Install the Reference Configuration File (RCF)
You can install the RCF after setting up the Nexus 9336C-FX2 switch for the first time. You can also use this procedure to upgrade your RCF version.
The examples in this procedure use the following switch and node nomenclature:
The names of the two Cisco switches are cs1 and cs2.
The node names arecluster1-01, cluster1-02, cluster1-03, and cluster1-04.
The cluster LIF names are cluster1-01_clus1, cluster1-01_clus2, cluster1-02_clus1, cluster1-02_clus2 , cluster1-03_clus1, cluster1-03_clus2, cluster1-04_clus1, and cluster1-04_clus2.
The
cluster1::*>
prompt indicates the name of the cluster.
The procedure requires the use of both ONTAP commands and Cisco Nexus 9000 Series Switches commands; ONTAP commands are used unless otherwise indicated. |
Display the cluster ports on each node that are connected to the cluster switches:
network device-discovery show
cluster1::*> network device-discovery show Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ---------------- -------- cluster1-01/cdp e0a cs1 Ethernet1/7 N9K-C9336C e0d cs2 Ethernet1/7 N9K-C9336C cluster1-02/cdp e0a cs1 Ethernet1/8 N9K-C9336C e0d cs2 Ethernet1/8 N9K-C9336C cluster1-03/cdp e0a cs1 Ethernet1/1/1 N9K-C9336C e0b cs2 Ethernet1/1/1 N9K-C9336C cluster1-04/cdp e0a cs1 Ethernet1/1/2 N9K-C9336C e0b cs2 Ethernet1/1/2 N9K-C9336C cluster1::*>
Check the administrative and operational status of each cluster port.
Verify that all the cluster ports are up with a healthy status:
network port show –role cluster
cluster1::*> network port show -role cluster Node: cluster1-01 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false Node: cluster1-02 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false 8 entries were displayed. Node: cluster1-03 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false Node: cluster1-04 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false cluster1::*>
Verify that all the cluster interfaces (LIFs) are on the home port:
network interface show -role cluster
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ------------------ ---------- ----------------- ------------ ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0a true cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0d true cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0a true cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0d true cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0a true cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0b true cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0a true cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0b true 8 entries were displayed. cluster1::*>
Verify that the cluster displays information for both cluster switches:
system cluster-switch show -is-monitoring-enabled-operational true
cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true Switch Type Address Model --------------------------- ------------------ ---------------- ----- cs1 cluster-network 10.233.205.90 N9K-C9336C Serial Number: FOCXXXXXXGD Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP cs2 cluster-network 10.233.205.91 N9K-C9336C Serial Number: FOCXXXXXXGS Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP cluster1::*>
Disable auto-revert on the cluster LIFs.
cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert false
On cluster switch cs2, shut down the ports connected to the cluster ports of the nodes.
cs2(config)# interface eth1/1/1-2,eth1/7-8 cs2(config-if-range)# shutdown
Verify that the cluster ports have migrated to the ports hosted on cluster switch cs1. This might take a few seconds.
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ----------------- ---------- ------------------ ------------- ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0a true cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0a false cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0a true cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0a false cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0a true cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0a false cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0a true cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0a false 8 entries were displayed. cluster1::*>
Verify that the cluster is healthy:
cluster show
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------ ------- cluster1-01 true true false cluster1-02 true true false cluster1-03 true true true cluster1-04 true true false 4 entries were displayed. cluster1::*>
Clean the configuration on switch cs2 and perform a basic setup.
Clean the configuration. This step requires a console connection to the switch.
cs2# write erase Warning: This command will erase the startup-configuration. Do you wish to proceed anyway? (y/n) [n] y cs2# reload This command will reboot the system. (y/n)? [n] y cs2#
Perform a basic setup of the switch.
Copy the RCF to the bootflash of switch cs2 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP. For more information on Cisco commands, see the appropriate guide in the Cisco Nexus 9000 Series NX-OS Command Reference guides.
This example shows TFTP being used to copy an RCF to the bootflash on switch cs2:
cs2# copy tftp: bootflash: vrf management Enter source filename: Nexus_9336C_RCF_v1.6-Cluster-HA-Breakout.txt Enter hostname for the tftp server: 172.22.201.50 Trying to connect to tftp server......Connection to Server Established. TFTP get operation was successful Copy complete, now saving to disk (please wait)...
Apply the RCF previously downloaded to the bootflash.
This example shows the RCF file
being installed on switch cs2:cs2# copy Nexus_9336C_RCF_v1.6-Cluster-HA-Breakout.txt running-config echo-commands
Examine the banner output from the
show banner motd
command. You must read and follow these instructions to ensure the proper configuration and operation of the switch.cs2# show banner motd ****************************************************************************** * NetApp Reference Configuration File (RCF) * * Switch : Nexus N9K-C9336C-FX2 * Filename : Nexus_9336C_RCF_v1.6-Cluster-HA-Breakout.txt * Date : 10-23-2020 * Version : v1.6 * * Port Usage: * Ports 1- 3: Breakout mode (4x10G) Intra-Cluster Ports, int e1/1/1-4, e1/2/1-4 , e1/3/1-4 * Ports 4- 6: Breakout mode (4x25G) Intra-Cluster/HA Ports, int e1/4/1-4, e1/5/ 1-4, e1/6/1-4 * Ports 7-34: 40/100GbE Intra-Cluster/HA Ports, int e1/7-34 * Ports 35-36: Intra-Cluster ISL Ports, int e1/35-36 * * Dynamic breakout commands: * 10G: interface breakout module 1 port <range> map 10g-4x * 25G: interface breakout module 1 port <range> map 25g-4x * * Undo breakout commands and return interfaces to 40/100G configuration in confi g mode: * no interface breakout module 1 port <range> map 10g-4x * no interface breakout module 1 port <range> map 25g-4x * interface Ethernet <interfaces taken out of breakout mode> * inherit port-profile 40-100G * priority-flow-control mode auto * service-policy input HA * exit * ******************************************************************************
Verify that the RCF file is the correct newer version:
show running-config
When you check the output to verify you have the correct RCF, make sure that the following information is correct:
The RCF banner
The node and port settings
Customizations The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
After you verify the RCF versions and switch settings are correct, copy the running-config file to the startup-config file.
cs2# copy running-config startup-config \[\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\] 100% Copy complete
Reboot switch cs2. You can ignore the “cluster ports down” events reported on the nodes while the switch reboots.
Verify the health of cluster ports on the cluster.
Verify that e0d ports are up and healthy across all nodes in the cluster:
cluster1::*> network port show -role cluster Node: cluster1-01 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false Node: cluster1-02 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false Node: cluster1-03 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false Node: cluster1-04 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false 8 entries were displayed.
Verify the switch health from the cluster (this might not show switch cs2, since LIFs are not homed on e0d).
cluster1::*> network device-discovery show -protocol cdp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ----------------- -------- cluster1-01/cdp e0a cs1 Ethernet1/7 N9K-C9336C e0d cs2 Ethernet1/7 N9K-C9336C cluster01-2/cdp e0a cs1 Ethernet1/8 N9K-C9336C e0d cs2 Ethernet1/8 N9K-C9336C cluster01-3/cdp e0a cs1 Ethernet1/1/1 N9K-C9336C e0b cs2 Ethernet1/1/1 N9K-C9336C cluster1-04/cdp e0a cs1 Ethernet1/1/2 N9K-C9336C e0b cs2 Ethernet1/1/2 N9K-C9336C cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true Switch Type Address Model --------------------------- ------------------ ---------------- ----- cs1 cluster-network 10.233.205.90 NX9-C9336C Serial Number: FOCXXXXXXGD Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP cs2 cluster-network 10.233.205.91 NX9-C9336C Serial Number: FOCXXXXXXGS Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP 2 entries were displayed.
You might observe the following output on the cs1 switch console depending on the RCF version previously loaded on the switch:
2020 Nov 17 16:07:18 cs1 %$ VDC-1 %$ %STP-2-UNBLOCK_CONSIST_PORT: Unblocking port port-channel1 on VLAN0092. Port consistency restored. 2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_PEER: Blocking port-channel1 on VLAN0001. Inconsistent peer vlan. 2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_LOCAL: Blocking port-channel1 on VLAN0092. Inconsistent local vlan.
On cluster switch cs1, shut down the ports connected to the cluster ports of the nodes.
The following example uses the interface example output from step 1:
cs1(config)# interface eth1/1/1-2,eth1/7-8 cs1(config-if-range)# shutdown
Verify that the cluster LIFs have migrated to the ports hosted on switch cs2. This might take a few seconds.
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ------------------ ---------- ------------------ ------------------- ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0d false cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0d true cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0d false cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0d true cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0b false cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0b true cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0b false cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0b true 8 entries were displayed. cluster1::*>
cluster show
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- -------- ------------- ------- cluster1-01 true true false cluster1-02 true true false cluster1-03 true true true cluster1-04 true true false 4 entries were displayed. cluster1::*>
Repeat Steps 7 to 14 on switch cs1.
Enable auto-revert on the cluster LIFs.
cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert True
Reboot switch cs1.You do this to trigger the cluster LIFs to revert to their home ports. You can ignore the “cluster ports down” events reported on the nodes while the switch reboots.
cs1# reload This command will reboot the system. (y/n)? [n] y
Verify that the switch ports connected to the cluster ports are up.
cs1# show interface brief \| grep up . . Eth1/1/1 1 eth access up none 10G(D) -- Eth1/1/2 1 eth access up none 10G(D) -- Eth1/7 1 eth trunk up none 100G(D) -- Eth1/8 1 eth trunk up none 100G(D) -- . .
Verify that the ISL between cs1 and cs2 is functional:
show port-channel summary
cs1# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed b - BFD Session Wait S - Switched R - Routed U - Up (port-channel) p - Up in delay-lacp mode (member) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 1 Po1(SU) Eth LACP Eth1/35(P) Eth1/36(P) cs1#
Verify that the cluster LIFs have reverted to their home port:
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ------------------ ---------- ------------------ ------------------- ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0d true cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0d true cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0d true cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0d true cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0b true cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0b true cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0b true cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0b true 8 entries were displayed. cluster1::*>
cluster show
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------- ------- cluster1-01 true true false cluster1-02 true true false cluster1-03 true true true cluster1-04 true true false 4 entries were displayed. cluster1::*>
Ping the remote cluster interfaces to verify connectivity:
cluster ping-cluster -node local
cluster1::*> cluster ping-cluster -node local Host is cluster1-03 Getting addresses from network interface table... Cluster cluster1-03_clus1 169.254.1.3 cluster1-03 e0a Cluster cluster1-03_clus2 169.254.1.1 cluster1-03 e0b Cluster cluster1-04_clus1 169.254.1.6 cluster1-04 e0a Cluster cluster1-04_clus2 169.254.1.7 cluster1-04 e0b Cluster cluster1-01_clus1 169.254.3.4 cluster1-01 e0a Cluster cluster1-01_clus2 169.254.3.5 cluster1-01 e0d Cluster cluster1-02_clus1 169.254.3.8 cluster1-02 e0a Cluster cluster1-02_clus2 169.254.3.9 cluster1-02 e0d Local = 169.254.1.3 169.254.1.1 Remote = 169.254.1.6 169.254.1.7 169.254.3.4 169.254.3.5 169.254.3.8 169.254.3.9 Cluster Vserver Id = 4294967293 Ping status: ............ Basic connectivity succeeds on 12 path(s) Basic connectivity fails on 0 path(s) ................................................ Detected 9000 byte MTU on 12 path(s): Local 169.254.1.3 to Remote 169.254.1.6 Local 169.254.1.3 to Remote 169.254.1.7 Local 169.254.1.3 to Remote 169.254.3.4 Local 169.254.1.3 to Remote 169.254.3.5 Local 169.254.1.3 to Remote 169.254.3.8 Local 169.254.1.3 to Remote 169.254.3.9 Local 169.254.1.1 to Remote 169.254.1.6 Local 169.254.1.1 to Remote 169.254.1.7 Local 169.254.1.1 to Remote 169.254.3.4 Local 169.254.1.1 to Remote 169.254.3.5 Local 169.254.1.1 to Remote 169.254.3.8 Local 169.254.1.1 to Remote 169.254.3.9 Larger than PMTU communication succeeds on 12 path(s) RPC status: 6 paths up, 0 paths down (tcp check) 6 paths up, 0 paths down (udp check)
