Install and maintain
Replace a Cisco Nexus 9364D-GX2A switch in an AFX system
Contributors netapp-yvonneo netapp-jsnyder netapp-lisa
Replace a defective Cisco Nexus 9364D-GX2A switch in an AFX system without disrupting operation. This nondisruptive procedure (NDU) involves preparing a replacement switch and restoring the system configuration.
Review requirements
Before performing the switch replacement, make sure that:
  • You have verified the switch serial number to ensure that the correct switch is replaced.
  • On the existing cluster and network infrastructure:
    • The existing cluster is verified as completely functional, with at least one fully connected cluster switch.
    • All cluster ports are up.
    • All cluster logical interfaces (LIFs) are up and on their home ports.
    • The ONTAP cluster ping-cluster -node <node-name> command must indicate that basic connectivity and larger than PMTU communication are successful on all paths.
  • On the Nexus 9364D-GX2A replacement switch:
    • Management network connectivity on the replacement switch is functional.
    • Console access to the replacement switch is in place.
    • The node connections are ports 1/1 through 1/62.
    • All Inter-Switch Link (ISL) ports is disabled on ports 1/63 and 1/64.
    • The desired reference configuration file (RCF) and NX-OS operating system image switch is loaded onto the switch.
    • Initial customization of the switch is complete, as detailed in Complete initial switch setup.
      Any previous site customizations, such as STP, SNMP, and SSH, are copied to the new switch.
  • You have executed the command for migrating a cluster LIF from the node where the cluster LIF is hosted.
Enable console logging
NetApp strongly recommends that you enable console logging on the devices that you are using and take the following actions when replacing your switch:
Replace the switch
About the examples
The examples in this procedure use the following switch and node nomenclature:
  • The names of the existing Nexus 9364D-GX2A switches are cs1 and cs2.
  • The name of the new Nexus 9364D-GX2A switch is newcs2.
  • The node names are node1-01, node1-02, node1-03, and node1-04.
  • The cluster LIF names are node1-01_clus1 and node1-01_clus2 for node1-01, node1-02_clus1 and node1-02_clus2 for node1-02, node1-03_clus1 and node1-03_clus2 for node1-03, and node1-04_clus1 and node1-04_clus2 for node1-04.
  • The prompt for changes to all cluster nodes is cluster1::*>
About this task
The following procedure is based on the following cluster network topology:
Show example
cluster1::*> network port show -ipspace Cluster
Node: node1-01
        Ignore
                                                  Speed(Mbps) Health   Health
Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
e7a       Cluster      Cluster          up   9000  auto/10000 healthy  false
e7b       Cluster      Cluster          up   9000  auto/10000 healthy  false
Node: node1-02
        Ignore
Node: node1-03
        Ignore
Node: node1-04
        Ignore
cluster1::*> network interface show -vserver Cluster
            Logical         Status     Network            Current       Current Is
Vserver     Interface       Admin/Oper Address/Mask       Node          Port    Home
Cluster
            node1-01_clus1  up/up      169.254.209.69/16  node1-01      e7a     true
            node1-01_clus2  up/up      169.254.49.125/16  node1-01      e7b     true
            node1-02_clus1  up/up      169.254.47.194/16  node1-02      e7a     true
            node1-02_clus2  up/up      169.254.19.183/16  node1-02      e7b     true
cluster1::*> network device-discovery show -protocol cdp
Node/       Local  Discovered
Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
node1-01/cdp
            e10a   cs1(FLMXXXXXXXX)          Ethernet1/16/3    N9K-C9364D-GX2A
            e10b   cs2(FDOXXXXXXXX)          Ethernet1/16/3    N9K-C9364D-GX2A
            e11a   cs1(FLMXXXXXXXX)          Ethernet1/16/4    N9K-C9364D-GX2A
            e11b   cs2(FDOXXXXXXXX)          Ethernet1/16/4    N9K-C9364D-GX2A
            e1a    cs1(FLMXXXXXXXX)          Ethernet1/16/1    N9K-C9364D-GX2A
            e1b    cs2(FDOXXXXXXXX)          Ethernet1/16/1    N9K-C9364D-GX2A
            e7a    cs1(FLMXXXXXXXX)          Ethernet1/16/2    N9K-C9364D-GX2A
            e7b    cs2(FDOXXXXXXXX)          Ethernet1/16/2    N9K-C9364D-GX2A
cs1# show cdp neighbors
Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater,
                  V - VoIP-Phone, D - Remotely-Managed-Device,
                  s - Supports-STP-Dispute
Device-ID          Local Intrfce  Hldtme Capability  Platform      Port ID
newcs2(FDOXXXXXXXX)   Eth1/63        179    R S I s     N9K-C9332D-GX2B   Eth1/31
newcs2(FDOXXXXXXXX)   Eth1/64        179    R S I s     N9K-C9332D-GX2B   Eth1/32
node1-01              Eth1/4/1       123    H           AFX-1K            e1a
node1-01              Eth1/4/2       123    H           AFX-1K            e7a
node1-01              Eth1/4/3       123    H           AFX-1K            e10a
node1-01              Eth1/4/4       123    H           AFX-1K            e11a
node1-02              Eth1/9/1       138    H           AFX-1K            e1a
node1-02              Eth1/9/2       138    H           AFX-1K            e7a
node1-02              Eth1/9/3       138    H           AFX-1K            e10a
node1-02              Eth1/9/4       138    H           AFX-1K            e11a
node1-03              Eth1/15/1      138    H           AFX-1K            e1a
node1-03              Eth1/15/2      138    H           AFX-1K            e7a
node1-03              Eth1/15/3      138    H           AFX-1K            e10a
node1-03              Eth1/15/4      138    H           AFX-1K            e11a
node1-04              Eth1/16/1      173    H           AFX-1K            e1a
node1-04              Eth1/16/2      173    H           AFX-1K            e7a
node1-04              Eth1/16/3      173    H           AFX-1K            e10a
node1-04              Eth1/16/4      173    H           AFX-1K            e11a
Total entries displayed: 18
newcs2# show cdp neighbors
cs1(FDOXXXXXXXX)   Eth1/63        179    R S I s     N9K-C9332D-GX2B   Eth1/31
cs1(FDOXXXXXXXX)   Eth1/64        179    R S I s     N9K-C9332D-GX2B   Eth1/32
Step 1: Prepare for replacement
  1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
    system node autosupport invoke -node * -type all -message MAINT=xh
    where x is the duration of the maintenance window in hours.
    Note The AutoSupport message notifies technical support of this maintenance task so that automatic case creation is suppressed during the maintenance window.
  2. Install the appropriate RCF and image on the switch, newcs2, and make any necessary site preparations.
    If necessary, verify, download, and install the appropriate versions of the RCF and NX-OS software for the new switch. If you have verified that the new switch is correctly set up and does not need updates to the RCF and NX-OS software, continue to step 2.
    1. Go to the NetApp Cluster and Management Network Switches Reference Configuration File Description Page on the NetApp Support Site.
    2. Click the link for the Cluster Network and Management Network Compatibility Matrix, and then note the required switch software version.
    3. Click your browser's back arrow to return to the Description page, click CONTINUE, accept the license agreement, and then go to the Download page.
    4. Follow the steps on the Download page to download the correct RCF and NX-OS files for the version of ONTAP software you are installing.
  3. On the new switch, log in as admin and shut down all of the ports that will be connected to the node cluster interfaces (ports 1/1 to 1/64).
    If the switch that you are replacing is not functional and is powered down, go to Step 4. The LIFs on the cluster nodes should have already failed over to the other cluster port for each node.
    Show example
    newcs2# config
    newcs2(config)# interface e1/1/1-4,e1/2/1-4,e1/3/1-4,e1/4/1-4,e1/5/1-4,e1/6/1-4,e1/7/1-4,e1/8/1-4
    newcs2(config-if-range)# shutdown
    newcs2(config)# interface e1/9/1-4,e1/10/1-4,e1/11/1-4,e1/12/1-4,e1/13/1-4,e1/14/1-4,e1/15/1-4,e1/16/1-4
    newcs2(config)# interface e1/17/1-4,e1/18/1-4,e1/19/1-4,e1/20/1-4,e1/21/1-4,e1/22/1-4,e1/23/1-4,e1/24/1-4
    newcs2(config)# interface e1/25/1-4,e1/26/1-4,e1/27/1-4,e1/28/1-4,e1/29/1-4,e1/30/1-4,e1/31/1-4,e1/32/1-4
    newcs2(config)# interface e1/33/1-4,e1/34/1-4,e1/35/1-4,e1/36/1-4,e1/37/1-4,e1/38/1-4,e1/39/1-4,e1/40/1-4
    newcs2(config)# interface e1/41/1-4,e1/42/1-4,e1/43/1-4,e1/44/1-4,e1/45/1-4,e1/46/1-4,e1/47/1-4,e1/48/1-4
    newcs2(config)# interface e1/49/1-4,e1/50/1-4,e1/51/1-4,e1/52/1-4,e1/53/1-4,e1/54/1-4,e1/55/1-4,e1/56/1-4
    newcs2(config-if-range)# shutdown\
    newcs2(config)# interface e1/57/1-4,e1/58/1-4,e1/59/1-4,e1/60/1-4,e1/61/1-4,e1/62/1-4
    newcs2(config-if-range)# exit
    newcs2(config)# exit
  4. Verify that all cluster LIFs have auto-revert enabled:
    network interface show -vserver Cluster -fields auto-revert
    Show example
    cluster1::> network interface show -vserver Cluster -fields auto-revert
                 Logical
    Vserver      Interface        Auto-revert
    Cluster      node1-01_clus1   true
    Cluster      node1-01_clus2   true
    Cluster      node1-02_clus1   true
    Cluster      node1-02_clus2   true
    Cluster      node1-03_clus1   true
    Cluster      node1-03_clus2   true
    Cluster      node1-04_clus1   true
    Cluster      node1-04_clus2   true
    8 entries were displayed.
  5. Verify the connectivity of the remote cluster interfaces:
    1. You can use the network interface check cluster-connectivity show command to display the details of an accessibility check for cluster connectivity:
      Show example
      cluster1::*> network interface check cluster-connectivity show
                                           Source          Destination     Packet
      Node      Date                       LIF             LIF             Loss
      node1-01
                6/4/2025 03:13:33 -04:00   node1-01_clus2  node1-02_clus1  none
                6/4/2025 03:13:34 -04:00   node1-01_clus2  node1-02_clus2  none
      node1-02
                6/4/2025 03:13:33 -04:00   node1-02_clus2  node1-01_clus1  none
                6/4/2025 03:13:34 -04:00   node1-02_clus2  node1-01_clus2  none
    2. Alternatively, you can also use the cluster ping-cluster -node <node-name> command to check the connectivity:
      Show example
      cluster1::*> cluster ping-cluster -node local
      Host is node2
      Getting addresses from network interface table...
      Cluster node1_clus1 169.254.209.69 node1 e0a
      Cluster node1_clus2 169.254.49.125 node1 e0b
      Cluster node2_clus1 169.254.47.194 node2 e0a
      Cluster node2_clus2 169.254.19.183 node2 e0b
      Local = 169.254.47.194 169.254.19.183
      Remote = 169.254.209.69 169.254.49.125
      Cluster Vserver Id = 4294967293
      Ping status:
      Basic connectivity succeeds on 4 path(s)
      Basic connectivity fails on 0 path(s)
      Detected 9000 byte MTU on 4 path(s):
      Local 169.254.47.194 to Remote 169.254.209.69
      Local 169.254.47.194 to Remote 169.254.49.125
      Local 169.254.19.183 to Remote 169.254.209.69
      Local 169.254.19.183 to Remote 169.254.49.125
      Larger than PMTU communication succeeds on 4 path(s)
      RPC status:
      2 paths up, 0 paths down (tcp check)
      2 paths up, 0 paths down (udp check)
Step 2: Configure cables and ports
  1. Shut down the ISL ports 1/63 and 1/64 on the Nexus 9364D-GX2A switch cs1.
    cs1# config
    Enter configuration commands, one per line. End with CNTL/Z.
    cs1(config)# interface e1/63-64
    cs1(config-if-range)# shutdown
    cs1(config-if-range)# exit
    cs1(config)# exit
  2. Remove all of the cables from the Nexus 9364D-GX2B cs2 switch, and then connect them to the same ports on the Nexus 9364D-GX2A newcs2 switch.
  3. Bring up the ISLs ports 1/63 and 1/64 between the cs1 and newcs2 switches, and then verify the port channel operation status.
    Port-Channel should indicate Po1(SU) and Member Ports should indicate Eth1/63(P) and Eth1/64(P).
    Show example
    This example enables ISL ports 1/63 and 1/64 and displays the port channel summary on switch cs1:
    cs1# config
    cs1(config-if-range)# no shutdown
    cs1(config)# exit
    cs1#
    cs1(config-if-range)# show port-channel summary
    Flags:  D - Down        P - Up in port-channel (members)
            I - Individual  H - Hot-standby (LACP only)
            s - Suspended   r - Module-removed
            b - BFD Session Wait
            S - Switched    R - Routed
            U - Up (port-channel)
            p - Up in delay-lacp mode (member)
            M - Not in use. Min-links not met
    Group Port-        Type     Protocol  Member Ports
          Channel
    11     Po1(SU)     Eth      LACP      Eth1/63(P)   Eth1/64(P)
    999    Po999(SD)   Eth      NONE      --
  4. Bring up all of the ports on the newcs2 switch.
    Show example
    newcs2# config
    newcs2(config-if-range)# no shutdown
  5. Verify that port e7b is up on all nodes:
    network port show ipspace Cluster
    Show example
    The output should be similar to the following:
    Node: node1-01
        Ignore
    e7a       Cluster      Cluster          up   9000  auto/100000 healthy false
    e7b       Cluster      Cluster          up   9000  auto/100000 healthy false
    Node: node1-02
        Ignore
    Node: node1-03
        Ignore
    Node: node1-04
        Ignore
  6. On the same node you used in the previous step, revert the cluster LIF associated with the port in the previous step by using the network interface revert command.
    Show example
    In this example, LIF node1-01_clus2 on node1-01 is successfully reverted if the Home value is true and the port is e7b.
    The following commands return LIF node1-01_clus2 on node1-01 to home port e7a and displays information about the LIFs on both nodes. Bringing up the first node is successful if the Is Home column is true for both cluster interfaces and they show the correct port assignments, in this example e7a and e7b on node1-01.
    Cluster
                node1-02_clus1  up/up      169.254.47.194/16  node1-02   e7b     true
                node1-02_clus2  up/up      169.254.19.183/16  node1-02   e7a     false
  7. Display information about the nodes in a cluster:
    cluster show
    Show example
    This example shows that the node health for node1 and node2 in this cluster is true:
    cluster1::*> cluster show
    Node          Health  Eligibility
    node1-01      false   true
    node1-02      true    true
    node1-03      true    true
    node1-04      true    true
  8. Verify that all physical cluster ports are up:
    Show example
    Node: node1-01
        Ignore
    Node: node1-02
        Ignore
  9. Verify the connectivity of the remote cluster interfaces:
    Show example
    node1-01
    node1-02
    1. Alternatively, you can also use the cluster ping-cluster -node <node-name> command to check the connectivity:
      Show example
      Host is node2
      Ping status:
      RPC status:
Step 3: Verify the configuration
  1. Verify the health of all the ports on the cluster.
    1. Cluster ports
      1. Verify that cluster ports are up and healthy across all nodes in the cluster:
        network interface show -vserver cluster
        show cdp neighbors
        Show example
        Node: node1-01
        Ignore
        Node: node1-02
        Ignore
        Node: node1-03
        Ignore
        Node: node1-04
        Ignore
        cluster1::*> network interface show -vserver cluster
        Cluster
        cluster1::> network device-discovery show -protocol cdp
        node1-01/cdp
    2. HA ports
      1. Verify that all the HA ports are up with a healthy status:
        ha interconnect status show -node <node-name>
        Show example
        cluster1::*> ha interconnect status show -node node1-01
          (system ha interconnect status show)
                               Node: node1-01
                      Link 0 Status: up
                      Link 1 Status: up
                   Is Link 0 Active: true
                   Is Link 1 Active: true
                 IC RDMA Connection: up
                               Slot: 0
                     Debug Firmware: no
        Interconnect Port 0 :
                          Port Name: e1a-17
                                MTU: 4096
                   Link Information: ACTIVE
        Interconnect Port 1 :
                          Port Name: e1b-18
                                MTU: 4096
        cluster1::*> ha interconnect status show -node node1-02
                               Node: node1-02
                      Link 0 Status: up
                      Link 1 Status: up
                               Slot: 0
                     Debug Firmware: no
                          Port Name: e1a-17
                                MTU: 4096
                          Port Name: e1b-18
                                MTU: 4096
    3. Storage ports
      1. Verify that all the storage ports are up with a healthy status:
        storage port show -port-type ENET
        Show example
        cluster1::*> storage port show -port-type ENET
                                              Speed
        Node               Port Type  Mode    (Gb/s) State    Status
        node1-01
                           e10a ENET  -          100 enabled  online
                           e10b ENET  -          100 enabled  online
                           e11a ENET  -          100 enabled  online
                           e11b ENET  -          100 enabled  online
        node1-02
        node1-03
        node1-04
        16 entries were displayed.
    4. Storage shelf ports
      1. Verify that all the storage shelf ports are up with a healthy status:
        storage shelf port show
        Show example
        cluster1::*> storage shelf port show
        Shelf ID Module State        Internal?
        1.1
               0 A      connected    false
               1 A      connected    false
               2 A      connected    false
               3 A      connected    false
               4 A      connected    false
               5 A      connected    false
               6 A      connected    false
               7 A      connected    false
               8 B      connected    false
               9 B      connected    false
              10 B      connected    false
              11 B      connected    false
              12 B      connected    false
              13 B      connected    false
              14 B      connected    false
              15 B      connected    false
      2. Verify the connection status of all the storage shelf ports:
        storage shelf port show -fields remote-device,remote-port,connector-state
        Show example
        cluster1::*> storage shelf port show -fields remote-device,remote-port,connector-state
        shelf id connector-state remote-port    remote-device
        1.1   0  connected       Ethernet1/17/1 CX9332D-cs1
        1.1   1  connected       Ethernet1/15/1 CX9364D-cs1
        1.1   2  connected       Ethernet1/17/2 CX9332D-cs1
        1.1   3  connected       Ethernet1/15/2 CX9364D-cs1
        1.1   4  connected       Ethernet1/17/3 CX9332D-cs1
        1.1   5  connected       Ethernet1/15/3 CX9364D-cs1
        1.1   6  connected       Ethernet1/17/4 CX9332D-cs1
        1.1   7  connected       Ethernet1/15/4 CX9364D-cs1
        1.1   8  connected       Ethernet1/19/1 CX9332D-cs1
        1.1   9  connected       Ethernet1/17/1 CX9364D-cs1
        1.1   10 connected       Ethernet1/19/2 CX9332D-cs1
        1.1   11 connected       Ethernet1/17/2 CX9364D-cs1
        1.1   12 connected       Ethernet1/19/3 CX9332D-cs1
        1.1   13 connected       Ethernet1/17/3 CX9364D-cs1
        1.1   14 connected       Ethernet1/19/4 CX9332D-cs1
        1.1   15 connected       Ethernet1/17/4 CX9364D-cs1
  2. If you suppressed automatic case creation, re-enable it by invoking an AutoSupport message:
What's next?
After you've replaced your switches, you configure switch health monitoring.
