Upgrade NX-OS on the Cisco Nexus 9808 switch
Upgrade the NX-OS on Cisco Nexus 9808 switches to support new hardware or a new ONTAP version on AFX 2K systems.
NetApp recommends that you complete any ONTAP software upgrade first, then perform the software upgrade for your switches. |
Make sure you have a current backup of the switch configuration.
Verify that your cluster is fully functional, meaning that there are no errors in the logs or similar issues.
If needed, you can refer to the Cisco Nexus 9000 Series NX-OS Software Upgrade and Downgrade Guide for more information.
If needed, you can refer to the Cisco Nexus 9000 and 3000 Upgrade and ISSU Matrix, which provides information on In-Service Software Upgrade (ISSU) for Cisco Nexus 9000 Series Switches based on your current and target releases.
On the page, select Disruptive Upgrade and select your current release and target release from the dropdown list.
The version of ONTAP running on your AFX system determines the supported versions of NX-OS for your switches.
For switches in an AFX 2K system, running ONTAP 9.19.1GA or later, NX-OS 10.6 and later is supported.
For the current list of supported NX-OS versions, see the NetApp Cisco Ethernet Switches page.
Do not upgrade or downgrade your NX-OS version to an unsupported version.
Because this procedure requires the use of ONTAP commands and Cisco Nexus 9000 Series Switches commands, the steps indicate which CLI you are using to enter commands.
The examples in this procedure use the following switch and node nomenclature:
The names of the two Cisco switches are cs1 and cs2.
The node names are node1-01, node1-02, node1-03, and node1-04.
The cluster LIF names are:
node1-01_clus1 and node1-01_clus2 for node1-01
node1-02_clus1 and node1-02_clus2 for node1-02
node1-03_clus1 and node1-03_clus2 for node1-03
node1-04_clus1 and node1-04_clus2 for node1-04
The
cluster1::*>prompt indicates the name of the cluster.
The examples shown in this procedure are for AFX 2K systems with switches running RCF 10.1. The input and output can vary depending on your RCF version.
Step 1: Prepare to upgrade the NX-OS
Prepare to upgrade the NX-OS by making sure you have a management network connection to each switch, downloading the NX-OS version, checking port status on the cluster, and disabling auto-revert on the cluster LIFs.
Connect each switch to the management network.
Using the switch CLI, verify connectivity to the server hosting the NX-OS:
ping <IP address>Show example
This example verifies that the switch can reach the server at IP address 172.19.2.1:
cs1# ping 172.19.2.1 Pinging 172.19.2.1 with 0 bytes of data: Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
Download the correct version of NX-OS to the switches from the Cisco software download page.
Using the ONTAP CLI, display the cluster ports on each node that are connected to the cluster switches:
network device-discovery showShow example
cluster1::*> network device-discovery show Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ---------------- ---------------- node1-01/cdp e10a cs1(FOXXXXXXXXX) Ethernet1/5 N9K-C9808 e10b cs2(FDOXXXXXXXX) Ethernet1/14 N9K-C9808 e8a cs1(FOXXXXXXXXX) Ethernet1/7 N9K-C9808 e8b cs2(FDOXXXXXXXX) Ethernet1/16 N9K-C9808 e2a cs1(FOXXXXXXXXX) Ethernet1/3 N9K-C9808 e2b cs2(FOXXXXXXXXX) Ethernet1/12 N9K-C9808 node1-01/lldp e10a cs1 (ec:bb:78:9e:c7:e8) Ethernet1/5 - e10b cs2 (ec:bb:78:9e:c8:0c) Ethernet1/14 - e8a cs1 (ec:bb:78:9e:c7:f0) Ethernet1/7 - e8b cs2 (ec:bb:78:9e:c8:14) Ethernet1/16 - e2a cs1 (ec:bb:78:9e:c7:d8) Ethernet1/1 - e2b cs2 (ec:bb:78:9e:c7:fc) Ethernet1/10 - e1a cs1 (ec:bb:78:9e:c7:e0) Ethernet1/3 - e1b cs2 (ec:bb:78:9e:c8:04) Ethernet1/12 - node1-02/cdp e10a cs1(FOXXXXXXXXX) Ethernet1/6 N9K-C9808 e10b cs2(FDOXXXXXXXX) Ethernet1/15 N9K-C9808 e8a cs1(FOXXXXXXXXX) Ethernet1/8 N9K-C9808 e8b cs2(FDOXXXXXXXX) Ethernet1/17 N9K-C9808 e2a cs1(FOXXXXXXXXX) Ethernet1/2 N9K-C9808 e2b cs2(FDOXXXXXXXX) Ethernet1/13 N9K-C9808 node1-02/lldp e10a cs1 (ec:bb:78:9e:c7:ec) Ethernet1/6 - e10b cs2 (ec:bb:78:9e:c8:10) Ethernet1/15 - e8a cs1 (ec:bb:78:9e:c7:f4) Ethernet1/8 - e8b cs2 (ec:bb:78:9e:c8:18) Ethernet1/17 - e1a cs1 (ec:bb:78:9e:c7:dc) Ethernet1/2 - e1b cs2 (ec:bb:78:9e:c8:00) Ethernet1/11 - e2a cs1 (ec:bb:78:9e:c7:e4) Ethernet1/4 - e2b cs2 (ec:bb:78:9e:c8:08) Ethernet1/13 - -
Using the ONTAP CLI, check the administrative and operational status of each port:
Cluster ports
Verify that all the cluster ports are up with a healthy status:
network port show -ipspace ClusterShow example
cluster1::*> network port show -ipspace Cluster Node: node1-01 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ------------ -------- ------ e2a Cluster Cluster up 9000 auto/400000 healthy false e2b Cluster Cluster up 9000 auto/400000 healthy false Node: node1-02 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ------------ -------- ------ e2a Cluster Cluster up 9000 auto/400000 healthy false e2b Cluster Cluster up 9000 auto/400000 healthy false Node: node1-03 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ------------ -------- ------ e2a Cluster Cluster up 9000 auto/400000 healthy false e2b Cluster Cluster up 9000 auto/400000 healthy false Node: node1-04 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ------------ -------- ------ e2a Cluster Cluster up 9000 auto/400000 healthy false e2b Cluster Cluster up 9000 auto/400000 healthy false -
Verify that all the cluster interfaces (LIFs) are on the home port:
network interface show -role clusterShow example
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- --------------- ---------- ------------------ --------- ------- ---- Cluster node1-01_clus1 up/up 169.254.36.44/16 node1-01 e2a true node1-01_clus2 up/up 169.254.7.5/16 node1-01 e2b true node1-02_clus1 up/up 169.254.197.206/16 node1-02 e2a true node1-02_clus2 up/up 169.254.195.186/16 node1-02 e2b true node1-03_clus1 up/up 169.254.192.49/16 node1-03 e2a true node1-03_clus2 up/up 169.254.182.76/16 node1-03 e2b true node1-04_clus1 up/up 169.254.59.49/16 node1-04 e2a true node1-04_clus2 up/up 169.254.62.244/16 node1-04 e2b true -
Verify that the cluster displays information for both cluster switches:
system cluster-switch show -is-monitoring-enabled-operational trueShow example
cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true Switch Type Address Model --------------------------- ------------------ ---------------- --------- cs2(FDOXXXXXXXX) cluster-network 10.228.137.233 N9K-C9808 Serial Number: FDOXXXXXXXX Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 10.5(3)(F) Version Source: CDP/ISDP cs1(FOXXXXXXXXX) cluster-network 10.228.137.253 N9K-C9808 Serial Number: FOXXXXXXXXX Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 10.5(3)(F) Version Source: CDP/ISDP
HA ports
Verify that all the HA ports are up with a healthy status:
ha interconnect status show -node <node-name>Show example
cluster1::*> ha interconnect status show -node node1-01 (system ha interconnect status show) Node: node1-01 Link 0 Status: up Link 1 Status: up Is Link 0 Active: true Is Link 1 Active: true IC RDMA Connection: up Slot: 0 Debug Firmware: no Interconnect Port 0 : Port Name: e1a-17 MTU: 4096 Link Information: ACTIVE Interconnect Port 1 : Port Name: e1b-18 MTU: 4096 Link Information: ACTIVE cluster1::*> ha interconnect status show -node node1-02 (system ha interconnect status show) Node: node1-02 Link 0 Status: up Link 1 Status: up Is Link 0 Active: true Is Link 1 Active: true IC RDMA Connection: up Slot: 0 Debug Firmware: no Interconnect Port 0 : Port Name: e1a-17 MTU: 4096 Link Information: ACTIVE Interconnect Port 1 : Port Name: e1b-18 MTU: 4096 Link Information: ACTIVE . . . -
Verify that all the HA ports are correctly configured and that the interconnect type is RoCE:
ha interconnect config showShow example
cluster1::*> ha interconnect config show (system ha interconnect config show) Node: node1-01 Interconnect Type: RoCE Local System ID: 542023071 Partner System ID: 542022984 Connection Initiator: local Interface: external Port IP Address Flags ------ ----------------- ----------- e1a-17 169.254.17.111 0x0 e1b-18 169.254.18.242 0x0 Node: node1-02 Interconnect Type: RoCE Local System ID: 542022984 Partner System ID: 542023071 Connection Initiator: partner Interface: external Port IP Address Flags ------ ----------------- ----------- e1a-17 169.254.17.208 0x0 e1b-18 169.254.18.169 0x0 . . .
Storage ports
Verify that all the storage ports are up with a healthy status:
storage port show -port-type ENETShow example
cluster1::*> storage port show -port-type ENET Speed Node Port Type Mode (Gb/s) State Status ------------------ ---- ----- ------- ------ -------- ----------- node1-01 e10a ENET - 400 enabled online e10b ENET - 0 enabled offline e8a ENET - 400 enabled online e8b ENET - 0 enabled offline node1-02 e10a ENET - 400 enabled online e10b ENET - 0 enabled offline e8a ENET - 400 enabled online e8b ENET - 0 enabled offline node1-03 e10a ENET - 400 enabled online e10b ENET - 0 enabled offline e8a ENET - 400 enabled online e8b ENET - 0 enabled offline node1-04 e10a ENET - 400 enabled online e10b ENET - 0 enabled offline e8a ENET - 400 enabled online e8b ENET - 0 enabled offline
Storage shelf ports
Verify that all the storage shelf ports are up with a healthy status:
storage shelf port showShow example
cluster1::*> storage shelf port show Shelf ID Module State Internal? ----- -- ------ ------------ --------- 1.1 0 A connected false 1 A connected false 2 A connected false 3 A connected false 4 A connected false 5 A connected false 6 A connected false 7 A connected false 8 B connected false 9 B connected false 10 B connected false 11 B connected false 12 B connected false 13 B connected false 14 B connected false 15 B connected false -
Verify the connection status of all the storage shelf ports:
storage shelf port show -fields remote-device,remote-port,connector-stateShow example
cluster1::*> storage shelf port show -fields remote-device,remote-port,connector-state shelf id connector-state remote-port remote-device ----- -- --------------- -------------- ----------------- 1.1 0 connected Ethernet1/17/1 cs1(FOXXXXXXXXX) 1.1 1 connected Ethernet1/15/1 cs2(FDOXXXXXXXX) 1.1 2 connected Ethernet1/17/2 cs1(FOXXXXXXXXX) 1.1 3 connected Ethernet1/15/2 cs2(FDOXXXXXXXX) 1.1 4 connected Ethernet1/17/3 cs1(FOXXXXXXXXX) 1.1 5 connected Ethernet1/15/3 cs2(FDOXXXXXXXX) 1.1 6 connected Ethernet1/17/4 cs1(FOXXXXXXXXX) 1.1 7 connected Ethernet1/15/4 cs2(FDOXXXXXXXX) 1.1 8 connected Ethernet1/19/1 cs1(FOXXXXXXXXX) 1.1 9 connected Ethernet1/17/1 cs2(FDOXXXXXXXX) 1.1 10 connected Ethernet1/19/2 cs1(FOXXXXXXXXX) 1.1 11 connected Ethernet1/17/2 cs2(FDOXXXXXXXX) 1.1 12 connected Ethernet1/19/3 cs1(FOXXXXXXXXX) 1.1 13 connected Ethernet1/17/3 cs2(FDOXXXXXXXX) 1.1 14 connected Ethernet1/19/4 cs1(FOXXXXXXXXX) 1.1 15 connected Ethernet1/17/4 cs2(FDOXXXXXXXX)
Using the ONTAP CLI, disable auto-revert on the cluster LIFs. The cluster LIFs fail over to the partner cluster switch and remain there as you perform this procedure on the targeted switch:
network interface modify -vserver Cluster -lif * -auto-revert false
Step 2: Install the NX-OS
You install the NX-OS on the first switch (cs1) by installing and verifying the new version of the NX-OS and EPLD, verifying the health of all ports on the cluster, and then repeat these steps on the second switch (cs2).
Using the switch CLI, copy the combined NX-OS and EPLD image to a switch:
copy <protocol>: bootflash: vrf managementShow example
The example uses sftp.
cs1# copy sftp: bootflash: vrf management Enter source filename: /code/nxos64-s1.10.6.3.F.bin Enter hostname for the sftp server: 172.19.2.1 Enter username: user1 Outbound-ReKey for 172.19.2.1:22 Inbound-ReKey for 172.19.2.1:22 user1@172.19.2.1's password: sftp> progress Progress meter enabled sftp> get code/nxos64-s1.10.6.3.F.bin /bootflash/nxos64-s1.10.6.3.F.bin /code/nxos64-s1.10.6.3.F.bin 100% 1261MB 9.3MB/s 02:15 sftp> exit Copy complete, now saving to disk (please wait)... Copy complete.
Using the switch CLI, verify the running version of NX-OS:
show versionShow example
cs1# show version Cisco Nexus Operating System (NX-OS) Software TAC support: http://www.cisco.com/tac Copyright (C) 2002-2025, Cisco and/or its affiliates. All rights reserved. The copyrights to certain works contained in this software are owned by other third parties and used and distributed under their own licenses, such as open source. This software is provided "as is," and unless otherwise stated, there is no warranty, express or implied, including but not limited to warranties of merchantability and fitness for a particular purpose. Certain components of this software are licensed under the GNU General Public License (GPL) version 2.0 or GNU General Public License (GPL) version 3.0 or the GNU Lesser General Public License (LGPL) Version 2.1 or Lesser General Public License (LGPL) Version 2.0. A copy of each such license is available at http://www.opensource.org/licenses/gpl-2.0.php and http://opensource.org/licenses/gpl-3.0.html and http://www.opensource.org/licenses/lgpl-2.1.php and http://www.gnu.org/licenses/old-licenses/library.txt. Software BIOS: version 01.14 NXOS: version 10.5(3)(F) [Feature Release] Host NXOS: version 10.5(3)(F) BIOS compile time: 11/25/2024 NXOS image file is: bootflash:///nxos64-s1.10.5.3.F.bin NXOS compile time: 11/30/2023 12:00:00 [12/14/2023 05:25:50] NXOS boot mode: LXC Hardware cisco Nexus9000 C9808 Chassis Intel(R) Xeon(R) CPU D-1633N @ 2.50GHz with 32802156 kB of memory. Processor Board ID FLMXXXXXXXX Device name: cs1 bootflash: 115802886 kB Kernel uptime is 5 day(s), 2 hour(s), 13 minute(s), 21 second(s) Last reset at 3580 usecs after Thu Jun 5 15:55:08 2025 Reason: Reset Requested by CLI command reload System version: 10.4(1) Service: plugin Core Plugin, Ethernet Plugin Active Package(s): cs1#
Using the switch CLI, install the NX-OS and EPLD image.
Installing the image file causes it to be loaded every time the switch reboots:
install all nxos bootflash:nxos.<version number>.binShow example
The example uses NX-OS version 10.6(3)(F).
cs1# install all nxos bootflash:/nxos64-s1.10.6.3.F.bin Installer will perform compatibility check first. Please wait. Installer is forced disruptive Verifying image bootflash:/nxos64-s1.10.6.3.F.bin for boot variable "nxos". [] 100% -- SUCCESS Verifying image type. [] 100% -- SUCCESS Preparing "nxos" version info using image bootflash://nxos64-s1.10.6.3.F.bin. [] 100% -- SUCCESS Preparing "bios" version info using image bootflash:/nxos64-s1.10.6.3.F.bin. [] 100% -- SUCCESS Performing module support checks. [] 100% -- SUCCESS Notifying services about system upgrade. [] 100% -- SUCCESS Compatibility check is done: Module Bootable Impact Install-type Reason ------ -------- --------------- ------------ --------- 1 yes Disruptive Reset Default upgrade is not hitless Images will be upgraded according to following table: Module Image Running-Version(pri:alt) New-Version Upg-Required ------- --------- ---------------------------------------- ------------------- ------------ 1 nxos 10.5(3)(F) 10.6(3)(F) Yes 1 bios xx.xx.:xx.xx xxx No Switch will be reloaded for disruptive upgrade. Do you want to continue with the installation (y/n)? [n] y Install is in progress, please wait. Performing runtime checks. [] 100% -- SUCCESS Setting boot variables. [] 100% -- SUCCESS Performing configuration copy. [] 100% -- SUCCESS Module 1: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. [] 100% -- SUCCESS Finishing the upgrade, switch will reboot in 10 seconds.
Using the switch CLI, verify the new version of NX-OS after the switch reboots:
cs1# show version Cisco Nexus Operating System (NX-OS) Software TAC support: http://www.cisco.com/tac Copyright (C) 2002-2025, Cisco and/or its affiliates. All rights reserved. The copyrights to certain works contained in this software are owned by other third parties and used and distributed under their own licenses, such as open source. This software is provided "as is," and unless otherwise stated, there is no warranty, express or implied, including but not limited to warranties of merchantability and fitness for a particular purpose. Certain components of this software are licensed under the GNU General Public License (GPL) version 2.0 or GNU General Public License (GPL) version 3.0 or the GNU Lesser General Public License (LGPL) Version 2.1 or Lesser General Public License (LGPL) Version 2.0. A copy of each such license is available at http://www.opensource.org/licenses/gpl-2.0.php and http://opensource.org/licenses/gpl-3.0.html and http://www.opensource.org/licenses/lgpl-2.1.php and http://www.gnu.org/licenses/old-licenses/library.txt. Software BIOS: version 01.14 NXOS: version 10.6(3)(F) [Feature Release] Host NXOS: version 10.6(3)(F) BIOS compile time: 11/25/2024 NXOS image file is: bootflash:///nxos64-s1.10.6.3.F.bin NXOS compile time: 05/30/2026 12:00:00 [06/14/2026 05:25:50] NXOS boot mode: LXC Hardware cisco Nexus9000 C9808 Chassis Intel(R) Xeon(R) CPU D-1633N @ 2.50GHz with 32802156 kB of memory. Processor Board ID FLMXXXXXXXX Device name: cs1 bootflash: 115802886 kB Kernel uptime is 5 day(s), 2 hour(s), 13 minute(s), 21 second(s) Last reset at 3580 usecs after Thu Jun 5 15:55:08 2025 Reason: Reset Requested by CLI command reload System version: 10.4(2) Service: plugin Core Plugin, Ethernet Plugin Active Package(s): cs1#
Using the switch CLI, verify that the new version of EPLD loaded successfully:
show install epld statusShow example
The example uses EPLD version 10.6(3)(F).
cs1# show install epld status 1) Module 2 upgraded on Mon May 4 09:17:08 2026 (631239 us) EPLD Install Image: EPLD image file 10.6.3.F. built on Fri Apr 24 19:49:50 2026 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- MI FPGA 0x10014 0x1000b IO FPGA 0x10033 0x10006 2) Module 27 upgraded on Wed Apr 1 15:03:13 2026 (193093 us) EPLD Install Image: EPLD image file 10.6.3.F. built on Mon Mar 16 03:28:47 2026 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- IO FPGA 0x1002d 0x10020 3) Module 28 upgraded on Wed Apr 1 14:59:53 2026 (843907 us) EPLD Install Image: EPLD image file 10.6.3.F. built on Mon Mar 16 03:28:47 2026 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- IO FPGA 0x1002d 0x10020 4) Module 27 upgraded on Fri Mar 27 21:55:55 2026 (132290 us) EPLD Install Image: EPLD image file 10.6.2.F. built on Fri Dec 12 11:15:18 2025 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- FM-19 FPGA 0x10006 0x10000 FM-20 FPGA 0x10006 0x10000 FM-21 FPGA 0x10006 0x10000 FM-22 FPGA 0x10006 0x10000 FM-23 FPGA 0x10006 0x10000 FM-24 FPGA 0x10006 0x10000 FM-25 FPGA 0x10006 0x10000 FM-26 FPGA 0x10006 0x10000 5) Module 27 upgraded on Fri Mar 27 21:50:16 2026 ( 4899 us) EPLD Install Image: EPLD image file 10.6.2.F. built on Fri Dec 12 11:15:18 2025 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- FM-19 FPGA 0x10006 0x10000 FM-20 FPGA 0x10006 0x10000 FM-21 FPGA 0x10006 0x10000 FM-22 FPGA 0x10006 0x10000 FM-23 FPGA 0x10006 0x10000 FM-24 FPGA 0x10006 0x10000 FM-25 FPGA 0x10006 0x10000 FM-26 FPGA 0x10006 0x10000 6) Module 27 upgraded on Fri Mar 27 21:44:36 2026 (775397 us) EPLD Install Image: EPLD image file 10.6.2.F. built on Fri Dec 12 11:15:18 2025 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- FM-19 FPGA 0x10006 0x10000 FM-20 FPGA 0x10006 0x10000 FM-21 FPGA 0x10006 0x10000 FM-22 FPGA 0x10006 0x10000 FM-23 FPGA 0x10006 0x10000 FM-24 FPGA 0x10006 0x10000 FM-25 FPGA 0x10006 0x10000 FM-26 FPGA 0x10006 0x10000 7) Module 27 upgraded on Fri Mar 27 21:38:58 2026 (330582 us) EPLD Install Image: EPLD image file 10.6.2.F. built on Fri Dec 12 11:15:18 2025 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- FM-19 FPGA 0x10006 0x10000 FM-20 FPGA 0x10006 0x10000 FM-21 FPGA 0x10006 0x10000 FM-22 FPGA 0x10006 0x10000 FM-23 FPGA 0x10006 0x10000 FM-24 FPGA 0x10006 0x10000 FM-25 FPGA 0x10006 0x10000 FM-26 FPGA 0x10006 0x10000 8) Module 27 upgraded on Fri Mar 27 21:33:19 2026 (112679 us) EPLD Install Image: EPLD image file 10.6.2.F. built on Fri Dec 12 11:15:18 2025 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- FM-19 FPGA 0x10006 0x10000 FM-20 FPGA 0x10006 0x10000 FM-21 FPGA 0x10006 0x10000 FM-22 FPGA 0x10006 0x10000 FM-23 FPGA 0x10006 0x10000 FM-24 FPGA 0x10006 0x10000 FM-25 FPGA 0x10006 0x10000 FM-26 FPGA 0x10006 0x10000 9) Module 27 upgraded on Fri Mar 27 21:27:41 2026 (957182 us) EPLD Install Image: EPLD image file 10.6.2.F. built on Fri Dec 12 11:15:18 2025 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- FM-19 FPGA 0x10006 0x10000 FM-20 FPGA 0x10006 0x10000 FM-21 FPGA 0x10006 0x10000 FM-22 FPGA 0x10006 0x10000 FM-23 FPGA 0x10006 0x10000 FM-24 FPGA 0x10006 0x10000 FM-25 FPGA 0x10006 0x10000 FM-26 FPGA 0x10006 0x10000 10) Module 27 upgraded on Fri Mar 27 21:22:03 2026 ( 90303 us) EPLD Install Image: EPLD image file 10.6.2.F. built on Fri Dec 12 11:15:18 2025 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- FM-19 FPGA 0x10006 0x10000 FM-20 FPGA 0x10006 0x10000 FM-21 FPGA 0x10006 0x10000 FM-22 FPGA 0x10006 0x10000 FM-23 FPGA 0x10006 0x10000 FM-24 FPGA 0x10006 0x10000 FM-25 FPGA 0x10006 0x10000 FM-26 FPGA 0x10006 0x10000 11) Module 1 upgraded on Fri Mar 27 21:16:24 2026 (240369 us) EPLD Install Image: EPLD image file 10.6.2.F. built on Fri Dec 12 11:15:18 2025 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- MI FPGA 0x10014 0x1000b IO FPGA 0x10033 0x10006
Using the ONTAP CLI, verify the health of all the ports on the cluster.
Cluster ports
Verify that cluster ports are up and healthy across all nodes in the cluster:
cluster1::*> network port show -ipspace Cluster Node: node1-01 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ------------ -------- ------ e2a Cluster Cluster up 9000 auto/400000 healthy false e2b Cluster Cluster up 9000 auto/400000 healthy false Node: node1-02 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ------------ -------- ------ e2a Cluster Cluster up 9000 auto/400000 healthy false e2b Cluster Cluster up 9000 auto/400000 healthy false Node: node1-03 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ------------- -------- ------ e2a Cluster Cluster up 9000 auto/400000 healthy false e2b Cluster Cluster up 9000 auto/400000 healthy false Node: node1-04 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ------------ -------- ------ e2a Cluster Cluster up 9000 auto/400000 healthy false e2b Cluster Cluster up 9000 auto/400000 healthy false -
Verify the switch health from the cluster:
network device-discovery show -protocol cdpsystem cluster-switch show -is-monitoring-enabled-operational trueShow example
cluster1::*> network device-discovery show -protocol cdp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ---------------- ---------------- node1-01/cdp e10a cs1(FOXXXXXXXXX) Ethernet1/5 N9K-C9808 e10b cs2(FDOXXXXXXXX) Ethernet1/14 N9K-C9808 e8a cs1(FOXXXXXXXXX) Ethernet1/7 N9K-C9808 e8b cs2(FDOXXXXXXXX) Ethernet1/16 N9K-C9808 e2a cs1(FOXXXXXXXXX) Ethernet1/3 N9K-C9808 e2b cs2(FOXXXXXXXXX) Ethernet1/12 N9K-C9808 . . . node1-02/cdp e10a cs1(FOXXXXXXXXX) Ethernet1/6 N9K-C9808 e10b cs2(FDOXXXXXXXX) Ethernet1/15 N9K-C9808 e8a cs1(FOXXXXXXXXX) Ethernet1/8 N9K-C9808 e8b cs2(FDOXXXXXXXX) Ethernet1/17 N9K-C9808 e2a cs1(FOXXXXXXXXX) Ethernet1/2 N9K-C9808 e2b cs2(FDOXXXXXXXX) Ethernet1/13 N9K-C9808 . . . cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true Switch Type Address Model --------------------------- ------------------ ---------------- --------------- cs1(FOXXXXXXXXX) cluster-network 10.228.137.233 N9K-C9808 Serial Number: FOXXXXXXXXX Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 10.6(3)(F) Version Source: CDP/ISDP cs2(FDOXXXXXXXX) cluster-network 10.228.137.253 N9K-C9808 Serial Number: FDOXXXXXXXX Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 10.6(3)(F) Version Source: CDP/ISDP
HA ports
Storage ports
Storage shelf ports
cluster1::*> storage shelf port show Shelf ID Module State Internal? ----- -- ------ ------------ --------- 1.1 0 A connected false 1 A connected false 2 A connected false 3 A connected false 4 A connected false 5 A connected false 6 A connected false 7 A connected false 8 B connected false 9 B connected false 10 B connected false 11 B connected false 12 B connected false 13 B connected false 14 B connected false 15 B connected false 16 entries were displayed. -
cluster1::*> storage shelf port show -fields remote-device,remote-port,connector-state shelf id connector-state remote-port remote-device ----- -- --------------- -------------- ----------------- 1.1 0 connected Ethernet1/17/1 cs1(FOXXXXXXXXX) 1.1 1 connected Ethernet1/15/1 cs2(FDOXXXXXXXX) 1.1 2 connected Ethernet1/17/2 cs1(FOXXXXXXXXX) 1.1 3 connected Ethernet1/15/2 cs2(FDOXXXXXXXX) 1.1 4 connected Ethernet1/17/3 cs1(FOXXXXXXXXX) 1.1 5 connected Ethernet1/15/3 cs2(FDOXXXXXXXX) 1.1 6 connected Ethernet1/17/4 cs1(FOXXXXXXXXX) 1.1 7 connected Ethernet1/15/4 cs2(FDOXXXXXXXX) 1.1 8 connected Ethernet1/19/1 cs1(FOXXXXXXXXX) 1.1 9 connected Ethernet1/17/1 cs2(FDOXXXXXXXX) 1.1 10 connected Ethernet1/19/2 cs1(FOXXXXXXXXX) 1.1 11 connected Ethernet1/17/2 cs2(FDOXXXXXXXX) 1.1 12 connected Ethernet1/19/3 cs1(FOXXXXXXXXX) 1.1 13 connected Ethernet1/17/3 cs2(FDOXXXXXXXX) 1.1 14 connected Ethernet1/19/4 cs1(FOXXXXXXXXX) 1.1 15 connected Ethernet1/17/4 cs2(FDOXXXXXXXX) 16 entries were displayed.
Using the ONTAP CLI, verify that the cluster is healthy:
cluster showShow example
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------ ------------ node1-01 true true false node1-02 true true false node1-03 true true false node1-04 true true true
Repeat these steps to install the NX-OS and EPLD image on switch cs2.
Step 3: Complete the NX-OS upgrade
Using the ONTAP CLI, complete the NX-OS upgrade by re-enabling auto-revert on the cluster LIFs and verifying the cluster LIFs reverted to their home ports.
Re-enable auto-revert on the cluster LIFs:
network interface modify -vserver Cluster -lif * -auto-revert true -
Verify that the cluster LIFs have reverted to their home port:
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- --------------- ---------- ------------------ ----------- ------- ---- Cluster node1-01_clus1 up/up 169.254.36.44/16 node1-01 e2a true node1-01_clus2 up/up 169.254.7.5/16 node1-01 e2b true node1-02_clus1 up/up 169.254.197.206/16 node1-02 e2a true node1-02_clus2 up/up 169.254.195.186/16 node1-02 e2b true node1-03_clus1 up/up 169.254.192.49/16 node1-03 e2a true node1-03_clus2 up/up 169.254.182.76/16 node1-03 e2b true node1-04_clus1 up/up 169.254.59.49/16 node1-04 e2a true node1-04_clus2 up/up 169.254.62.244/16 node1-04 e2b trueIf any cluster LIFs have not returned to their home ports, revert them manually from the local node:
network interface revert -vserver Cluster -lif <lif-name>
After you've upgraded the NX-OS on your switches, you upgrade the RCF starting with the Install or upgrade the RCF overview.
