Install and maintain
Review configuration requirements for Cisco Nexus 9336C-FX2 and 9336C-FX2-T cluster switches
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder
Review the ONTAP and NX-OS version requirements and supported configurations for Cisco Nexus 9336C-FX2 and 9336C-FX2-T cluster switches before installation or upgrade.
ONTAP support
ONTAP 9.9.1 and later
From ONTAP 9.9.1, you can use Cisco Nexus 9336C-FX2 switches to combine storage and cluster functionality into a shared switch configuration.
If you want to build ONTAP clusters with more than two nodes, you need two supported network switches.
Note Ethernet switch health monitor does not support ONTAP 9.13.1P8 and earlier and 9.14.1P3 and earlier or NX-OS version 10.3(4a)(M).
ONTAP 9.10.1 and later
In addition, beginning with ONTAP 9.10.1, you can use Cisco Nexus 9336C-FX2-T switches to combine storage and cluster functionality into a shared switch configuration.
Configuration requirements
Make sure that:
  • You have the appropriate number and type of cables and cable connectors for your switches. Refer to the Hardware Universe.
  • Depending on the type of switch you are initially configuring, you need to connect to the switch console port with the included console cable.
Network requirements
You need the following network information for all switch configurations.
  • IP subnet for management network traffic
  • Host names and IP addresses for each of the storage system controllers and all applicable switches
  • Most storage system controllers are managed through the e0M interface by connecting to the Ethernet service port (wrench icon). On AFF A800 and AFF A700s systems, the e0M interface uses a dedicated Ethernet port.
  • Refer to the Hardware Universe for the latest information.
For more information about the initial configuration of your switch, refer to the following Cisco Nexus 9336C-FX2 Installation and Upgrade Guide.
What's next
After you've reviewed the configuration requirements, you can confirm your components and part numbers.
