Migrate from a switched configuration with DAT storage by adding two new shared switches
Contributors netapp-martyh
You must be aware of certain configuration information, port connections, and cabling requirements when you are replacing some older Cisco Nexus cluster switches with Cisco Nexus 9336C-FX2 shared switches.
  • The following switches are supported:
    • Nexus 9336C-FX2
    • Nexus 3232C
  • The switches use the following ports for connections to nodes:
  • Nexus 9336C-FX2:
    • Ports 1- 3: Breakout mode (4x10G) Intra-Cluster Ports, int e1/1/1-4, e1/2/1-4, e1/3/1-4
    • Ports 4- 6: Breakout mode (4x25G) Intra-Cluster/HA Ports, int e1/4/1-4, e1/5/1-4, e1/6/1-4
    • Ports 7-34: 40/100GbE Intra-Cluster/HA Ports, int e1/7-34
  • Nexus 3232C:
    • Ports 1-30: 10/40/100 GbE
  • The switches use the following Inter-Switch Link (ISL) ports:
    • Ports int e1/35-36: Nexus 9336C-FX2
    • Ports e1/31-32: Nexus 3232C
  • The Hardware Universe contains information about supported cabling for all cluster switches.
    See Hardware Universe for more information.
  • You have configured some of the ports on Nexus 9336C-FX2 switches to run at 100 GbE.
  • You have planned, migrated, and documented 100 GbE connectivity from nodes to Nexus 9336C-FX2 switches.
  • The ONTAP and NX-OS versions supported in this procedure are on the Cisco Ethernet Switches page. See Cisco Ethernet switches.
  • You can migrate nondisruptively other Cisco cluster switches from an ONTAP cluster to Cisco Nexus 9336C-FX2 network switches.
Before you begin
  • The existing switch network must be properly set up and functioning.
  • All ports must be in the up state to ensure nondisruptive operations.
  • The Nexus 9336C-FX2 switches must be configured and operating under the proper version of NX-OS installed and reference configuration file (RCF) applied.
  • The existing network configuration must have the following:
    • A redundant and fully functional NetApp cluster using both older Cisco switches.
    • Management connectivity and console access to both the older Cisco switches and the new switches.
    • All cluster LIFs in the up state with the cluster LIFs are on their home ports.
    • ISL ports enabled and cabled between the other Cisco switches and between the new switches.
About this task
The examples in this procedure use the following switch and node nomenclature:
  • The existing Cisco Nexus 3232C cluster switches are c1 and c2.
  • The new Nexus 9336C-FX2 switches are sh1 and sh2.
  • The nodes are node1 and node2.
  • The cluster LIFs are node1_clus1 and node1_clus2 on node 1, and node2_clus1 and node2_clus2 on node 2 respectively.
  • Switch c2 is replaced by switch sh2 first and then switch c1 is replaced by switch sh1.
Steps
  1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
    system node autosupport invoke -node * -type all -message MAINT=x h
    Where x is the duration of the maintenance window in hours.
  2. Check the administrative and operational status of each cluster port.
  3. Verify that all the cluster ports are up with a healthy status:
    network port show –role cluster
cluster1::*> network port show -role cluster
Node: node1
        Ignore
                                             Speed(Mbps)  Health   Health
Port    IPspace   Broadcast Domain Link MTU  Admin/Ope    Status   Status
e3a     Cluster   Cluster          up   9000  auto/100000 healthy  false
e3b     Cluster   Cluster          up   9000  auto/100000 healthy  false
Node: node2
        Ignore
Port    IPspace   Broadcast Domain Link MTU  Admin/Oper  Status    Status
4 entries were displayed.
cluster1::*>
  1. Verify that all the cluster interfaces (LIFs) are on the home port:
    network interface show -role cluster
cluster1::*> network interface show -role cluster
         Logical     Status     Network           Current     Current Is
Vserver  Interface   Admin/Oper Address/Mask      Node        Port    Home
Cluster
        node1_clus1  up/up      169.254.3.4/23    node1       e3a     true
        node1_clus2  up/up      169.254.3.5/23    node1       e3b     true
        node2_clus1  up/up      169.254.3.8/23    node2       e3a     true
        node2_clus2  up/up      169.254.3.9/23    node2       e3b     true
cluster1::*>
  1. Verify that the cluster displays information for both cluster switches:
    system cluster-switch show -is-monitoring-enabled-operational true
cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true
Switch                    Type               Address          Model
sh1                       cluster-network    10.233.205.90    N9K-C9336C
     Serial Number: FOCXXXXXXGD
      Is Monitored: true
            Reason: None
  Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                    9.3(5)
    Version Source: CDP
sh2                       cluster-network    10.233.205.91    N9K-C9336C
     Serial Number: FOCXXXXXXGS
      Is Monitored: true
            Reason: None
                    9.3(5)
    Version Source: CDP
cluster1::*>
  1. Disable auto-revert on the cluster LIFs.
cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert false
  1. Shutdown the c2 switch:
c2# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
c2(config)# interface ethernet <int range>
c2(config)#shutdown
  1. Verify that the cluster LIFs have migrated to the ports hosted on cluster switch sh1:
    This might take a few seconds.
Cluster
          node1_clus2 up/up      169.254.3.5/23  node1        e3a      false
          node2_clus2 up/up      169.254.3.9/23  node2        e3a      false
cluster1::*>
  1. Replace switch c2 with the new switch sh2 and re-cable the new switch.
  2. Verify that the ports are back up on sh2. Note that the LIFs are still on switch c1.
  3. Shutdown the c1 switch:
c1# configure terminal
c1(config)# interface ethernet <int range>
c1(config)#shutdown
  1. Verify that the cluster LIFs have migrated to the ports hosted on cluster switch sh2. This might take a few seconds.
Cluster
cluster1::*>
  1. Replace switch c1 with the new switch sh1 and re-cable the new switch.
  2. Verify that the ports are back up on sh1. Note that the LIFs are still on switch c2.
  3. Enable auto-revert on the cluster LIFs:
cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert True
  1. Verify that the cluster is healthy:
    cluster show
cluster1::*> cluster show
Node                 Health  Eligibility   Epsilon
node1                true    true          false
node2                true    true          false
2 entries were displayed.
cluster1::*>
