Migrate from a Cisco switch to a Cisco Nexus 9336C-FX2 cluster switch
You must be aware of certain configuration information, port connections and cabling requirements when you are replacing some older Cisco Nexus cluster switches with Cisco Nexus 9336C-FX2 cluster switches.
The following cluster switches are supported:
Nexus 9336C-FX2
Nexus 92300YC
Nexus 5596UP
Nexus 3232C
Nexus 3132Q-V
See the Hardware Universe for full details of supported ports and their configurations.
You have configured some of the ports on Nexus 9336C-FX2 switches to run at 10 GbE or 40 GbE.
You have planned, migrated, and documented 10 GbE and 40 GbE connectivity from nodes to Nexus 9336C-FX2 cluster switches.
The ONTAP and NX-OS versions supported in this procedure are on the Cisco Ethernet Switches page.
