Install and maintain
Install the RCF
Contributors netapp-yvonneo
You install the RCF after setting up the Nexus 9364D-GX2A switch for the first time.
Before you begin
Verify the following installations and connections:
  • A console connection to the switch. The console connection is optional if you have remote access to the switch.
  • Switch cs1 and switch cs2 are powered up and the initial switch setup is complete (the Management IP address and SSH is setup).
  • The desired NX-OS version has been installed.
  • ISL connections between switches are connected.
  • ONTAP node cluster ports are not connected.
Step 1: Install the RCF on the switches
  1. Login to switch cs1 using SSH or by using a serial console.
  2. Copy the RCF to the bootflash of switch cs1 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP.
    For more information on Cisco commands, refer to the appropriate guide in the Cisco Nexus 9000 Series NX-OS Command Reference.
    Show example
    This example shows TFTP being used to copy an RCF to the bootflash on switch cs1:
    cs1# copy tftp: bootflash: vrf management
    Enter source filename: NX9364D-GX2A-RCF-v10.0-Shared.txt
    Enter hostname for the tftp server: 172.22.201.50
    Trying to connect to tftp server......Connection to Server Established.
    TFTP get operation was successful
    Copy complete, now saving to disk (please wait)...
  3. Apply the RCF previously downloaded to the bootflash.
    Show example
    This example shows the RCF file NX9364D-GX2A-RCF-v10.0-Shared.txt being installed on switch cs1:
    cs1# copy NX9364D-GX2A-RCF-v10.0-Shared.txt running-config echo-commands
  4. Examine the banner output from the show banner motd command. You must read and follow these instructions to ensure the proper configuration and operation of the switch.
    Show example
    cs1# show banner motd
    * NetApp Reference Configuration File (RCF)
    * Switch   : NX9364D-GX2A
    * Filename : NX9364D-GX2A-RCF-v10.0-Shared.txt
    * Date     : 05-09-2025
    * Version  : v10.0
    * Port Usage:
    * Ports  1-62: 100GbE Intra-Cluster/HA/Storage Ports, int e1/{1-62}/1-4
    * Ports 63-64: Intra-Cluster ISL Ports, int e1/63-64
    * IMPORTANT NOTES
    * Interface port-channel999 is reserved to identify the version of this file.
  5. Verify that the RCF file is the correct newer version:
    show running-config
    When you check the output to verify you have the correct RCF, make sure that the following information is correct:
    • The RCF banner
    • The node and port settings
    • Customizations
      The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
  6. Save basic configuration details to the write_erase.cfg file on the bootflash.
    Note
    Make sure to configure the following:
    • Username and password
    • Management IP address
    • Default gateway
    • Switch name
    cs1# show run | i "username admin password" > bootflash:write_erase.cfg
    cs1# show run | section "vrf context management" >> bootflash:write_erase.cfg
    cs1# show run | section "interface mgmt0" >> bootflash:write_erase.cfg
    cs1# show run | section "switchname" >> bootflash:write_erase.cfg
    cs1# echo "hardware access-list tcam region ing-racl 1024" >> bootflash:write_erase.cfg
    cs1# echo "hardware access-list tcam region egr-racl 1024" >> bootflash:write_erase.cfg
    cs1# echo "hardware access-list tcam region ing-l2-qos 1536" >> bootflash:write_erase.cfg
  7. Verify that the write_erase.cfg file is populated as expected:
    show file bootflash:write_erase.cfg
  8. Issue the write erase command to erase the current saved configuration:
    cs1# write erase
    Warning: This command will erase the startup-configuration.
    Do you wish to proceed anyway? (y/n) [n] y
  9. Copy the previously saved basic configuration into the startup configuration.
    cs1# copy bootflash:write_erase.cfg startup-config
  10. Reboot the switch:
    cs1# reload
    This command will reboot the system. (y/n)? [n] y
  11. Repeat steps 1 through 10 on switch cs2.
  12. Connect the ports of all nodes in the ONTAP cluster to switches cs1 and cs2.
Step 2: Verify the switch connections
  1. Verify that the switch ports connected to the cluster ports are up:
    show interface brief
    Show example
    cs1# show interface brief | grep up
    Eth1/9/3        1       eth  trunk  up      none                     100G(D) --
    Eth1/9/4        1       eth  trunk  up      none                     100G(D) --
    Eth1/15/1       1       eth  trunk  up      none                     100G(D) --
    Eth1/15/2       1       eth  trunk  up      none                     100G(D) --
    Eth1/15/3       1       eth  trunk  up      none                     100G(D) --
    Eth1/15/4       1       eth  trunk  up      none                     100G(D) --
    Eth1/16/1       1       eth  trunk  up      none                     100G(D) --
    Eth1/16/2       1       eth  trunk  up      none                     100G(D) --
    Eth1/16/3       1       eth  trunk  up      none                     100G(D) --
    Eth1/16/4       1       eth  trunk  up      none                     100G(D) --
    Eth1/17/1       1       eth  trunk  up      none                     100G(D) --
    Eth1/17/2       1       eth  trunk  up      none                     100G(D) --
    Eth1/17/3       1       eth  trunk  up      none                     100G(D) --
    Eth1/17/4       1       eth  trunk  up      none                     100G(D) --
  2. Verify that the cluster nodes are in their correct cluster VLANs using the following commands:
    show vlan brief
    show interface trunk
    Show example
    cs1# show vlan brief
    VLAN Name                             Status    Ports
    1    default                          active    Po1, Po999, Eth1/63, Eth1/64
                                                    Eth1/65, Eth1/66, Eth1/1/1
                                                    Eth1/1/2, Eth1/1/3, Eth1/1/4
                                                    Eth1/2/1, Eth1/2/2, Eth1/2/3
                                                    Eth1/2/4, Eth1/3/1, Eth1/3/2
                                                    Eth1/3/3, Eth1/3/4, Eth1/4/1
                                                    Eth1/4/2, Eth1/4/3, Eth1/4/4
                                                    Eth1/5/1, Eth1/5/2, Eth1/5/3
                                                    Eth1/5/4, Eth1/6/1, Eth1/6/2
                                                    Eth1/6/3, Eth1/6/4, Eth1/7/1
                                                    Eth1/7/2, Eth1/7/3, Eth1/7/4
                                                    Eth1/8/1, Eth1/8/2, Eth1/8/3
                                                    Eth1/8/4, Eth1/9/1, Eth1/9/2
                                                    Eth1/9/3, Eth1/9/4, Eth1/10/1
                                                    Eth1/10/2, Eth1/10/3, Eth1/10/4
                                                    Eth1/11/1, Eth1/11/2, Eth1/11/3
                                                    Eth1/11/4, Eth1/12/1, Eth1/12/2
                                                    Eth1/12/3, Eth1/12/4, Eth1/13/1
                                                    Eth1/13/2, Eth1/13/3, Eth1/13/4
                                                    Eth1/14/1, Eth1/14/2, Eth1/14/3
                                                    Eth1/14/4, Eth1/15/1, Eth1/15/2
                                                    Eth1/15/3, Eth1/15/4, Eth1/16/1
                                                    Eth1/16/2, Eth1/16/3, Eth1/16/4
                                                    Eth1/17/1, Eth1/17/2, Eth1/17/3
                                                    Eth1/17/4, Eth1/18/1, Eth1/18/2
                                                    Eth1/18/3, Eth1/18/4, Eth1/19/1
                                                    Eth1/19/2, Eth1/19/3, Eth1/19/4
                                                    Eth1/20/1, Eth1/20/2, Eth1/20/3
                                                    Eth1/20/4, Eth1/21/1, Eth1/21/2
                                                    Eth1/21/3, Eth1/21/4, Eth1/22/1
                                                    Eth1/22/2, Eth1/22/3, Eth1/22/4
                                                    Eth1/23/1, Eth1/23/2, Eth1/23/3
                                                    Eth1/23/4, Eth1/24/1, Eth1/24/2
                                                    Eth1/24/3, Eth1/24/4, Eth1/25/1
                                                    Eth1/25/2, Eth1/25/3, Eth1/25/4
                                                    Eth1/26/1, Eth1/26/2, Eth1/26/3
                                                    Eth1/26/4, Eth1/27/1, Eth1/27/2
                                                    Eth1/27/3, Eth1/27/4, Eth1/28/1
                                                    Eth1/28/2, Eth1/28/3, Eth1/28/4
                                                    Eth1/29/1, Eth1/29/2, Eth1/29/3
                                                    Eth1/29/4, Eth1/30/1, Eth1/30/2
                                                    Eth1/30/3, Eth1/30/4, Eth1/31/1
                                                    Eth1/31/2, Eth1/31/3, Eth1/31/4
                                                    Eth1/32/1, Eth1/32/2, Eth1/32/3
                                                    Eth1/32/4, Eth1/33/1, Eth1/33/2
                                                    Eth1/33/3, Eth1/33/4, Eth1/34/1
                                                    Eth1/34/2, Eth1/34/3, Eth1/34/4
                                                    Eth1/35/1, Eth1/35/2, Eth1/35/3
                                                    Eth1/35/4, Eth1/36/1, Eth1/36/2
                                                    Eth1/36/3, Eth1/36/4, Eth1/37/1
                                                    Eth1/37/2, Eth1/37/3, Eth1/37/4
                                                    Eth1/38/1, Eth1/38/2, Eth1/38/3
                                                    Eth1/38/4, Eth1/39/1, Eth1/39/2
                                                    Eth1/39/3, Eth1/39/4, Eth1/40/1
                                                    Eth1/40/2, Eth1/40/3, Eth1/40/4
                                                    Eth1/41/1, Eth1/41/2, Eth1/41/3
                                                    Eth1/41/4, Eth1/42/1, Eth1/42/2
                                                    Eth1/42/3, Eth1/42/4, Eth1/43/1
                                                    Eth1/43/2, Eth1/43/3, Eth1/43/4
                                                    Eth1/44/1, Eth1/44/2, Eth1/44/3
                                                    Eth1/44/4, Eth1/45/1, Eth1/45/2
                                                    Eth1/45/3, Eth1/45/4, Eth1/46/1
                                                    Eth1/46/2, Eth1/46/3, Eth1/46/4
                                                    Eth1/47/1, Eth1/47/2, Eth1/47/3
                                                    Eth1/47/4, Eth1/48/1, Eth1/48/2
                                                    Eth1/48/3, Eth1/48/4, Eth1/49/1
                                                    Eth1/49/2, Eth1/49/3, Eth1/49/4
                                                    Eth1/50/1, Eth1/50/2, Eth1/50/3
                                                    Eth1/50/4, Eth1/51/1, Eth1/51/2
                                                    Eth1/51/3, Eth1/51/4, Eth1/52/1
                                                    Eth1/52/2, Eth1/52/3, Eth1/52/4
                                                    Eth1/53/1, Eth1/53/2, Eth1/53/3
                                                    Eth1/53/4, Eth1/54/1, Eth1/54/2
                                                    Eth1/54/3, Eth1/54/4, Eth1/55/1
                                                    Eth1/55/2, Eth1/55/3, Eth1/55/4
                                                    Eth1/56/1, Eth1/56/2, Eth1/56/3
                                                    Eth1/56/4, Eth1/57/1, Eth1/57/2
                                                    Eth1/57/3, Eth1/57/4, Eth1/58/1
                                                    Eth1/58/2, Eth1/58/3, Eth1/58/4
                                                    Eth1/59/1, Eth1/59/2, Eth1/59/3
                                                    Eth1/59/4, Eth1/60/1, Eth1/60/2
                                                    Eth1/60/3, Eth1/60/4, Eth1/61/1
                                                    Eth1/61/2, Eth1/61/3, Eth1/61/4
                                                    Eth1/62/1, Eth1/62/2, Eth1/62/3
                                                    Eth1/62/4
    17   VLAN0017                         active    Eth1/1/1, Eth1/1/2, Eth1/1/3
                                                    Eth1/1/4, Eth1/2/1, Eth1/2/2
                                                    Eth1/2/3, Eth1/2/4, Eth1/3/1
                                                    Eth1/3/2, Eth1/3/3, Eth1/3/4
                                                    Eth1/4/1, Eth1/4/2, Eth1/4/3
                                                    Eth1/4/4, Eth1/5/1, Eth1/5/2
                                                    Eth1/5/3, Eth1/5/4, Eth1/6/1
                                                    Eth1/6/2, Eth1/6/3, Eth1/6/4
                                                    Eth1/7/1, Eth1/7/2, Eth1/7/3
                                                    Eth1/7/4, Eth1/8/1, Eth1/8/2
                                                    Eth1/8/3, Eth1/8/4, Eth1/9/1
                                                    Eth1/9/2, Eth1/9/3, Eth1/9/4
                                                    Eth1/10/1, Eth1/10/2, Eth1/10/3
                                                    Eth1/10/4, Eth1/11/1, Eth1/11/2
                                                    Eth1/11/3, Eth1/11/4, Eth1/12/1
                                                    Eth1/12/2, Eth1/12/3, Eth1/12/4
                                                    Eth1/13/1, Eth1/13/2, Eth1/13/3
                                                    Eth1/13/4, Eth1/14/1, Eth1/14/2
                                                    Eth1/14/3, Eth1/14/4, Eth1/15/1
                                                    Eth1/15/2, Eth1/15/3, Eth1/15/4
                                                    Eth1/16/1, Eth1/16/2, Eth1/16/3
                                                    Eth1/16/4, Eth1/17/1, Eth1/17/2
                                                    Eth1/17/3, Eth1/17/4, Eth1/18/1
                                                    Eth1/18/2, Eth1/18/3, Eth1/18/4
                                                    Eth1/19/1, Eth1/19/2, Eth1/19/3
                                                    Eth1/19/4, Eth1/20/1, Eth1/20/2
                                                    Eth1/20/3, Eth1/20/4, Eth1/21/1
                                                    Eth1/21/2, Eth1/21/3, Eth1/21/4
                                                    Eth1/22/1, Eth1/22/2, Eth1/22/3
                                                    Eth1/22/4, Eth1/23/1, Eth1/23/2
                                                    Eth1/23/3, Eth1/23/4, Eth1/24/1
                                                    Eth1/24/2, Eth1/24/3, Eth1/24/4
                                                    Eth1/25/1, Eth1/25/2, Eth1/25/3
                                                    Eth1/25/4, Eth1/26/1, Eth1/26/2
                                                    Eth1/26/3, Eth1/26/4, Eth1/27/1
                                                    Eth1/27/2, Eth1/27/3, Eth1/27/4
                                                    Eth1/28/1, Eth1/28/2, Eth1/28/3
                                                    Eth1/28/4, Eth1/29/1, Eth1/29/2
                                                    Eth1/29/3, Eth1/29/4, Eth1/30/1
                                                    Eth1/30/2, Eth1/30/3, Eth1/30/4
                                                    Eth1/31/1, Eth1/31/2, Eth1/31/3
                                                    Eth1/31/4, Eth1/32/1, Eth1/32/2
                                                    Eth1/32/3, Eth1/32/4, Eth1/33/1
                                                    Eth1/33/2, Eth1/33/3, Eth1/33/4
                                                    Eth1/34/1, Eth1/34/2, Eth1/34/3
                                                    Eth1/34/4, Eth1/35/1, Eth1/35/2
                                                    Eth1/35/3, Eth1/35/4, Eth1/36/1
                                                    Eth1/36/2, Eth1/36/3, Eth1/36/4
                                                    Eth1/37/1, Eth1/37/2, Eth1/37/3
                                                    Eth1/37/4, Eth1/38/1, Eth1/38/2
                                                    Eth1/38/3, Eth1/38/4, Eth1/39/1
                                                    Eth1/39/2, Eth1/39/3, Eth1/39/4
                                                    Eth1/40/1, Eth1/40/2, Eth1/40/3
                                                    Eth1/40/4, Eth1/41/1, Eth1/41/2
                                                    Eth1/41/3, Eth1/41/4, Eth1/42/1
                                                    Eth1/42/2, Eth1/42/3, Eth1/42/4
                                                    Eth1/43/1, Eth1/43/2, Eth1/43/3
                                                    Eth1/43/4, Eth1/44/1, Eth1/44/2
                                                    Eth1/44/3, Eth1/44/4, Eth1/45/1
                                                    Eth1/45/2, Eth1/45/3, Eth1/45/4
                                                    Eth1/46/1, Eth1/46/2, Eth1/46/3
                                                    Eth1/46/4, Eth1/47/1, Eth1/47/2
                                                    Eth1/47/3, Eth1/47/4, Eth1/48/1
                                                    Eth1/48/2, Eth1/48/3, Eth1/48/4
                                                    Eth1/49/1, Eth1/49/2, Eth1/49/3
                                                    Eth1/49/4, Eth1/50/1, Eth1/50/2
                                                    Eth1/50/3, Eth1/50/4, Eth1/51/1
                                                    Eth1/51/2, Eth1/51/3, Eth1/51/4
                                                    Eth1/52/1, Eth1/52/2, Eth1/52/3
                                                    Eth1/52/4, Eth1/53/1, Eth1/53/2
                                                    Eth1/53/3, Eth1/53/4, Eth1/54/1
                                                    Eth1/54/2, Eth1/54/3, Eth1/54/4
                                                    Eth1/55/1, Eth1/55/2, Eth1/55/3
                                                    Eth1/55/4, Eth1/56/1, Eth1/56/2
                                                    Eth1/56/3, Eth1/56/4, Eth1/57/1
                                                    Eth1/57/2, Eth1/57/3, Eth1/57/4
                                                    Eth1/58/1, Eth1/58/2, Eth1/58/3
                                                    Eth1/58/4, Eth1/59/1, Eth1/59/2
                                                    Eth1/59/3, Eth1/59/4, Eth1/60/1
                                                    Eth1/60/2, Eth1/60/3, Eth1/60/4
                                                    Eth1/61/1, Eth1/61/2, Eth1/61/3
                                                    Eth1/61/4, Eth1/62/1, Eth1/62/2
                                                    Eth1/62/3, Eth1/62/4
    18   VLAN0018                         active    Eth1/1/1, Eth1/1/2, Eth1/1/3
    30   VLAN0030                         active    Eth1/1/1, Eth1/1/2, Eth1/1/3
    40   VLAN0040                         active    Eth1/1/1, Eth1/1/2, Eth1/1/3
    cs1# show interface trunk
    Port          Native  Status        Port
                  Vlan                  Channel
    Eth1/1/1      1       trunking      --
    Eth1/1/2      1       trunking      --
    Eth1/1/3      1       trunking      --
    Eth1/1/4      1       trunking      --
    Eth1/2/1      1       trunking      --
    Eth1/2/2      1       trunking      --
    Eth1/2/3      1       trunking      --
    Eth1/2/4      1       trunking      --
    Eth1/62/2     none
    Eth1/62/3     none
    Eth1/62/4     none
    Eth1/63       none
    Eth1/64       none
    Po1           1
    Note For specific port and VLAN usage details, refer to the banner and important notes section in your RCF.
  3. Verify that the ISL between cs1 and cs2 is functional:
    show port-channel summary
    Show example
    cs1# show port-channel summary
    Flags:  D - Down        P - Up in port-channel (members)
            I - Individual  H - Hot-standby (LACP only)
            s - Suspended   r - Module-removed
            b - BFD Session Wait
            S - Switched    R - Routed
            U - Up (port-channel)
            p - Up in delay-lacp mode (member)
            M - Not in use. Min-links not met
    Group Port-       Type     Protocol  Member Ports
          Channel
    1     Po1(SU)     Eth      LACP      Eth1/63(P)   Eth1/64(P)
    999   Po999(SD)   Eth      NONE      --
    cs1#
Step 3: Set up your ONTAP cluster
NetApp recommends that you use System Manager to set up new clusters.
System Manager provides a simple and easy workflow for cluster set up and configuration including assigning a node management IP address, initializing the cluster, creating a local tier, configuring protocols and provisioning initial storage.
What's next?
After you've installed the RCF, you verify the SSH configuration.
