Install and maintain
Troubleshoot log collection for Ethernet switch health monitoring
Contributors netapp-yvonneo netapp-jsnyder
If you encounter any of the following error statuses reported by the log collection feature (visible in the output of the system switch ethernet log show command), try the corresponding debug steps:
Log collection error status
Resolution
RSA keys not present
Regenerate ONTAP SSH keys.
Switch password error
Verify credentials, test SSH connectivity, and regenerate ONTAP SSH keys. Review the switch documentation or contact NetApp support for instructions.
ECDSA keys not present for FIPS
If FIPS mode is enabled, ECDSA keys need to be generated on the switch before retrying.
Pre-existing log found
Remove the previous log collection file on the switch.
Switch dump log error
Ensure the switch user has log collection permissions. Refer to the prerequisites above.
Note If the resolution details do not work, contact NetApp support.
