Install and maintain
Review components and part numbers for Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder
Identify the components and part numbers for Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches to support hardware installation and ongoing maintenance.
The following table lists the part number and description for the 9336C-FX2 and 9336C-FX2-T storage switches, fans, and power supplies:
Part number Description
X190200-CS-PE
Cluster Switch, N9336C 36Pt PTSX 10/25/40/100G
X190200-CS-PI
Cluster Switch, N9336C 36Pt PSIN 10/25/40/100G
X190212-CS-PE
Cluster Switch, N9336C 12Pt (9336C-FX2-T) PTSX 10/25/40/100G
X190212-CS-PI
Cluster Switch, N9336C 12Pt (9336C-FX2-T) PSIN 10/25/40/100G
SW-N9K-FX2-24P-UPG
SW, Cisco 9336CFX2 24-Port POD License
X190210-FE-PE
N9K-9336C, FTE, PTSX, 36PT 10/25/40/100GQSFP28
X190210-FE-PI
N9K-9336C, FTE, PSIN, 36PT 10/25/40/100GQSFP28
X190002
Accessory Kit X190001/X190003
X-NXA-PAC-1100W-PE2
N9K-9336C AC 1100W PSU - Port side exhaust airflow
X-NXA-PAC-1100W-PI2
N9K-9336C AC 1100W PSU - Port side Intake airflow
X-NXA-FAN-65CFM-PE
N9K-9336C 65CFM, Port side exhaust airflow
X-NXA-FAN-65CFM-PI
N9K-9336C 65CFM, Port side intake airflow
Cisco Smart licenses for 9336C-FX2-T ports only
In order to activate more than 12 ports on your Cisco Nexus 9336C-FX-T storage switch, you must purchase a Cisco Smart license. Cisco Smart licenses are managed through Cisco Smart accounts.
  1. Create a new Smart account, if required. Refer to Create a new Smart account for details.
  2. Request access to an existing Smart account. Refer to Request access to an existing Smart account for details.
Note Once you have purchased your Smart license, install the appropriate RCF to enable and configure all 36 available ports for use.
What's next
After you've confirmed your components and part numbers, you can review the required documentation.
