Review cabling and configuration guidelines for Cisco Nexus 9336C-FX2 storage switches
Review the cabling and configuration considerations for Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches before deployment.
Support for NVIDIA CX6, CX6-DX, and CX7 Ethernet ports
If you are connecting a switch port to an ONTAP controller using NVIDIA ConnectX-6 (CX6), ConnectX-6 Dx (CX6-DX), or ConnectX-7 (CX7) NIC ports, you must hard-code the switch port speed.
(s1)(config)# interface Ethernet1/19 For 100GbE speed: (s1)(config-if)# speed 100000 For 40GbE speed: (s1)(config-if)# speed 40000 (s1)(config-if)# no negotiate auto (s1)(config-if)# exit (s1)(config)# exit Save the changes: (s1)# copy running-config startup-config
Related information
Refer to the Hardware Universe for more information on switch ports.
Refer to What additional information do I need to install my equipment that is not in HWU? for more information about switch installation requirements.
