can migrate nondisruptively other Cisco cluster switches from an ONTAP cluster to Cisco Nexus 9336C-FX2 network switches.
The existing switch network must be properly set up and functioning.
All ports must be in the up state to ensure nondisruptive operations.
The Nexus 9336C-FX2 switches must be configured and operating under the proper version of NX-OS installed and reference configuration file (RCF) applied.
The existing network configuration must have the following:
A redundant and fully functional NetApp cluster using both older Cisco switches.
Management connectivity and console access to both the older Cisco switches and the new switches.
All cluster LIFs in the up state with the cluster LIFs are on their home ports.
ISL ports enabled and cabled between the other Cisco switches and between the new switches.
The examples in this procedure use the following switch and node nomenclature:
The existing Cisco Nexus 3232C cluster switches are c1 and c2.
The new Nexus 9336C-FX2 switches are sh1 and sh2.
The nodes are node1 and node2.
The cluster LIFs are node1_clus1 and node1_clus2 on node 1, and node2_clus1 and node2_clus2 on node 2 respectively.
Switch c2 is replaced by switch sh2 first and then switch c1 is replaced by switch sh1.
If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=x h
Where x is the duration of the maintenance window in hours.
Check the administrative and operational status of each cluster port.
Verify that all the cluster ports are up with a healthy status:
network port show –role cluster
cluster1::*> network port show -role cluster Node: node1 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Ope Status Status ------- --------- ---------------- ---- ---- ------------ -------- ------ e3a Cluster Cluster up 9000 auto/100000 healthy false e3b Cluster Cluster up 9000 auto/100000 healthy false Node: node2 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status ------- --------- ---------------- ---- ---- ----------- --------- ------ e3a Cluster Cluster up 9000 auto/100000 healthy false e3b Cluster Cluster up 9000 auto/100000 healthy false 4 entries were displayed. cluster1::*>
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ------- ----------- ---------- ----------------- ----------- ------- ---- Cluster node1_clus1 up/up 169.254.3.4/23 node1 e3a true node1_clus2 up/up 169.254.3.5/23 node1 e3b true node2_clus1 up/up 169.254.3.8/23 node2 e3a true node2_clus2 up/up 169.254.3.9/23 node2 e3b true 4 entries were displayed. cluster1::*>
cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true Switch Type Address Model ------------------------- ------------------ ---------------- ------ sh1 cluster-network 10.233.205.90 N9K-C9336C Serial Number: FOCXXXXXXGD Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP sh2 cluster-network 10.233.205.91 N9K-C9336C Serial Number: FOCXXXXXXGS Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP cluster1::*>
cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert false
c2# configure terminal Enter configuration commands, one per line. End with CNTL/Z. c2(config)# interface ethernet <int range> c2(config)#shutdown
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home --------- ----------- ---------- --------------- ------------ -------- ----- Cluster node1_clus1 up/up 169.254.3.4/23 node1 e3a true node1_clus2 up/up 169.254.3.5/23 node1 e3a false node2_clus1 up/up 169.254.3.8/23 node2 e3a true node2_clus2 up/up 169.254.3.9/23 node2 e3a false 4 entries were displayed. cluster1::*>
c1# configure terminal Enter configuration commands, one per line. End with CNTL/Z. c1(config)# interface ethernet <int range> c1(config)#shutdown
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home -------- -------------- ---------- --------------- --------- ------- ---- Cluster node1_clus1 up/up 169.254.3.4/23 node1 e3a true node1_clus2 up/up 169.254.3.5/23 node1 e3a false node2_clus1 up/up 169.254.3.8/23 node2 e3a true node2_clus2 up/up 169.254.3.9/23 node2 e3a false 4 entries were displayed. cluster1::*>
cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert True
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------- ------- node1 true true false node2 true true false 2 entries were displayed. cluster1::*>
