Install and maintain
Replace FRUs in the Cisco Nexus 9364D-GX2A switch
Contributors netapp-lisa netapp-jsnyder
Replace faulty field replaceable units (FRUs) on Cisco Nexus 9364D-GX2A switches to restore switch functionality without replacing the entire switch.
About this task
The Cisco Nexus 9364D-GX2A switch has the following FRUs:
  • Fan module (4 total)
  • Power supply module (2 total)
  • OSFP/QSFP transceiver modules (64 fixed 400GbE ports)
Steps
  1. Go to the Cisco site for the Cisco Nexus 9364D-GX2A NX-OS Mode Switch Hardware Installation Guide.
  2. Navigate to the Replacing components section to see the FRU procedures.
  3. Follow the applicable procedure to replace your faulty FRU.
What's next?
After you've completed the applicable FRU procedure on the Cisco site, you can resume normal operations.
