Cisco Nexus 92300YC cabling worksheet
If you want to document the supported platforms, you must complete the blank cabling worksheet by using the completed sample cabling worksheet as a guide.
Sample cabling worksheet
The sample port definition on each pair of switches is as follows:
Cluster switch A | Cluster switch B | ||
Switch port |
Node and port usage |
Switch port |
1 |
10/25 GbE node |
1 |
10/25 GbE node |
2 |
10/25 GbE node |
2 |
10/25 GbE node |
3 |
10/25 GbE node |
3 |
10/25 GbE node |
4 |
10/25 GbE node |
4 |
10/25 GbE node |
5 |
10/25 GbE node |
5 |
10/25 GbE node |
6 |
10/25 GbE node |
6 |
10/25 GbE node |
7 |
10/25 GbE node |
7 |
10/25 GbE node |
8 |
10/25 GbE node |
8 |
10/25 GbE node |
9 |
10/25 GbE node |
9 |
10/25 GbE node |
10 |
10/25 GbE node |
10 |
10/25 GbE node |
11 |
10/25 GbE node |
11 |
10/25 GbE node |
12 |
10/25 GbE node |
12 |
10/25 GbE node |
13 |
10/25 GbE node |
13 |
10/25 GbE node |
14 |
10/25 GbE node |
14 |
10/25 GbE node |
15 |
10/25 GbE node |
15 |
10/25 GbE node |
16 |
10/25 GbE node |
16 |
10/25 GbE node |
17 |
10/25 GbE node |
17 |
10/25 GbE node |
18 |
10/25 GbE node |
18 |
10/25 GbE node |
19 |
10/25 GbE node |
19 |
10/25 GbE node |
20 |
10/25 GbE node |
20 |
10/25 GbE node |
21 |
10/25 GbE node |
21 |
10/25 GbE node |
22 |
10/25 GbE node |
22 |
10/25 GbE node |
23 |
10/25 GbE node |
23 |
10/25 GbE node |
24 |
10/25 GbE node |
24 |
10/25 GbE node |
25 |
10/25 GbE node |
25 |
10/25 GbE node |
26 |
10/25 GbE node |
26 |
10/25 GbE node |
27 |
10/25 GbE node |
27 |
10/25 GbE node |
28 |
10/25 GbE node |
28 |
10/25 GbE node |
29 |
10/25 GbE node |
29 |
10/25 GbE node |
30 |
10/25 GbE node |
30 |
10/25 GbE node |
31 |
10/25 GbE node |
31 |
10/25 GbE node |
32 |
10/25 GbE node |
32 |
10/25 GbE node |
33 |
10/25 GbE node |
33 |
10/25 GbE node |
34 |
10/25 GbE node |
34 |
10/25 GbE node |
35 |
10/25 GbE node |
35 |
10/25 GbE node |
36 |
10/25 GbE node |
36 |
10/25 GbE node |
37 |
10/25 GbE node |
37 |
10/25 GbE node |
38 |
10/25 GbE node |
38 |
10/25 GbE node |
39 |
10/25 GbE node |
39 |
10/25 GbE node |
40 |
10/25 GbE node |
40 |
10/25 GbE node |
41 |
10/25 GbE node |
41 |
10/25 GbE node |
42 |
10/25 GbE node |
42 |
10/25 GbE node |
43 |
10/25 GbE node |
43 |
10/25 GbE node |
44 |
10/25 GbE node |
44 |
10/25 GbE node |
45 |
10/25 GbE node |
45 |
10/25 GbE node |
46 |
10/25 GbE node |
46 |
10/25 GbE node |
47 |
10/25 GbE node |
47 |
10/25 GbE node |
48 |
10/25 GbE node |
48 |
10/25 GbE node |
49 |
40/100 GbE node |
49 |
40/100 GbE node |
50 |
40/100 GbE node |
50 |
40/100 GbE node |
51 |
40/100 GbE node |
51 |
40/100 GbE node |
52 |
40/100 GbE node |
52 |
40/100 GbE node |
53 |
40/100 GbE node |
53 |
40/100 GbE node |
54 |
40/100 GbE node |
54 |
40/100 GbE node |
55 |
40/100 GbE node |
55 |
40/100 GbE node |
56 |
40/100 GbE node |
56 |
40/100 GbE node |
57 |
40/100 GbE node |
57 |
40/100 GbE node |
58 |
40/100 GbE node |
58 |
40/100 GbE node |
59 |
40/100 GbE node |
59 |
40/100 GbE node |
60 |
40/100 GbE node |
60 |
40/100 GbE node |
61 |
40/100 GbE node |
61 |
40/100 GbE node |
62 |
40/100 GbE node |
62 |
40/100 GbE node |
63 |
40/100 GbE node |
63 |
40/100 GbE node |
64 |
40/100 GbE node |
64 |
40/100 GbE node |
65 |
100 GbE ISL to switch B port 65 |
65 |
100 GbE ISL to switch A port 65 |
66 |
100 GbE ISL to switch B port 66 |
66 |
Blank cabling worksheet
You can use the blank cabling worksheet to document the platforms that are supported as nodes in a cluster. The Supported Cluster Connections section of the Hardware Universe defines the cluster ports used by the platform.
Switch port |
Node/port usage |
Switch port |
Node/port usage |
1 |
1 |
2 |
2 |
3 |
3 |
4 |
4 |
5 |
5 |
6 |
6 |
7 |
7 |
8 |
8 |
9 |
9 |
10 |
10 |
11 |
11 |
12 |
12 |
13 |
13 |
14 |
14 |
15 |
15 |
16 |
16 |
17 |
17 |
18 |
18 |
19 |
19 |
20 |
20 |
21 |
21 |
22 |
22 |
23 |
23 |
24 |
24 |
25 |
25 |
26 |
26 |
27 |
27 |
28 |
28 |
29 |
29 |
30 |
30 |
31 |
31 |
32 |
32 |
33 |
33 |
34 |
34 |
35 |
35 |
36 |
36 |
37 |
37 |
38 |
38 |
39 |
39 |
40 |
40 |
41 |
41 |
42 |
42 |
43 |
43 |
44 |
44 |
45 |
45 |
46 |
46 |
47 |
47 |
48 |
48 |
49 |
49 |
50 |
50 |
51 |
51 |
52 |
52 |
53 |
53 |
54 |
54 |
55 |
55 |
56 |
56 |
57 |
57 |
58 |
58 |
59 |
59 |
60 |
60 |
61 |
61 |
62 |
62 |
63 |
63 |
64 |
64 |
65 |
65 |
66 |
66 |
ISL to switch A port 66 |
