Install and maintain
Install or upgrade the Reference Configuration File (RCF) overview
Contributors netapp-yvonneo
You install the Reference Configuration File (RCF) after setting up the Nexus 9336C-FX2 and 9336C-FX2-T switches for the first time. You upgrade your RCF version when you have an existing version of the RCF file installed on your switch.
Refer to the Knowledge Base article How to clear configuration on a Cisco interconnect switch while retaining remote connectivity for further information when installing or upgrading your RCF.
Available RCF configurations
The following table describes the RCFs available for different configurations. Choose the RCF applicable to your configuration. Refer to Cisco Ethernet Switches for more information.
For specific port and VLAN usage details, refer to the banner and important notes section in your RCF.
RCF configuration Description
2-Cluster-HA-Breakout
Supports two ONTAP clusters with at least eight nodes, including nodes that use shared Cluster+HA ports.
4-Cluster-HA-Breakout
Supports four ONTAP clusters with at least four nodes, including nodes that use shared Cluster+HA ports.
1-Cluster-HA
All ports are configured for 40/100GbE. Supports shared cluster/HA traffic on ports. Required for AFF A320, AFF A250, and FAS500f systems. Additionally, all ports can be used as dedicated cluster ports.
1-Cluster-HA-Breakout
Ports are configured for 4x10GbE breakout, 4x25GbE breakout (RCF 1.6+ on 100GbE switches), and 40/100GbE. Supports shared cluster/HA traffic on ports for nodes that use shared cluster/HA ports: AFF A320, AFF A250, and FAS500f systems. Additionally, all ports can be used as dedicated cluster ports.
Cluster-HA-Storage
Ports are configured for 40/100GbE for Cluster+HA, 4x10GbE breakout for Cluster and 4x25GbE breakout for Cluster+HA, and 100GbE for each Storage HA Pair.
Cluster
Two flavors of RCF with different allocations of 4x10GbE ports (breakout) and 40/100GbE ports. All FAS/AFF nodes are supported, except for AFF A320, AFF A250, and FAS500f systems.
Storage
All ports are configured for 100GbE NVMe storage connections.
Available RCFs
The following table lists the available RCFs for 9336C-FX2 and 9336C-FX2-T switches. Choose the applicable RCF version for your configuration. Refer to Cisco Ethernet Switches for more information.
RCF name
Cluster-HA-Breakout RCF 1.xx
Cluster-HA-Storage RCF 1.xx
Storage RCF 1.xx
MultiCluster-HA RCF 1.xx
Suggested documentation
  • Cisco Ethernet Switches (NSS)
    Consult the switch compatibility table for the supported ONTAP and RCF versions on the NetApp Support Site. Note that there can be command dependencies between the command syntax in the RCF and the syntax found in specific versions of NX-OS.
  • Cisco Nexus 9000 Series Switches
    Refer to the appropriate software and upgrade guides available on the Cisco website for complete documentation on the Cisco switch upgrade and downgrade procedures.
About the examples
The examples in this procedure use the following switch and node nomenclature:
  • The names of the two Cisco switches are cs1 and cs2.
  • The node names are cluster1-01, cluster1-02, cluster1-03, and cluster1-04.
  • The cluster LIF names are cluster1-01_clus1, cluster1-01_clus2, cluster1-02_clus1, cluster1-02_clus2, cluster1-03_clus1, cluster1-03_clus2, cluster1-04_clus1, and cluster1-04_clus2.
  • The cluster1::*> prompt indicates the name of the cluster.
The examples in this procedure use four nodes. These nodes use two 10GbE cluster interconnect ports e0a and e0b. Refer to the Hardware Universe to verify the correct cluster ports on your platforms.
Note The command outputs might vary depending on different releases of ONTAP.
For details of the available RCF configurations, refer to the Software install workflow.
Commands used
The procedure requires the use of both ONTAP commands and Cisco Nexus 9000 Series Switches commands; ONTAP commands are used unless otherwise indicated.
What's next?
After you've reviewed the install RCF or upgrade RCF procedure, you can install the RCF or upgrade your RCF as required.
