Install NX-OS on the Cisco Nexus 9364D-GX2A switch
Install NX-OS on Cisco Nexus 9364D-GX2A switches for new AFX 1K or AFX 2K system installations, switch replacements, or when resetting a switch to factory default settings.
The switch(es) must be powered on and you must have completed the Complete initial switch setup procedure.
If you are installing the NX-OS on switch(es) as part of a new AFX system installation or switch replacement, verify that the version of NX-OS on your switch(es) is the current NetApp-supported version.
If your switch(es) have the current NetApp-supported version, you do not need to install the NX-OS. You need to install the RCF. Start with the Install or upgrade the RCF overview.
If your switch(es) do not have the current NetApp-supported version, continue with this procedure to install the NX-OS.
If you are installing the NX-OS on a switch as part of a switch replacement or a switch reset to factory default settings, verify that your cluster is fully functional, meaning that there are no errors in the logs or similar issues.
If you are installing the NX-OS as part of a new AFX system installation, you can skip this requirement because the controllers in your AFX system are not powered on at this point in your AFX system installation and setup. |
The version of ONTAP running on your AFX system determines the supported versions of NX-OS for your switches.
For switches in an AFX 1K system, running any supported version of ONTAP, NX-OS 10.4.2 and later is supported.
For switches in an AFX 2K system, running ONTAP 9.19.1GA or later, NX-OS 10.6 and later is supported.
For the current list of supported NX-OS versions, see the NetApp Cisco Ethernet Switches page.
This procedure only requires the use of Cisco Nexus 9000 Series Switches commands.
The examples in this procedure refer to the first switch as cs1 and the second switch as cs2.
If you have installed switches as part of a new AFX 1K or AFX 2K system installation, this procedure has you install the NX-OS on the first switch (cs1) and then has you repeat the steps for the second switch (cs2).
The examples shown in this procedure are for AFX 1K systems with switches running RCF 10.0. If you have an AFX 2K system, the input and output can vary.
Step 1: Prepare to install the NX-OS
Prepare to install the NX-OS on the switch(es) by making sure you have access to a server with the supported NX-OS version, downloading the NX-OS, connecting to the management network for the file transfer, and then verifying connectivity to the server.
You must have access to an HTTP, FTP, or TFTP server. Access to one of these servers allows you to download a supported version of the NX-OS.
Download the correct version of NX-OS to the switch(es) from the Cisco software download page.
Connect the switch to the management network (for the file transfer).
Verify connectivity to the server hosting the NX-OS using the ping command.
ping <IP address>Show example
This example verifies that the switch can reach the server at IP address 172.19.2.1:
cs1# ping 172.19.2.1 Pinging 172.19.2.1 with 0 bytes of data: Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
Step 2: Install the NX-OS and EPLD image
You install and verify the NX-OS and EPLD image on the first switch (cs1), and then repeat these steps on the second switch (cs2) if you are installing the NX-OS as part of a new AFX system installation.
Install the NX-OS and EPLD image.
Choose the tab that applies to your situation:
Install 10.4(2)F
Install 10.6(3)F or a later version
You use the switch CLI to enter the commands for the following steps.
Copy NX-OS and EPLD images to the first switch.
You use this command two times: the first time is to copy the NX-OS version and the second time is to copy the EPLD version.
copy <protocol>: bootflash: vrf managementShow example
The example uses sftp.
cs1# copy sftp: bootflash: vrf management Enter source filename: /code/nxos.10.4.2.bin Enter hostname for the sftp server: 172.19.2.1 Enter username: root Outbound-ReKey for 172.19.2.1:22 Inbound-ReKey for 172.19.2.1:22 root@172.19.2.1's password: sftp> progress Progress meter enabled sftp> get /code/nxos.10.4.2.bin /bootflash/nxos.10.4.2.bin /code/nxos.10.4.2.bin 100% 1261MB 9.3MB/s 02:15 sftp> exit Copy complete, now saving to disk (please wait)... Copy complete. cs1# copy sftp: bootflash: vrf management Enter source filename: /code/n9000-epld.10.4.2.F.img Enter hostname for the sftp server: 172.19.2.1 Enter username: user1 Outbound-ReKey for 172.19.2.1:22 Inbound-ReKey for 172.19.2.1:22 user1@172.19.2.1's password: sftp> progress Progress meter enabled sftp> get /code/n9000-epld.10.4.2.F.img /bootflash/n9000-epld.10.4.2.F.img /code/n9000-epld.10.4.2.F.img 100% 161MB 9.5MB/s 00:16 sftp> exit Copy complete, now saving to disk (please wait)... Copy complete.
Verify the running version of NX-OS:
show versionShow example
cs1# show version Cisco Nexus Operating System (NX-OS) Software ... Software BIOS: version 01.14 NXOS: version 10.4(1) [Feature Release] Host NXOS: version 10.4(1) BIOS compile time: 11/25/2024 NXOS image file is: bootflash:///nxos64-cs.10.4.1.F.bin NXOS compile time: 11/30/2023 12:00:00 [12/14/2023 05:25:50] NXOS boot mode: LXC Hardware cisco Nexus9000 C9364D-GX2A Chassis Intel(R) Xeon(R) CPU D-1633N @ 2.50GHz with 32802156 kB of memory. Processor Board ID FLMXXXXXXXX Device name: cs2 bootflash: 115802886 kB Kernel uptime is 5 day(s), 2 hour(s), 13 minute(s), 21 second(s) Last reset at 3580 usecs after Thu Jun 5 15:55:08 2025 Reason: Reset Requested by CLI command reload System version: 10.4(1) Service: plugin Core Plugin, Ethernet Plugin Active Package(s): cs1#
Install the NX-OS image.
Installing the image file causes it to be loaded every time the switch reboots.
install all nxos bootflash:nxos.<version number>.binShow example
The example uses NX-OS version 10.4.2.
cs1# install all nxos bootflash:nxos.10.4.2.bin Installer will perform compatibility check first. Please wait. Installer is forced disruptive Verifying image bootflash:/nxos.10.4.2.bin for boot variable "nxos". [] 100% -- SUCCESS Verifying image type. [] 100% -- SUCCESS Preparing "nxos" version info using image bootflash:/nxos.10.4.2.bin. [] 100% -- SUCCESS Preparing "bios" version info using image bootflash:/nxos.10.4.2.bin. [] 100% -- SUCCESS Performing module support checks. [] 100% -- SUCCESS Notifying services about system upgrade. [] 100% -- SUCCESS Compatibility check is done: Module Bootable Impact Install-type Reason ------ -------- --------------- ------------ --------- 1 yes Disruptive Reset Default upgrade is not hitless Images will be upgraded according to following table: Module Image Running-Version(pri:alt) New-Version Upg-Required ------- --------- ---------------------------------------- ------------------- ------------ 1 nxos 10.4(1) 10.4(2) Yes 1 bios xx.xx.:xx.xx xxx No Switch will be reloaded for disruptive upgrade. Do you want to continue with the installation (y/n)? [n] y Install is in progress, please wait. Performing runtime checks. [] 100% -- SUCCESS Setting boot variables. [] 100% -- SUCCESS Performing configuration copy. [] 100% -- SUCCESS Module 1: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. [] 100% -- SUCCESS Finishing the upgrade, switch will reboot in 10 seconds.
Verify the new version of NX-OS after the switch reboots:
cs1# show version ... Software BIOS: version 01.14 NXOS: version 10.4(2) [Feature Release] Host NXOS: version 10.4(2) BIOS compile time: 11/25/2024 NXOS image file is: bootflash:///nxos64-cs.10.4.2.F.bin NXOS compile time: 11/30/2023 12:00:00 [12/14/2023 05:25:50] NXOS boot mode: LXC Hardware cisco Nexus9000 C9364D-GX2A Chassis Intel(R) Xeon(R) CPU D-1633N @ 2.50GHz with 32802156 kB of memory. Processor Board ID FLMXXXXXXXX Device name: cs1 bootflash: 115802886 kB Kernel uptime is 5 day(s), 2 hour(s), 13 minute(s), 21 second(s) Last reset at 3580 usecs after Thu Jun 5 15:55:08 2025 Reason: Reset Requested by CLI command reload System version: 10.4(2) Service: plugin Core Plugin, Ethernet Plugin Active Package(s): cs1#
Upgrade the EPLD image using the following commands:
show version module 1 epldinstall epld bootflash:n9000-epld.<version>.img module allAfter the last command is executed, the switch reboots.
Show example
The example uses EPLD version 10.4(2)F
cs1# show version module 1 epld EPLD Device Version --------------------------------------- MI FPGA 0x7 IO FPGA 0x17 MI FPGA2 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2 cs1# install epld bootflash:n9000-epld.10.4.2.F.img module all Compatibility check: Module Type Upgradable Impact Reason ------ ------------------ ----------------- --------- ----------- 1 SUP Yes disruptive Module Upgradable Retrieving EPLD versions.... Please wait. Images will be upgraded according to following table: Module Type EPLD Running-Version New-Version Upg-Required ------- ------ ----------------- ----------------- ------------ ------------ 1 SUP MI FPGA 0x07 0x07 No 1 SUP IO FPGA 0x17 0x19 Yes 1 SUP MI FPGA2 0x02 0x02 No The above modules require upgrade. The switch will be reloaded at the end of the upgrade Do you want to continue (y/n) ? [n] y Proceeding to upgrade Modules. Starting Module 1 EPLD Upgrade Module 1 : IO FPGA [Programming] : 100.00% ( 64 of 64 sectors) Module 1 EPLD upgrade is successful. Module Type Upgrade-Result -------- ----- -------------- 1 SUP Success EPLDs upgraded. Module 1 EPLD upgrade is successful. -
After the switch reboots, log in and verify that the new version of EPLD loaded successfully:
show version module 1 epldShow example
cs1# show version module 1 epld EPLD Device Version --------------------------------------- MI FPGA 0x7 IO FPGA 0x19 MI FPGA2 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2
Copy the combined NX-OS and EPLD image to the first switch:
copy <protocol>: bootflash: vrf managementExample
cs1# copy sftp: bootflash: vrf management Enter source filename: /code/nxos.10.6.3.F.bin Enter hostname for the sftp server: 172.19.2.1 Enter username: user1 Outbound-ReKey for 172.19.2.1:22 Inbound-ReKey for 172.19.2.1:22 user1@172.19.2.1's password: sftp> progress Progress meter enabled sftp> get /code/nxos.10.6.3.F.bin /bootflash/nxos.10.6.3.F.bin /code/nxos.10.6.3.F.bin 100% 1261MB 9.3MB/s 02:15 sftp> exit Copy complete, now saving to disk (please wait)... Copy complete.
Verify the running version of the NX-OS:
show versionExample
cs1# show version ... Software BIOS: version 08.38 NXOS: version 10.6.3(F) BIOS compile time: 05/29/2020 NXOS image file is: bootflash:///nxos.10.6.3.F.bin NXOS compile time: 4/28/2020 21:00:00 [04/29/2020 02:28:31] Hardware cisco Nexus9000 C9364D-GX2A Chassis Intel(R) Xeon(R) CPU E5-2403 v2 @ 1.80GHz with 8154432 kB of memory. Processor Board ID FOC20291J6K Device name: cs1 bootflash: 53298520 kB Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 42 second(s) Last reset at 157524 usecs after Mon Nov 2 18:32:06 2020 Reason: Reset Requested by CLI command reload System version: 9.3(4) Service: plugin Core Plugin, Ethernet Plugin Active Package(s): cs1#
Install the NX-OS and EPLD images.
The EPLD image is not automatically updated when you upgrade to NX-OS 10.6(3)F and later. After your upgrade completes and the switch reboots, you must run the same upgrade
install allcommand again.-
The second upgrade pass verifies, but skips the NX-OS upgrade; only the EPLD image is updated.
When you have already upgraded to NX-OS 10.6(3)F and later, both images are updated at the same time.
Installing the image file causes it to be loaded every time the switch is rebooted.
The following example shows an upgrade from NX-OS 10.4(2)F to 10.6(3)F. The first pass performs the NX-OS upgrade and the second pass performs the EPLD image upgrade.
install all nxos bootflash:nxos.<version number>.binExample
cs1# install all nxos bootflash:nxos.10.6.3.F.bin <---- 1st pass updates NX-OS only Installer will perform compatibility check first. Please wait. Installer is forced disruptive Verifying image bootflash:/nxos.10.6.3.F.bin for boot variable "nxos". [] 100% -- SUCCESS Verifying image type. [] 100% -- SUCCESS Preparing "nxos" version info using image bootflash:/nxos.10.6.3.F.bin. [] 100% -- SUCCESS Preparing "bios" version info using image bootflash:/nxos.10.6.3.F.bin. [] 100% -- SUCCESS Performing module support checks. [] 100% -- SUCCESS Notifying services about system upgrade. [] 100% -- SUCCESS Compatibility check is done: Module Bootable Impact Install-type Reason ------ -------- --------------- ------------ --------- 1 yes Disruptive Reset Default upgrade is not hitless Images will be upgraded according to following table: Module Image Running-Version(pri:alt) New-Version Upg-Required ------- --------- ---------------------------------------- -------------------- ------------ 1 nxos 10.4(2)(F) 10.6(3)(F) yes 1 bios v05.47(04/28/2022):v05.47(04/28/2022) v05.53(01/22/2025) yes Switch will be reloaded for disruptive upgrade. Do you want to continue with the installation (y/n)? [n] y Install is in progress, please wait. Performing runtime checks. [] 100% -- SUCCESS Setting boot variables. [] 100% -- SUCCESS Performing configuration copy. [] 100% -- SUCCESS Module 1: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. [] 100% -- SUCCESS [] 100% -- SUCCESS Finishing the upgrade, switch will reboot in 10 seconds. cs1# install all nxos bootflash:nxos.10.6.3.F.bin <---- 2nd pass updates EPLD image only Installer will perform compatibility check first. Please wait. Installer is forced disruptive Verifying image bootflash:/nxos.10.6.3.F.bin for boot variable "nxos". [] 100% -- SUCCESS Verifying EPLD/FPGA image //bootflash/nxos.10.6.3.F.bin. [] 100% -- SUCCESS Verifying image type. [] 100% -- SUCCESS Preparing "nxos" version info using image bootflash:/nxos.10.6.3.F.bin. [] 100% -- SUCCESS Preparing "bios" version info using image bootflash:/nxos.10.6.3.F.bin. [] 100% -- SUCCESS Performing module support checks. [] 100% -- SUCCESS Notifying services about system upgrade. [] 100% -- SUCCESS Compatibility check is done: Module bootable Impact Install-type Reason ------ -------- -------------- ------------ ------ 1 yes disruptive reset default upgrade is not hitless 27 yes disruptive none default upgrade is not hitless Images will be upgraded according to following table: Module Image Running-Version(pri:alt) New-Version Upg-Required -------- --------------------- ------------------------------------- ----------------- ------------ 27 nxos 10.4(2)(F) 10.6(3)(F) no 27 bios v05.53(01/22/2025):v05.47(04/28/2022) v05.53(01/22/2025) no FPGA microcode will be upgraded according to following table: Module Type EPLD Running-Version Flashed-Version* New-Version Upg-Required ------ ---- ----------------- --------------- ---------------- ----------- ------------ 27 SUP MI FPGA 0x5 0x5 0x5 No 27 SUP IO FPGA 0x17 0x17 0x18 Yes If Running-Version and Flashed-Version are different it implies that the system has not yet been reloaded for the new version to take effect. EPLD Upgrade may result in multiple modules going offline. Switch will be reloaded for disruptive upgrade. Do you want to continue with the installation (y/n)? [n] y Install is in progress, please wait. Setting boot variables. [] 100% -- SUCCESS Performing configuration copy. [] 100% -- SUCCESS Performing configuration copy. [] 100% -- SUCCESS Module 1: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. Module 1: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. [] 100% -- SUCCESS Module 27: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. Module 27: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. [] 100% -- SUCCESS EPLD/FPGA upgrade can take up to 4 mins. Performing EPLD/FPGA upgrade. [] 100% -- SUCCESS Install has been successful.
Verify the new version of NX-OS after the switch has rebooted:
show versionExample
cs1# show version ... Software BIOS: version 05.33 NXOS: version 10.6.3(f) BIOS compile time: 09/08/2018 NXOS image file is: bootflash:///nxos.10.6.3.F.bin NXOS compile time: 11/4/2018 21:00:00 [11/05/2018 06:11:06] Hardware cisco Nexus9000 C9364D-GX2A Chassis Intel(R) Xeon(R) CPU E5-2403 v2 @ 1.80GHz with 8154432 kB of memory. Processor Board ID FOC20291J6K Device name: cs1 bootflash: 53298520 kB Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 42 second(s) Last reset at 277524 usecs after Mon Nov 2 22:45:12 2020 Reason: Reset due to upgrade System version: 9.3(4) Service: plugin Core Plugin, Ethernet Plugin Active Package(s):
After the switch reboot, log in again and verify that the new version of EPLD loaded successfully:
show version module 1 epldExample
cs2# show version module 1 epld EPLD Device Version --------------------------------------- MI FPGA 0x7 IO FPGA 0x19 MI FPGA2 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2
If you are installing the NX-OS as part of a new AFX system installation, repeat these steps to install the NX-OS and EPLD images on switch cs2.
After you've installed the NX-OS on your switch(es), you install RCF starting with the Install or upgrade the RCF overview.
