Install and maintain
Review cabling and configuration requirements for the Cisco Nexus 9336C-FX2 shared switch
Contributors netapp-yvonneo netapp-jsnyder
Review the cabling and configuration considerations for the Cisco Nexus 9336C-FX2 shared switch before deployment.
Support for NVIDIA CX6, CX6-DX, and CX7 Ethernet ports
If you are connecting a switch port to an ONTAP controller using NVIDIA ConnectX-6 (CX6), ConnectX-6 Dx (CX6-DX), or ConnectX-7 (CX7) NIC ports, you must hard-code the switch port speed.
(cs1)(config)# interface Ethernet1/19
For 100GbE speed:
(cs1)(config-if)# speed 100000
For 40GbE speed:
(cs1)(config-if)# speed 40000
(cs1)(config-if)# no negotiate auto
(cs1)(config-if)# exit
(cs1)(config)# exit
Save the changes:
(cs1)# copy running-config startup-config
25GbE FEC requirements
FAS2820 e0a/e0b ports
FAS2820 e0a and e0b ports require FEC configuration changes to link up with 9336C-FX2 and 9336C-FX2-T switch ports. For switch ports e0a and e0b, the fec setting is set to rs-cons16.
(cs1)(config)# interface Ethernet1/8-9
(cs1)(config-if-range)# fec rs-cons16
(cs1)(config-if-range)# exit
(cs1)(config)# exit
Save the changes:
On the 9336C-FX2 and 9336C-FX2-T switches, the Ternary Content Addressable Memory (TCAM) resources configured in the configuration utilized by the switch are exhausted.
Related information
