Install the RCF on the Cisco Nexus 9808 switch
Install the reference configuration file (RCF) on Cisco Nexus 9808 switches for new AFX 2K system installations, supervisor module replacements, or when resetting a switch to factory default settings.
The switch(es) must be powered on and you must have completed the Complete initial switch setup procedure.
You must have installed the desired NX-OS version using the Install the NX-OS procedure.
You must have read the Install or upgrade RCF overview page.
If you are installing the RCF on a switch as part of a supervisor module replacement or a switch reset to factory default settings, verify that your cluster is fully functional, meaning that there are no errors in the logs or similar issues.
If you are installing the RCF as part of a new AFX system installation, you can skip this requirement because the controllers in your AFX system are not powered on at this point in your AFX system installation and setup. |
If you have installed switches as part of a new AFX 2K system installation, you install the reference configuration file (RCF) on the first switch (cs1) and then repeat the steps for the second switch (cs2) using this procedure.
This procedure only requires the use of Cisco Nexus 9000 Series Switches commands.
The examples in this procedure refer to the first switch as cs1 and the second switch as cs2.
The examples shown in this procedure are for AFX 2K systems with switches running RCF 10.1. The input and output can vary depending on your RCF version.
Step 1: Prepare to install the RCF
Prepare to install the RCF on the switch(es) by making sure you have the necessary connections to download the RCF, and then download the RCF.
You must have access to an HTTP, FTP, or TFTP server. Access to one of these servers allows you to download a supported version of the RCF.
Download the RCF supported for your type of AFX system from the NetApp Support Site at mysupport.netapp.com.
New switches do not ship with the RCF installed. You must install the RCF on the switches. -
Each switch must be connected to a console or you must have remote access to each switch.
You must be connected to the switches using the serial console or have preserved basic configuration information. This is because the RCF upgrade procedure requires you to erase the switch settings and perform basic configuration.
Step 2: Install the RCF
You install the RCF on the first switch (cs1) by copying and applying the RCF to the bootflash, examining the banner output, verifying the RCF version is correct, making the current running configuration persistent, and then rebooting the switch. You repeat these steps on the second switch (cs2) if you are installing the RCF as part of a new AFX system installation.
Log in to switch cs1 using SSH or by using a serial console.
Copy the RCF to the bootflash of switch cs1 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP.
For more information on Cisco commands, refer to the appropriate guide in the Cisco Nexus 9000 Series NX-OS Command Reference.
copy <protocol>: bootflash: vrf managementShow example
This example shows TFTP being used to copy an RCF to the bootflash on switch cs1:
cs1# copy tftp: bootflash: vrf management Enter source filename: RCF-v10.1-NX9808-CL1-ST1.txt Enter hostname for the tftp server: 172.22.201.50 Trying to connect to tftp server......Connection to Server Established. TFTP get operation was successful Copy complete, now saving to disk (please wait)...
Apply the RCF previously copied to the bootflash.
This example shows the RCF file
RCF-v10.1-NX9808-CL1-ST1.txtbeing installed on switch cs1:cs1# copy RCF-v10.1-NX9808-CL1-ST1.txt running-config echo-commands
Examine the banner output from the
show banner motdcommand. You must read and follow these instructions to ensure the proper configuration and operation of the switch.Show example
cs1# show banner motd ****************************************************************************** * NetApp Reference Configuration File (RCF) * * Switch : NX9808 * Filename : RCF-v10.1-NX9808-CL1-ST1.txt * Date : 06-15-2026 * Version : v10.1 * Port Usage: * Ports 1-18 (LC1-LC8) : 400GbE Cluster/Storage/HA ports. * Ports 19-35 (LC1-LC8): 4 * 100 GbE Storage shelf ports, int e1-e8/{19-35}/1-4 * Port 36 (LC1-LC8) : Intra-Cluster ISL Ports, int e1-e8/36 * IMPORTANT NOTES * Interface port-channel998/9 is reserved to identify the version of this file. ****************************************************************************** -
Verify that the RCF is the correct version:
show running-configWhen you check the output to verify you have the correct RCF, make sure that the following information is correct:
The RCF banner
The node and port settings
Customizations
The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
Copy the current running configuration to the startup configuration to make it persistent:
cs1# copy running-config startup-config -
Reboot the switch:
cs1# reloadThis command will reboot the system. (y/n)? [n] y -
Repeat these steps on switch cs2.
After you've installed the RCF in your switch(es), you verify SSH for log collection.
