Install the NX-OS software
You can use this procedure to install the NX-OS software on the Nexus 9336C-FX2 cluster switch.
Connect the cluster switch to the management network.
Use the ping command to verify connectivity to the server hosting the NX-OS software and the RCF.
This example verifies that the switch can reach the server at IP address 172.19.2.1:
cs2# ping 172.19.2.1 Pinging 172.19.2.1 with 0 bytes of data: Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
Copy the NX-OS software and EPLD images to the Nexus 9336C-FX2 switch.
cs2# copy sftp: bootflash: vrf management Enter source filename: /code/nxos.9.3.5.bin Enter hostname for the sftp server: 172.19.2.1 Enter username: user1 Outbound-ReKey for 172.19.2.1:22 Inbound-ReKey for 172.19.2.1:22 user1@172.19.2.1's password: sftp> progress Progress meter enabled sftp> get /code/nxos.9.3.5.bin /bootflash/nxos.9.3.5.bin /code/nxos.9.3.5.bin 100% 1261MB 9.3MB/s 02:15 sftp> exit Copy complete, now saving to disk (please wait)... Copy complete. cs2# copy sftp: bootflash: vrf management Enter source filename: /code/n9000-epld.9.3.5.img Enter hostname for the sftp server: 172.19.2.1 Enter username: user1 Outbound-ReKey for 172.19.2.1:22 Inbound-ReKey for 172.19.2.1:22 user1@172.19.2.1's password: sftp> progress Progress meter enabled sftp> get /code/n9000-epld.9.3.5.img /bootflash/n9000-epld.9.3.5.img /code/n9000-epld.9.3.5.img 100% 161MB 9.5MB/s 00:16 sftp> exit Copy complete, now saving to disk (please wait)... Copy complete.
Verify the running version of the NX-OS software:
cs2# show version Cisco Nexus Operating System (NX-OS) Software TAC support: http://www.cisco.com/tac Copyright (C) 2002-2020, Cisco and/or its affiliates. All rights reserved. The copyrights to certain works contained in this software are owned by other third parties and used and distributed under their own licenses, such as open source. This software is provided "as is," and unless otherwise stated, there is no warranty, express or implied, including but not limited to warranties of merchantability and fitness for a particular purpose. Certain components of this software are licensed under the GNU General Public License (GPL) version 2.0 or GNU General Public License (GPL) version 3.0 or the GNU Lesser General Public License (LGPL) Version 2.1 or Lesser General Public License (LGPL) Version 2.0. A copy of each such license is available at http://www.opensource.org/licenses/gpl-2.0.php and http://opensource.org/licenses/gpl-3.0.html and http://www.opensource.org/licenses/lgpl-2.1.php and http://www.gnu.org/licenses/old-licenses/library.txt. Software BIOS: version 08.38 NXOS: version 9.3(4) BIOS compile time: 05/29/2020 NXOS image file is: bootflash:///nxos.9.3.4.bin NXOS compile time: 4/28/2020 21:00:00 [04/29/2020 02:28:31] Hardware cisco Nexus9000 C9336C-FX2 Chassis Intel(R) Xeon(R) CPU E5-2403 v2 @ 1.80GHz with 8154432 kB of memory. Processor Board ID FOC20291J6K Device name: cs2 bootflash: 53298520 kB Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 42 second(s) Last reset at 157524 usecs after Mon Nov 2 18:32:06 2020 Reason: Reset Requested by CLI command reload System version: 9.3(4) Service: plugin Core Plugin, Ethernet Plugin Active Package(s): cs2#
Install the NX-OS image.
Installing the image file causes it to be loaded every time the switch is rebooted.
cs2# install all nxos bootflash:nxos.9.3.5.bin Installer will perform compatibility check first. Please wait. Installer is forced disruptive Verifying image bootflash:/nxos.9.3.5.bin for boot variable "nxos". [####################] 100% -- SUCCESS Verifying image type. [####################] 100% -- SUCCESS Preparing "nxos" version info using image bootflash:/nxos.9.3.5.bin. [####################] 100% -- SUCCESS Preparing "bios" version info using image bootflash:/nxos.9.3.5.bin. [####################] 100% -- SUCCESS Performing module support checks. [####################] 100% -- SUCCESS Notifying services about system upgrade. [####################] 100% -- SUCCESS Compatibility check is done: Module bootable Impact Install-type Reason ------ -------- --------------- ------------ ------ 1 yes disruptive reset default upgrade is not hitless Images will be upgraded according to following table: Module Image Running-Version(pri:alt New-Version Upg-Required ------- --------- ---------------------------------------- ------------------- ------------ 1 nxos 9.3(4) 9.3(5) yes 1 bios v08.37(01/28/2020):v08.23(09/23/2015) v08.38(05/29/2020) yes Switch will be reloaded for disruptive upgrade. Do you want to continue with the installation (y/n)? [n] y Install is in progress, please wait. Performing runtime checks. [####################] 100% -- SUCCESS Setting boot variables. [####################] 100% -- SUCCESS Performing configuration copy. [####################] 100% -- SUCCESS Module 1: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. [####################] 100% -- SUCCESS Finishing the upgrade, switch will reboot in 10 seconds.
Verify the new version of NX-OS software after the switch has rebooted:
show version
cs2# show version Cisco Nexus Operating System (NX-OS) Software TAC support: http://www.cisco.com/tac Copyright (C) 2002-2020, Cisco and/or its affiliates. All rights reserved. The copyrights to certain works contained in this software are owned by other third parties and used and distributed under their own licenses, such as open source. This software is provided "as is," and unless otherwise stated, there is no warranty, express or implied, including but not limited to warranties of merchantability and fitness for a particular purpose. Certain components of this software are licensed under the GNU General Public License (GPL) version 2.0 or GNU General Public License (GPL) version 3.0 or the GNU Lesser General Public License (LGPL) Version 2.1 or Lesser General Public License (LGPL) Version 2.0. A copy of each such license is available at http://www.opensource.org/licenses/gpl-2.0.php and http://opensource.org/licenses/gpl-3.0.html and http://www.opensource.org/licenses/lgpl-2.1.php and http://www.gnu.org/licenses/old-licenses/library.txt. Software BIOS: version 05.33 NXOS: version 9.3(5) BIOS compile time: 09/08/2018 NXOS image file is: bootflash:///nxos.9.3.5.bin NXOS compile time: 11/4/2018 21:00:00 [11/05/2018 06:11:06] Hardware cisco Nexus9000 C9336C-FX2 Chassis Intel(R) Xeon(R) CPU E5-2403 v2 @ 1.80GHz with 8154432 kB of memory. Processor Board ID FOC20291J6K Device name: cs2 bootflash: 53298520 kB Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 42 second(s) Last reset at 277524 usecs after Mon Nov 2 22:45:12 2020 Reason: Reset due to upgrade System version: 9.3(4) Service: plugin Core Plugin, Ethernet Plugin Active Package(s):
Upgrade the EPLD image and reboot the switch.
cs2# show version module 1 epld EPLD Device Version --------------------------------------- MI FPGA 0x7 IO FPGA 0x17 MI FPGA2 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2 cs2# install epld bootflash:n9000-epld.9.3.5.img module 1 Compatibility check: Module Type Upgradable Impact Reason ------ ------------------ ----------------- --------- ----- 1 SUP Yes disruptive Module Upgradable Retrieving EPLD versions.... Please wait. Images will be upgraded according to following table: Module Type EPLD Running-Version New-Version Upg-Required ------- ------ ----------------- ----------------- ------------ ------------ 1 SUP MI FPGA 0x07 0x07 No 1 SUP IO FPGA 0x17 0x19 Yes 1 SUP MI FPGA2 0x02 0x02 No The above modules require upgrade. The switch will be reloaded at the end of the upgrade Do you want to continue (y/n) ? [n] y Proceeding to upgrade Modules. Starting Module 1 EPLD Upgrade Module 1 : IO FPGA [Programming] : 100.00% ( 64 of 64 sectors) Module 1 EPLD upgrade is successful. Module Type Upgrade-Result -------- ----- -------------- 1 SUP Success EPLDs upgraded. Module 1 EPLD upgrade is successful.
After the switch reboot, log in again and verify that the new version of EPLD loaded successfully.
cs2# show version module 1 epld EPLD Device Version --------------------------------------- MI FPGA 0x7 IO FPGA 0x19 MI FPGA2 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2
