Cisco Nexus 3232C cabling worksheet
If you want to document the supported platforms, you must complete the blank cabling worksheet by using the completed sample cabling worksheet as a guide. Each switch can be configured as a single 100GbE, 40GbE port or 4 x 10GbE ports.
Sample cabling worksheet
The sample port definition on each pair of switches is as follows:
Cluster switch A | Cluster switch B | ||
Switch port |
Node and port usage |
Switch port |
1 |
4x10G/40G/100G node |
1 |
2 |
2 |
3 |
3 |
4 |
4 |
5 |
5 |
6 |
4x10G/40G/100Gnode |
6 |
7 |
7 |
8 |
8 |
9 |
9 |
10 |
10 |
11 |
11 |
12 |
12 |
13 |
13 |
14 |
14 |
15 |
15 |
16 |
16 |
17 |
17 |
18 |
18 |
19 |
40G/100G node 19 |
19 |
40G/100G node 19 |
20 |
40G/100G node 20 |
20 |
40G/100G node 20 |
21 |
40G/100G node 21 |
21 |
40G/100G node 21 |
22 |
40G/100G node 22 |
22 |
40G/100G node 22 |
23 |
40G/100G node 23 |
23 |
40G/100G node 23 |
24 |
40G/100G node 24 |
24 |
40G/100G node 24 |
25 through 30 |
Reserved |
25 through 30 |
Reserved |
31 |
100G ISL to switch B port 31 |
31 |
100G ISL to switch A port 31 |
32 |
100G ISL to switch B port 32 |
32 |
100G ISL to switch A port 32 |
Blank cabling worksheet
You can use the blank cabling worksheet to document the platforms that are supported as nodes in a cluster. The Supported Cluster Connections section of the Hardware Universe defines the cluster ports used by the platform.
Switch port |
Node/port usage |
Switch port |
Node/port usage |
1 |
1 |
2 |
2 |
3 |
3 |
4 |
4 |
5 |
5 |
6 |
6 |
7 |
7 |
8 |
8 |
9 |
9 |
10 |
10 |
11 |
11 |
12 |
12 |
13 |
13 |
14 |
14 |
15 |
15 |
16 |
16 |
17 |
17 |
18 |
18 |
19 |
19 |
20 |
20 |
21 |
21 |
22 |
22 |
23 |
23 |
24 |
24 |
25 through 30 |
Reserved |
25 through 30 |
Reserved |
31 |
31 |
32 |
32 |
