Request doc changesEdit this pageLearn how to contribute
ON THIS PAGE
    • Product and Solutions
    • Support and Training
    • Cloud Central
    • Community
    • Blog
    • Customer Stories
    • Contact
    • Contact
    Menu bars
    netapp-mark netapp-logo
    English
      • English
      • 日本語
      • 한국어
      • 简体中文
      • 繁體中文
    Available PDFs
    • PDF of this doc site
      • Broadcom-supported BES-53248 switches
        • Set up the switch
          • Install licenses
        • Migrate from CN1610 switches to BES-53248 switches
        • Migrate to a two-node switched cluster
        • Upgrade a switch in an NDO/NDU environment
          • Install licenses
      • Cisco Nexus 3132Q-V switches
        • Set up
          • Required cluster configuration information
          • Sample and blank cabling worksheets
        • Install NX-OS software and RCFs on Cisco Nexus 3132Q-V cluster switches
        • Migrate to a two-node switched cluster with Cisco Nexus 3132Q-V cluster switches
        • Replace Cisco Nexus 3132Q-V cluster switches
        • Replace a Cisco Nexus 5596 cluster switch with a Cisco Nexus 3132Q-V cluster switch
        • Replace CN1610 cluster switches with Cisco Nexus 3132Q-V cluster switches
      • Cisco Nexus 3232C switches
        • Set up
        • Install NX-OS software and RCFs on Cisco Nexus 3232C cluster switches
        • Migrate a CN1610 switch to a Cisco Nexus 3232C cluster switch
        • Migrate from a Cisco Nexus 5596 switch to a Cisco Nexus 3232C switch
        • Migrate from a two-node switchless cluster to a cluster with Cisco Nexus 3232C cluster switches
        • Replace a Cisco Nexus 3232C cluster switch
        • Replace a Cisco Nexus 3232C storage switch
      • Cisco Nexus 9336C-FX2 switches
        • Set up
        • Install NX-OS software and RCFs on Cisco Nexus 9336C-FX2 cluster switches
        • Migrate from a Cisco switch to a Cisco Nexus 9336C-FX2 cluster switch
        • Migrate to a two-node switched cluster with Cisco Nexus 9336C-FX2 cluster switches
        • Configure a Cisco Nexus 9336C-FX2 cluster switch
      • Cisco Nexus 9336C-FX2 shared switches
      • Cisco Nexus 92300YC switches
        • Set up
        • Configure a new Cisco Nexus 92300YC switch
        • Install NX-OS software and RCF on Cisco Nexus 92300YC cluster switches
        • Migrate to a two-node switched cluster with Cisco Nexus 92300YC switches
        • Migrate from a Cisco switch to a Cisco Nexus 92300YC switch
      • Other switch models
    Creating your file...
    Your file is ready
    • AFF and FAS switch docs
      • Overview of the BES-53248 cluster switch
      • Set up the switch
        • Required documentation
        • BES-53248 cluster switch configuration requirements
        • Configure a new BES-53248 switch
        • Initial installation
        • Enable SSH on BES-53248 cluster switches
        • Install the EFOS software
        • Install licenses
          • Install licenses for BES-53248 cluster switches
          • Restrictions and limitations
          • Edit the Reference Configuration File (RCF)
        • Install the Reference Configuration File (RCF)
        • Configure the cluster switch log collection feature
        • Install the Cluster Switch Health Monitor (CSHM) configuration file
        • Before you begin
        • How to migrate
        • Prepare to migrate
        • Migrate to a switched NetApp cluster environment
        • Overview
        • Prepare the controller
        • Install licenses
        • Verify the configuration
      • Replace a BES-53248 switch
      • Overview
      • Install a Cisco Nexus 3132Q-V cluster switch and a pass-through panel in a NetApp cabinet
      • Set up
        • Set up the switches
          • Install the Cluster Switch Health Monitor (CSHM) configuration file for 92300YC switches
        • Considerations for using Smart Call Home
          • Cisco Nexus 9336C-FX2 cabling worksheet
          • Cisco Nexus 92300YC cabling worksheet
          • Cisco Nexus 3232C cabling worksheet
          • Cisco Nexus 3132Q-V cabling worksheet
          • Cisco Nexus 5596UP and 5596T cabling worksheet
        • Install the NX-OS software
        • How to migrate a two-node switched cluster with Cisco Nexus 3132Q-V cluster switches
        • How to replace Cisco Nexus 3132Q-V cluster switches
        • How to replace a Cisco Nexus 5596 cluster switch with a Cisco Nexus 3132Q-V cluster switch
        • How to replace CN1610 cluster switches with Cisco Nexus 3132Q-V cluster switches
      • Overview
      • Install a Cisco Nexus 3232C cluster switch and a pass-through panel in a NetApp cabinet
      • Set up
        • How to migrate a CN1610 cluster switch to a Cisco Nexus 3232C cluster switch
        • How to migrate from a Cisco Nexus 5596 cluster switch to a Cisco Nexus 3232C cluster switch
        • How to migrate from a two-node switchless cluster to a cluster with Cisco Nexus 3232C cluster switches
        • How to replace a Cisco Nexus 3232C cluster switch
        • Steps to replace a Cisco Nexus 3232C storage switch
      • Upgrade a Cisco Nexus 3232C storage switch
      • Overview
      • Install a Cisco Nexus 9336C-FX2 switch and pass-through panel in a NetApp cabinet
      • Set up
        • Overview
        • Overview
        • How to migrate from a Cisco switch to a Cisco Nexus 9336C-FX2 cluster switch
        • Overview
        • How to migrate to a switched NetApp cluster environment with Cisco Nexus 9336C-FX2 cluster switches
        • Overview
        • Initial installation of the Nexus 9336C-FX2 cluster switch
      • Replace a Cisco Nexus 9336C-FX2 cluster switch
      • Replace a Cisco Nexus 9336C-FX2 storage switch
      • Setup and configuration guide for Cisco shared switches
      • Install NX-OS software and Reference Configuration Files (RCFs)
      • Migrate from a switchless cluster with direct-attached storage by adding two new shared switches
      • Migrate from a switched configuration with direct-attached storage by adding two new shared switches
      • Migrate from a switchless configuration with switch-attached storage by reusing the storage switches
      • Migrate from a switched cluster with switch-attached storage by reusing the storage switches
      • Replace a Cisco Nexus 9336C-FX2 shared switch
      • Overview
      • Set up
          • Sample cabling worksheet
        • Overview
        • Initial installation of the Cisco Nexus 92300YC switch
        • Overview
        • Overview
        • How to migrate
        • Overview
        • How to migrate from a Cisco switch to a Cisco Nexus 92300YC switch
        • Replace a Cisco Nexus 92300YC switch
    • Legal notices
    • docs.netapp.com
    • ONTAP Systems Switches
    NetApp 10G Cluster-Mode Switch Installation
    03/02/2022 Contributors netapp-yvonneo
    An overview of the CN1610 switch hardware and software features and describes the features to install the switch and access the CLI.
    10G Installation Guide
    • © 2022 NetApp, Inc.
    • Terms of Use
    • Privacy Policy
    • Cookie Policy
    • Cookie Settings
    • Have feedback for our website? Let us know
    • Announcements
    • blog blog@
    • community community@
    • twitter twitter@
    • facebook facebook@
    • linkedin linkedin@
    • youtube youtube@
    • slideshare slideshare@
