Cisco Nexus 9336C-FX2 cabling worksheet
If you want to document the supported platforms, you must complete the blank cabling worksheet by using the completed sample cabling worksheet as a guide.
Sample cabling worksheet
The sample port definition on each pair of switches is as follows:
Cluster switch A | Cluster switch B | ||
Switch port |
Node and port usage |
Switch port |
1 |
4x10GbE node 1 |
1 |
4x10GbE node 1 |
2 |
4x10GbE node 2 |
2 |
4x10GbE node 2 |
3 |
4x10GbE node 3 |
3 |
4x10GbE node 3 |
4 |
4x25GbE node 4 |
4 |
4x25GbE node 4 |
5 |
4x25GbE node 5 |
5 |
4x25GbE node 5 |
6 |
4x25GbE node 6 |
6 |
4x25GbE node 6 |
7 |
4x100GbE node 7 |
7 |
4x100GbE node 7 |
8 |
4x100GbE node 8 |
8 |
4x100GbE node 8 |
9 |
4x100GbE node 9 |
9 |
4x100GbE node 9 |
10 |
4x100GbE node 10 |
10 |
4x100GbE node 10 |
11 |
4x100GbE node 11 |
11 |
4x100GbE node 11 |
12 |
4x100GbE node 12 |
12 |
4x100GbE node 12 |
13 |
4x100GbE node 13 |
13 |
4x100GbE node 13 |
14 |
4x100GbE node 14 |
14 |
4x100GbE node 14 |
15 |
4x100GbE node 15 |
15 |
4x100GbE node 15 |
16 |
4x100GbE node 16 |
16 |
4x100GbE node 16 |
17 |
4x100GbE node 17 |
17 |
4x100GbE node 17 |
18 |
4x100GbE node 18 |
18 |
4x100GbE node 18 |
19 |
4x100GbE node 19 |
19 |
4x100GbE node 19 |
20 |
4x100GbE node 20 |
20 |
4x100GbE node 20 |
21 |
4x100GbE node 21 |
21 |
4x100GbE node 21 |
22 |
4x100GbE node 22 |
22 |
4x100GbE node 22 |
23 |
4x100GbE node 23 |
23 |
4x100GbE node 23 |
24 |
4x100GbE node 24 |
24 |
4x100GbE node 24 |
25 through 34 |
Reserved |
25 through 34 |
Reserved |
35 |
100G ISL to switch B port 35 |
35 |
100G ISL to switch A port 35 |
36 |
100G ISL to switch B port 36 |
36 |
100G ISL to switch A port 36 |
Blank cabling worksheet
You can use the blank cabling worksheet to document the platforms that are supported as nodes in a cluster. The Supported Cluster Connections section of the Hardware Universe defines the cluster ports used by the platform.
1 |
1 |
2 |
2 |
3 |
3 |
4 |
4 |
5 |
5 |
6 |
6 |
7 |
7 |
8 |
8 |
9 |
9 |
10 |
10 |
11 |
11 |
12 |
12 |
13 |
13 |
14 |
14 |
15 |
15 |
16 |
16 |
17 |
17 |
18 |
18 |
19 |
19 |
20 |
20 |
21 |
21 |
22 |
22 |
23 |
23 |
24 |
24 |
25 through 34 |
Reserved |
25 through 34 |
Reserved |
35 |
35 |
36 |
36 |
