How to migrate from a Cisco switch to a Cisco Nexus 9336C-FX2 cluster switch
You can migrate nondisruptively older Cisco cluster switches for an ONTAP cluster to Cisco Nexus 9336C-FX2 cluster network switches.
The existing cluster must be properly set up and functioning.
All cluster ports must be in the up state to ensure nondisruptive operations.
The Nexus 9336C-FX2 cluster switches must be configured and operating under the proper version of NX-OS installed and reference configuration file (RCF) applied.
The existing cluster network configuration must have the following:
A redundant and fully functional NetApp cluster using both older Cisco switches.
Management connectivity and console access to both the older Cisco switches and the new switches.
All cluster LIFs in the up state with the cluster LIfs are on their home ports.
ISL ports enabled and cabled between the older Cisco switches and between the new switches.
The examples in this procedure use the following switch and node nomenclature:
The existing Cisco Nexus 5596UP cluster switches are c1 and c2.
The new Nexus 9336C-FX2 cluster switches are cs1 and cs2.
The nodes are node1 and node2.
The cluster LIFs are node1_clus1 and node1_clus2 on node 1, and node2_clus1 and node2_clus2 on node 2 respectively.
Switch c2 is replaced by switch cs2 first and then switch c1 is replaced by switch cs1.
A temporary ISL is built on cs2 connecting c2 to cs2.
Cabling between the nodes and c2 are then disconnected from c2 and reconnected to cs2.
Cabling between the nodes and c1 are then disconnected from c1 and reconnected to cs1.
The temporary ISL between c2 and cs2 is then removed.
If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=xh
where x is the duration of the maintenance window in hours.
The AutoSupport message notifies technical support of this maintenance task so that automatic case creation is suppressed during the maintenance window. -
Change the privilege level to advanced, entering y when prompted to continue:
set -privilege advanced
The advanced prompt (*>) appears.
Verify that auto-revert is enabled on all cluster LIFs:
network interface show -vserver Cluster -fields auto-revert
cluster1::*> network interface show -vserver Cluster -fields auto-revert Logical Vserver Interface Auto-revert --------- ------------- ------------ Cluster node1_clus1 true node1_clus2 true node2_clus1 true node2_clus2 true 4 entries were displayed.
Determine the administrative or operational status for each cluster interface:
Each port should display up for
Link
and healthy forHealth Status
Display the network port attributes:
network port show -ipspace Cluster
cluster1::*> network port show -ipspace Cluster Node: node1 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false Node: node2 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false 4 entries were displayed.
Display information about the logical interfaces and their designated home nodes:
Each LIF should display up/up for
Status Admin/Oper
and true forIs Home
.cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ----------- ---------- ------------------ ------------- ------- ---- Cluster node1_clus1 up/up 169.254.209.69/16 node1 e0a true node1_clus2 up/up 169.254.49.125/16 node1 e0b true node2_clus1 up/up 169.254.47.194/16 node2 e0a true node2_clus2 up/up 169.254.19.183/16 node2 e0b true 4 entries were displayed.
The cluster ports on each node are connected to existing cluster switches in the following way (from the nodes' perspective) using the command:
network device-discovery show -protocol cdp
cluster1::*> network device-discovery show -protocol cdp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ---------------- ---------------- node1 /cdp e0a c1 0/1 N5K-C5596UP e0b c2 0/1 N5K-C5596UP node2 /cdp e0a c1 0/2 N5K-C5596UP e0b c2 0/2 N5K-C5596UP
The cluster ports and switches are connected in the following way (from the switches' perspective) using the command:
show cdp neighbors
c1# show cdp neighbors Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge S - Switch, H - Host, I - IGMP, r - Repeater, V - VoIP-Phone, D - Remotely-Managed-Device, s - Supports-STP-Dispute Device-ID Local Intrfce Hldtme Capability Platform Port ID node1 Eth1/1 124 H FAS2750 e0a node2 Eth1/2 124 H FAS2750 e0a c2 Eth1/41 179 S I s N5K-C5596UP Eth1/41 c2 Eth1/42 175 S I s N5K-C5596UP Eth1/42 c2 Eth1/43 179 S I s N5K-C5596UP Eth1/43 c2 Eth1/44 175 S I s N5K-C5596UP Eth1/44 c2 Eth1/45 179 S I s N5K-C5596UP Eth1/45 c2 Eth1/46 179 S I s N5K-C5596UP Eth1/46 c2 Eth1/47 175 S I s N5K-C5596UP Eth1/47 c2 Eth1/48 179 S I s N5K-C5596UP Eth1/48 Total entries displayed: 10 c2# show cdp neighbors Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge S - Switch, H - Host, I - IGMP, r - Repeater, V - VoIP-Phone, D - Remotely-Managed-Device, s - Supports-STP-Dispute Device-ID Local Intrfce Hldtme Capability Platform Port ID node1 Eth1/1 124 H FAS2750 e0b node2 Eth1/2 124 H FAS2750 e0b c1 Eth1/41 175 S I s N5K-C5596UP Eth1/41 c1 Eth1/42 175 S I s N5K-C5596UP Eth1/42 c1 Eth1/43 175 S I s N5K-C5596UP Eth1/43 c1 Eth1/44 175 S I s N5K-C5596UP Eth1/44 c1 Eth1/45 175 S I s N5K-C5596UP Eth1/45 c1 Eth1/46 175 S I s N5K-C5596UP Eth1/46 c1 Eth1/47 176 S I s N5K-C5596UP Eth1/47 c1 Eth1/48 176 S I s N5K-C5596UP Eth1/48
Ensure that the cluster network has full connectivity using the command:
cluster ping-cluster -node node-name
cluster1::*> cluster ping-cluster -node node2 Host is node2 Getting addresses from network interface table... Cluster node1_clus1 169.254.209.69 node1 e0a Cluster node1_clus2 169.254.49.125 node1 e0b Cluster node2_clus1 169.254.47.194 node2 e0a Cluster node2_clus2 169.254.19.183 node2 e0b Local = 169.254.47.194 169.254.19.183 Remote = 169.254.209.69 169.254.49.125 Cluster Vserver Id = 4294967293 Ping status: .... Basic connectivity succeeds on 4 path(s) Basic connectivity fails on 0 path(s) ................ Detected 9000 byte MTU on 4 path(s): Local 169.254.19.183 to Remote 169.254.209.69 Local 169.254.19.183 to Remote 169.254.49.125 Local 169.254.47.194 to Remote 169.254.209.69 Local 169.254.47.194 to Remote 169.254.49.125 Larger than PMTU communication succeeds on 4 path(s) RPC status: 2 paths up, 0 paths down (tcp check) 2 paths up, 0 paths down (udp check)
Configure a temporary ISL on cs1 on ports e1/33-34, between c1 and cs1.
The following example shows how the new ISL is configured on c1 and cs1:
cs2# configure Enter configuration commands, one per line. End with CNTL/Z. cs2(config)# interface e1/33-34 cs2(config-if-range)# description temporary ISL between Nexus 5596UP and Nexus 9336C cs2(config-if-range)# no lldp transmit cs2(config-if-range)# no lldp receive cs2(config-if-range)# switchport mode trunk cs2(config-if-range)# no spanning-tree bpduguard enable cs2(config-if-range)# channel-group 101 mode active cs2(config-if-range)# exit cs2(config)# interface port-channel 101 cs2(config-if)# switchport mode trunk cs2(config-if)# spanning-tree port type network cs2(config-if)# exit cs2(config)# exit
Remove ISL cables from ports e1/33-34 from c2 and connect the cables to ports e1/33-34 on cs2.
Verify that the ISL ports and port-channel are operational connecting c2 and cs2:
show port-channel summary
The following example shows the Cisco show port-channel summary command being used to verify the ISL ports are operational on c2 and cs2:
c2# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed b - BFD Session Wait S - Switched R - Routed U - Up (port-channel) p - Up in delay-lacp mode (member) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 1 Po1(SU) Eth LACP Eth1/41(P) Eth1/42(P) Eth1/43(P) Eth1/44(P) Eth1/45(P) Eth1/46(P) Eth1/47(P) Eth1/48(P) cs2# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed b - BFD Session Wait S - Switched R - Routed U - Up (port-channel) p - Up in delay-lacp mode (member) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 1 Po1(SU) Eth LACP Eth1/35(P) Eth1/36(P) 101 Po101(SU) Eth LACP Eth1/41(P) Eth1/42(P) Eth1/43(P) Eth1/44(P) Eth1/45(P) Eth1/46(P) Eth1/47(P) Eth1/48(P)
For node1, disconnect the cable from e1/1 on c2, and then connect the cable to e1/1 on cs2, using appropriate cabling supported by Nexus 9336C-FX2.
For node2, disconnect the cable from e1/2 on c2, and then connect the cable to e1/2 on cs2, using appropriate cabling supported by Nexus 9336C-FX2.
The cluster ports on each node are now connected to cluster switches in the following way, from the nodes' perspective:
cluster1::*> network device-discovery show -protocol cdp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ---------------- ---------------- node1 /cdp e0a c1 0/1 N5K-C5596UP e0b cs2 0/1 N9K-C9336C node2 /cdp e0a c1 0/2 N5K-C5596UP e0b cs2 0/2 N9K-C9336C
For node1, disconnect the cable from e1/1 on c1, and then connect the cable to e1/1 on cs1, using appropriate cabling supported by Nexus 9336C-FX2.
For node2, disconnect the cable from e1/2 on c1, and then connect the cable to e1/2 on cs1, using appropriate cabling supported by Nexus 9336C-FX2.
cluster1::*> network device-discovery show -protocol cdp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ---------------- ---------------- node1 /cdp e0a cs1 0/1 N9K-C9336C e0b cs2 0/1 N9K-C9336C node2 /cdp e0a cs1 0/2 N9K-C9336C e0b cs2 0/2 N9K-C9336C
Delete the temporary ISL between cs1 and c1.
cs1(config)# no interface port-channel 101 cs1(config)# interface e1/33-34 cs1(config-if-range)# lldp transmit cs1(config-if-range)# lldp receive cs1(config-if-range)# no switchport mode trunk cs1(config-if-range)# no channel-group cs1(config-if-range)# description 10GbE Node Port cs1(config-if-range)# spanning-tree bpduguard enable cs1(config-if-range)# exit cs1(config)# exit
Verify the final configuration of the cluster:
Link
.cluster1::*> network port show -ipspace Cluster Node: node1 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false Node: node2 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false 4 entries were displayed. cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- Cluster node1_clus1 up/up 169.254.209.69/16 node1 e0a true node1_clus2 up/up 169.254.49.125/16 node1 e0b true node2_clus1 up/up 169.254.47.194/16 node2 e0a true node2_clus2 up/up 169.254.19.183/16 node2 e0b true 4 entries were displayed. cluster1::*> network device-discovery show -protocol cdp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ---------------- ---------------- node2 /cdp e0a cs1 0/2 N9K-C9336C e0b cs2 0/2 N9K-C9336C node1 /cdp e0a cs1 0/1 N9K-C9336C e0b cs2 0/1 N9K-C9336C 4 entries were displayed.
Verify that both nodes each have one connection to each switch:
show cdp neighbors
The following example shows the appropriate results for both switches:
cs1# show cdp neighbors Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge S - Switch, H - Host, I - IGMP, r - Repeater, V - VoIP-Phone, D - Remotely-Managed-Device, s - Supports-STP-Dispute Device-ID Local Intrfce Hldtme Capability Platform Port ID node1 Eth1/1 124 H FAS2750 e0a node2 Eth1/2 124 H FAS2750 e0a cs2 Eth1/35 179 R S I s N9K-C9336C Eth1/35 cs2 Eth1/36 179 R S I s N9K-C9336C Eth1/36 cs2# show cdp neighbors Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge S - Switch, H - Host, I - IGMP, r - Repeater, V - VoIP-Phone, D - Remotely-Managed-Device, s - Supports-STP-Dispute Device-ID Local Intrfce Hldtme Capability Platform Port ID node1 Eth1/1 124 H FAS2750 e0b node2 Eth1/2 124 H FAS2750 e0b cs1 Eth1/35 179 R S I s N9K-C9336C Eth1/35 cs1 Eth1/36 179 R S I s N9K-C9336C Eth1/36 Total entries displayed: 4
Ensure that the cluster network has full connectivity:
cluster1::*> set -priv advanced Warning: These advanced commands are potentially dangerous; use them only when directed to do so by NetApp personnel. Do you want to continue? {y|n}: y cluster1::*> cluster ping-cluster -node node2 Host is node2 Getting addresses from network interface table... Cluster node1_clus1 169.254.209.69 node1 e0a Cluster node1_clus2 169.254.49.125 node1 e0b Cluster node2_clus1 169.254.47.194 node2 e0a Cluster node2_clus2 169.254.19.183 node2 e0b Local = 169.254.47.194 169.254.19.183 Remote = 169.254.209.69 169.254.49.125 Cluster Vserver Id = 4294967293 Ping status: .... Basic connectivity succeeds on 4 path(s) Basic connectivity fails on 0 path(s) ................ Detected 9000 byte MTU on 4 path(s): Local 169.254.19.183 to Remote 169.254.209.69 Local 169.254.19.183 to Remote 169.254.49.125 Local 169.254.47.194 to Remote 169.254.209.69 Local 169.254.47.194 to Remote 169.254.49.125 Larger than PMTU communication succeeds on 4 path(s) RPC status: 2 paths up, 0 paths down (tcp check) 2 paths up, 0 paths down (udp check) cluster1::*> set -privilege admin cluster1::*>
For ONTAP 9.8 and later, enable the Ethernet switch health monitor log collection feature for collecting switch-related log files, using the following two commands:
system switch ethernet log setup-password
andsystem switch ethernet log enable-collection
Enter:
cluster1::*> system switch ethernet log setup-password Enter the switch name: <return> The switch name entered is not recognized. Choose from the following list: cs1 cs2 cluster1::*> system switch ethernet log setup-password Enter the switch name: cs1 RSA key fingerprint is e5:8b:c6:dc:e2:18:18:09:36:63:d9:63:dd:03:d9:cc Do you want to continue? {y|n}::[n] y Enter the password: <enter switch password> Enter the password again: <enter switch password> cluster1::*> system switch ethernet log setup-password Enter the switch name: cs2 RSA key fingerprint is 57:49:86:a1:b9:80:6a:61:9a:86:8e:3c:e3:b7:1f:b1 Do you want to continue? {y|n}:: [n] y Enter the password: <enter switch password> Enter the password again: <enter switch password>
Followed by:
cluster1::*> system switch ethernet log enable-collection Do you want to enable cluster log collection for all nodes in the cluster? {y|n}: [n] y Enabling cluster switch log collection. cluster1::*>
If any of these commands return an error, contact NetApp support. -
For ONTAP releases 9.5P16, 9.6P12, and 9.7P10 and later patch releases, enable the Ethernet switch health monitor log collection feature for collecting switch-related log files, using the commands:
system cluster-switch log setup-password
andsystem cluster-switch log enable-collection
Enter:
cluster1::*> system cluster-switch log setup-password Enter the switch name: <return> The switch name entered is not recognized. Choose from the following list: cs1 cs2 cluster1::*> system cluster-switch log setup-password Enter the switch name: cs1 RSA key fingerprint is e5:8b:c6:dc:e2:18:18:09:36:63:d9:63:dd:03:d9:cc Do you want to continue? {y|n}::[n] y Enter the password: <enter switch password> Enter the password again: <enter switch password> cluster1::*> system cluster-switch log setup-password Enter the switch name: cs2 RSA key fingerprint is 57:49:86:a1:b9:80:6a:61:9a:86:8e:3c:e3:b7:1f:b1 Do you want to continue? {y|n}:: [n] y Enter the password: <enter switch password> Enter the password again: <enter switch password>
Followed by:
cluster1::*> system cluster-switch log enable-collection Do you want to enable cluster log collection for all nodes in the cluster? {y|n}: [n] y Enabling cluster switch log collection. cluster1::*>
If you suppressed automatic case creation, reenable it by invoking an AutoSupport message:
