Migrate from a switchless cluster with DAT storage by adding two new shared switches
You must be aware of certain configuration information, port connections, and cabling requirements when you migrate a two-node switchless cluster, non-disruptively, to a cluster with Cisco Nexus 9336C-FX2 cluster switches. The procedure you use depends on whether you have two dedicated cluster-network ports on each controller or a single cluster port on each controller. The process documented works for all nodes using optical or Twinax ports but is not supported on this switch if nodes are using onboard 10Gb BASE-T RJ45 ports for the cluster-network ports.
Most systems require two dedicated cluster-network ports on each controller. See Cisco Ethernet Switches for more information.
If you have an existing two-node switchless cluster environment, you can migrate to a two-node switched cluster environment using Cisco Nexus 9336C-FX2 switches to enable you to scale beyond two nodes in the cluster.
Two-node switchless configuration:
The two-node switchless configuration must be properly set up and functioning.
The nodes must be running ONTAP 9.8 and later.
All cluster ports must be in the up state.
All cluster logical interfaces (LIFs) must be in the up state and on their home ports.
Cisco Nexus 9336C-FX2 switch configuration:
Both switches must have management network connectivity.
There must be console access to the cluster switches.
Nexus 9336C-FX2 node-to-node switch and switch-to-switch connections must use Twinax or fiber cables.
The NetApp Hardware Universe contains more information about cabling.
Inter-Switch Link (ISL) cables must be connected to ports 1/35 and 1/36 on both 9336C-FX2 switches.
Initial customization of the 9336C-FX2 switches must be completed. So that the:
9336C-FX2 switches are running the latest version of software
Reference Configuration Files (RCFs) have been applied to the switches
Any site customization, such as SMTP, SNMP, and SSH must be configured on the new switches.
The examples in this procedure use the following cluster switch and node nomenclature:
The names of the 9336C-FX2 switches are cs1 and cs2.
The names of the cluster SVMs are node1 and node2.
The names of the LIFs are node1_clus1 and node1_clus2 on node 1, and node2_clus1 and node2_clus2 on node 2 respectively.
The cluster1::*> prompt indicates the name of the cluster.
The cluster ports used in this procedure are e3a and e3b, as per the AFF A400 controller. The Hardware Universe contains the latest information about the actual cluster ports for your platforms.
If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=xh
.where x is the duration of the maintenance window in hours.
The AutoSupport message notifies technical support of this maintenance task so that automatic case creation is suppressed during the maintenance window. |
Change the privilege level to advanced, entering y when prompted to continue:
set -privilege advanced
The advanced prompt (*>) appears.
Disable all node-facing ports (not ISL ports) on both the new cluster switches cs1 and cs2. You must not disable the ISL ports.
The following example shows that node-facing ports 1 through 34 are disabled on switch cs1:
cs1# config Enter configuration commands, one per line. End with CNTL/Z. cs1(config)# interface e/1-34 cs1(config-if-range)# shutdown
cs1# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed b - BFD Session Wait S - Switched R - Routed U - Up (port-channel) p - Up in delay-lacp mode (member) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 1 Po1(SU) Eth LACP Eth1/35(P) Eth1/36(P)
The following example shows that the ISL ports are up on switch cs2:
cs2# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed b - BFD Session Wait S - Switched R - Routed U - Up (port-channel) p - Up in delay-lacp mode (member) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 1 Po1(SU) Eth LACP Eth1/35(P) Eth1/36(P)
cs1# show cdp neighbors Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge S - Switch, H - Host, I - IGMP, r - Repeater, V - VoIP-Phone, D - Remotely-Managed-Device, s - Supports-STP-Dispute Device-ID Local Intrfce Hldtme Capability Platform Port ID cs2 Eth1/35 175 R S I s N9K-C9336C Eth1/35 cs2 Eth1/36 175 R S I s N9K-C9336C Eth1/36 Total entries displayed: 2
The following example lists the neighboring devices on switch cs2:
cs2# show cdp neighbors Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge S - Switch, H - Host, I - IGMP, r - Repeater, V - VoIP-Phone, D - Remotely-Managed-Device, s - Supports-STP-Dispute Device-ID Local Intrfce Hldtme Capability Platform Port ID cs1 Eth1/35 177 R S I s N9K-C9336C Eth1/35 cs1 ) Eth1/36 177 R S I s N9K-C9336C Eth1/36 Total entries displayed: 2
cluster1::*> network port show -ipspace Cluster Node: node1 Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ------------ --------- e3a Cluster Cluster up 9000 auto/100000 healthy e3b Cluster Cluster up 9000 auto/100000 healthy Node: node2 Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ------------ --------- e3a Cluster Cluster up 9000 auto/100000 healthy e3b Cluster Cluster up 9000 auto/100000 healthy 4 entries were displayed.
cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ----- Cluster node1_clus1 up/up 169.254.209.69/16 node1 e3a true node1_clus2 up/up 169.254.49.125/16 node1 e3b true node2_clus1 up/up 169.254.47.194/16 node2 e3a true node2_clus2 up/up 169.254.19.183/16 node2 e3b true 4 entries were displayed.
cluster1::*> network interface show -vserver Cluster -fields auto-revert Logical Vserver Interface Auto-revert --------- ------------- ------------ Cluster node1_clus1 true node1_clus2 true node2_clus1 true node2_clus2 true 4 entries were displayed.
Disconnect the cable from cluster port e3a on node1, and then connect e3a to port 1 on cluster switch cs1, using the appropriate cabling supported by the 9336C-FX2 switches.
Disconnect the cable from cluster port e3a on node2, and then connect e3a to port 2 on cluster switch cs1, using the appropriate cabling supported by the 9336C-FX2 switches.
Enable all node-facing ports on cluster switch cs1.
The following example shows that ports 1/1 through 1/34 are enabled on switch cs1:
cs1# config Enter configuration commands, one per line. End with CNTL/Z. cs1(config)# interface e1/1-34 cs1(config-if-range)# no shutdown
cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home --------- ------------ ---------- ------------------ ----------- ------- ---- Cluster node1_clus1 up/up 169.254.209.69/16 node1 e3a true node1_clus2 up/up 169.254.49.125/16 node1 e3b true node2_clus1 up/up 169.254.47.194/16 node2 e3a true node2_clus2 up/up 169.254.19.183/16 node2 e3b true 4 entries were displayed.
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------ ------------ node1 true true false node2 true true false 2 entries were displayed.
Disconnect the cable from cluster port e3b on node1, and then connect e3b to port 1 on cluster switch cs2, using the appropriate cabling supported by the 9336C-FX2 switches.
Disconnect the cable from cluster port e3b on node2, and then connect e3b to port 2 on cluster switch cs2, using the appropriate cabling supported by the 9336C-FX2 switches.
Enable all node-facing ports on cluster switch cs2.
The following example shows that ports 1/1 through 1/34 are enabled on switch cs2:
cs2# config Enter configuration commands, one per line. End with CNTL/Z. cs2(config)# interface e1/1-34 cs2(config-if-range)# no shutdown
cluster1::*> network port show -ipspace Cluster Node: node1 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ------------ -------- ------ e3a Cluster Cluster up 9000 auto/100000 healthy false e3b Cluster Cluster up 9000 auto/100000 healthy false Node: node2 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ------------ -------- ------ e3a Cluster Cluster up 9000 auto/100000 healthy false e3b Cluster Cluster up 9000 auto/100000 healthy false 4 entries were displayed.
This might take several minutes to complete. |
The following example shows that all LIFs are up on node1 and node2 and that Is Home
results are true:
cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home --------- ------------ ---------- ------------------ ---------- ------- ---- Cluster node1_clus1 up/up 169.254.209.69/16 node1 e3a true node1_clus2 up/up 169.254.49.125/16 node1 e3b true node2_clus1 up/up 169.254.47.194/16 node2 e3a true node2_clus2 up/up 169.254.19.183/16 node2 e3b true 4 entries were displayed.
cs1# show cdp neighbors Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge S - Switch, H - Host, I - IGMP, r - Repeater, V - VoIP-Phone, D - Remotely-Managed-Device, s - Supports-STP-Dispute Device-ID Local Intrfce Hldtme Capability Platform Port ID node1 Eth1/1 133 H AFFA400 e3a node2 Eth1/2 133 H AFFA400 e3a cs2 Eth1/35 175 R S I s N9K-C9336C Eth1/35 cs2 Eth1/36 175 R S I s N9K-C9336C Eth1/36 Total entries displayed: 4 cs2# show cdp neighbors Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge S - Switch, H - Host, I - IGMP, r - Repeater, V - VoIP-Phone, D - Remotely-Managed-Device, s - Supports-STP-Dispute Device-ID Local Intrfce Hldtme Capability Platform Port ID node1 Eth1/1 133 H AFFA400 e3b node2 Eth1/2 133 H AFFA400 e3b cs1 Eth1/35 175 R S I s N9K-C9336C Eth1/35 cs1 Eth1/36 175 R S I s N9K-C9336C Eth1/36 Total entries displayed: 4
cluster1::*> network device-discovery show -protocol cdp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ---------------- ---------------- node2 /cdp e3a cs1 0/2 N9K-C9336C e3b cs2 0/2 N9K-C9336C node1 /cdp e3a cs1 0/1 N9K-C9336C e3b cs2 0/1 N9K-C9336C 4 entries were displayed.
storage::*> system switch ethernet show Switch Type Address Model ------------------------- ---------------------- --------------- ---------- sh1 storage-network 172.17.227.5 C9336C Serial Number: FOC221206C2 Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP sh2 storage-network 172.17.227.6 C9336C Serial Number: FOC220443LZ Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP 2 entries were displayed. storage::*>
It might take several minutes for the command to complete. Wait for the '3-minute lifetime to expire' announcement. |
The false
output in the following example shows that the configuration settings are disabled:
cluster1::*> network options switchless-cluster show Enable Switchless Cluster: false
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------ -------- node1 true true false node2 true true false
cluster1::*> cluster ping-cluster -node node2 Host is node2 Getting addresses from network interface table... Cluster node1_clus1 169.254.209.69 node1 e3a Cluster node1_clus2 169.254.49.125 node1 e3b Cluster node2_clus1 169.254.47.194 node2 e3a Cluster node2_clus2 169.254.19.183 node2 e3b Local = 169.254.47.194 169.254.19.183 Remote = 169.254.209.69 169.254.49.125 Cluster Vserver Id = 4294967293 Ping status: ... Basic connectivity succeeds on 4 path(s) Basic connectivity fails on 0 path(s) ... Detected 9000 byte MTU on 4 path(s): Local 169.254.47.194 to Remote 169.254.209.69 Local 169.254.47.194 to Remote 169.254.49.125 Local 169.254.19.183 to Remote 169.254.209.69 Local 169.254.19.183 to Remote 169.254.49.125 Larger than PMTU communication succeeds on 4 path(s) RPC status: 2 paths up, 0 paths down (tcp check) 2 paths up, 0 paths down (udp check)
cluster1::*> system switch ethernet log setup-password Enter the switch name: <return> The switch name entered is not recognized. Choose from the following list: cs1 cs2 cluster1::*> system switch ethernet log setup-password Enter the switch name: cs1 RSA key fingerprint is e5:8b:c6:dc:e2:18:18:09:36:63:d9:63:dd:03:d9:cc Do you want to continue? {y|n}::[n] y Enter the password: <enter switch password> Enter the password again: <enter switch password> cluster1::*> system switch ethernet log setup-password Enter the switch name: cs2 RSA key fingerprint is 57:49:86:a1:b9:80:6a:61:9a:86:8e:3c:e3:b7:1f:b1 Do you want to continue? {y|n}:: [n] y Enter the password: <enter switch password> Enter the password again: <enter switch password> cluster1::*> system switch ethernet log enable-collection Do you want to enable cluster log collection for all nodes in the cluster? {y|n}: [n] y Enabling cluster switch log collection. cluster1::*>
Setup the shared switch
The examples in this procedure use the following switch and node nomenclature:
The names of the two shared switches are sh1 and sh2.
The nodes are node1 and node2.
The procedure requires the use of both ONTAP commands and Cisco Nexus 9000 Series Switches commands, ONTAP commands are used unless otherwise indicated. |
Verify that the storage configuration of HA pair 1 (and HA pair 2) is correct and error free:
storage::*> system switch ethernet show Switch Type Address Model ------------------------- --------------------- --------------- ------- sh1 storage-network 172.17.227.5 C9336C Serial Number: FOC221206C2 Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP sh2 storage-network 172.17.227.6 C9336C Serial Number: FOC220443LZ Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP 2 entries were displayed. storage::*>
storage::*> storage port show -port-type ENET Speed VLAN Node Port Type Mode (Gb/s) State Status ID ------- ------- ------- ---------- ----------- ---------- ---------- ----- node1 e0c ENET storage 100 enabled online 30 e0d ENET storage 100 enabled online 30 e5a ENET storage 100 enabled online 30 e5b ENET storage 100 enabled online 30 node2 e0c ENET storage 100 enabled online 30 e0d ENET storage 100 enabled online 30 e5a ENET storage 100 enabled online 30 e5b ENET storage 100 enabled online 30
Move the HA pair 1, NSM224 path A ports to sh1 port range 11-22.
Install a cable from HA pair 1, node1, path A to sh1 port range 11-22. For example, the path A storage port on an AFF A400 is e0c.
Install a cable from HA pair 1, node2, path A to sh1 port range 11-22.
Verify that the node ports are healthy and operational:
storage::*> storage port show -port-type ENET Speed VLAN Node Port Type Mode (Gb/s) State Status ID ------- ------- ------- ---------- ----------- ---------- ---------- ----- node1 e0c ENET storage 100 enabled online 30 e0d ENET storage 0 enabled offline 30 e5a ENET storage 0 enabled offline 30 e5b ENET storage 100 enabled online 30 node2 e0c ENET storage 100 enabled online 30 e0d ENET storage 0 enabled offline 30 e5a ENET storage 0 enabled offline 30 e5b ENET storage 100 enabled online 30
storage::*> system health alert show -instance There are no entries matching your query.
Move the HA pair 1, NSM224 path B ports to sh2 port range 11-22.
Install a cable from HA pair 1, node1, path B to sh2 port range 11-22. For example, the path B storage port on an AFF A400 is e5b.
Install a cable from HA pair 1, node2, path B to sh2 port range 11-22.
storage::*> system switch ethernet show Switch Type Address Model ------------------------- ---------------------- ---------------- ---------- sh1 storage-network 172.17.227.5 C9336C Serial Number: FOC221206C2 Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP sh2 storage-network 172.17.227.6 C9336C Serial Number: FOC220443LZ Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(5) Version Source: CDP 2 entries were displayed. storage::*>
storage port modify –node [node name] –port [port name] –mode network
To place storage ports into a broadcast domain:
network port broadcast-domain create
(to create a new domain, if needed) -
network port broadcast-domain add-ports
(to add ports to an existing domain)
