Installation and setup workflow for Cisco 9364D-GX2A switches
The Cisco 9364D-GX2A switch is part of the Cisco Nexus 9000 platform. AFX systems switches allow you to build ONTAP clusters with more than two nodes.
Follow these workflow steps to install and setup your to Cisco 9364D-GX2A switches.
Review the port details for the Cisco 9364D-GX2A switch.
Review specific switch and controller documentation to set up your 9364D-GX2A switches and the ONTAP cluster.
Review the requirements for the Cisco Smart Call Home feature, used to monitor the hardware and software components on your network.
Install the switch hardware.
Configure the switch software.
Configure switch health monitoring.
