Install a Reference Configuration File on a CN1610 switch
When you are installing a reference configuration file (RCF), you must first migrate the cluster LIFs away from switch cs2. After the RCF is installed and validated, the LIFs can be migrated back.
You must have saved the configuration that is currently running on your switch.
Save your current switch configuration information:
write memory
The following example shows the current switch configuration being saved to the startup configuration (
startup-config
) file on switch cs2:(cs2) # write memory This operation may take a few minutes. Management interfaces will not be available during this time. Are you sure you want to save? (y/n) y Config file 'startup-config' created successfully. Configuration Saved!
On the console of each node, migrate clus2 to port e1a:
network interface migrate
cluster::*> network interface migrate -vserver vs1 -lif clus2 -source-node node1 -destnode node1 -dest-port e1a cluster::*> network interface migrate -vserver vs2 -lif clus2 -source-node node2 -destnode node2 -dest-port e1a
On the console of each node, verify that the migration occurred:
network interface show -role cluster
The following example shows that clus2 has migrated to port e1a on both nodes:
cluster::*> network port show -role cluster clus1 up/up 10.10.10.1/16 node2 e1a true clus2 up/up 10.10.10.2/16 node2 e1a false
Shut down port e2a on both nodes:
network port modify
The following example shows port e2a being shut down on both nodes:
cluster::*> network port modify -node node1 -port e2a -up-admin false cluster::*> network port modify -node node2 -port e2a -up-admin false
Verify that port e2a is shut down on both nodes:
network port show
cluster::*> network port show -role cluster Auto-Negot Duplex Speed (Mbps) Node Port Role Link MTU Admin/Oper Admin/Oper Admin/Oper ------ ------ -------- ---- ----- ----------- ---------- ----------- node1 e1a cluster up 9000 true/true full/full auto/10000 e2a cluster down 9000 true/true full/full auto/10000 node2 e1a cluster up 9000 true/true full/full auto/10000 e2a cluster down 9000 true/true full/full auto/10000
Shut down the ISL ports on cs1, the active NetApp switch.
(cs1) # configure (cs1) (config) # interface 0/13-0/16 (cs1) (interface 0/13-0/16) # shutdown (cs1) (interface 0/13-0/16) # exit (cs1) (config) # exit
Copy the RCF to the switch.
You must set the .scr
extension as part of the file name before invoking the script. This extension is the extension for the FASTPATH operating system.The switch will validate the script automatically as it is downloaded to the switch, and the output will go to the console.
(cs2) # copy tftp://10.10.0.1/CN1610_CS_RCF_v1.1.txt nvram:script CN1610_CS_RCF_v1.1.scr [the script is now displayed line by line] Configuration script validated. File transfer operation completed successfully.
Verify that the script was downloaded and saved with the file name that you gave it.
(cs2) # script list Configuration Script Name Size(Bytes) -------------------------------- ----------- running-config.scr 6960 CN1610_CS_RCF_v1.1.scr 2199 2 configuration script(s) found. 6038 Kbytes free.
Validate the script.
The script is validated during the download to verify that each line is a valid switch command line. (cs2) # script validate CN1610_CS_RCF_v1.1.scr [the script is now displayed line by line] Configuration script 'CN1610_CS_RCF_v1.1.scr' validated.
Apply the script to the switch.
(cs2) #script apply CN1610_CS_RCF_v1.1.scr Are you sure you want to apply the configuration script? (y/n) y [the script is now displayed line by line]... Configuration script 'CN1610_CS_RCF_v1.1.scr' applied.
Verify that your changes have been implemented on the switch.
(cs2) # show running-config
The example displays the
running-config
file on the switch. You must compare the file to the RCF to verify that the parameters that you set are as you expect. -
Save the changes.
Set the
running-config
file to be the standard one.(cs2) # write memory This operation may take a few minutes. Management interfaces will not be available during this time. Are you sure you want to save? (y/n) y Config file 'startup-config' created successfully.
Reboot the switch and verify that the
running-config
file is correct.After the reboot completes, you must log in, view the
running-config
file, and then look for the description on interface 3/64, which is the version label for the RCF.(cs2) # reload The system has unsaved changes. Would you like to save them now? (y/n) y Config file 'startup-config' created successfully. Configuration Saved! System will now restart!
Bring up the ISL ports on cs1, the active switch.
(cs1) # configure (cs1) (config)# interface 0/13-0/16 (cs1) (Interface 0/13-0/16)# no shutdown (cs1) (Interface 0/13-0/16)# exit (cs1) (config)# exit
Verify that the ISLs are operational:
show port-channel 3/1
The Link State field should indicate
Up
.(cs2) # show port-channel 3/1 Local Interface................................ 3/1 Channel Name................................... ISL-LAG Link State..................................... Up Admin Mode..................................... Enabled Type........................................... Static Load Balance Option............................ 7 (Enhanced hashing mode) Mbr Device/ Port Port Ports Timeout Speed Active ------ ------------- --------- ------- 0/13 actor/long 10G Full True partner/long 0/14 actor/long 10G Full True partner/long 0/15 actor/long 10G Full True partner/long 0/16 actor/long 10G Full True partner/long
Bring up cluster port e2a on both nodes:
network port modify
The following example shows port e2a being brought up on node1 and node2:
cluster::*> network port modify -node node1 -port e2a -up-admin true cluster::*> network port modify -node node2 -port e2a -up-admin true
Verify that port e2a is up on both nodes:
cluster::*> network port show -role cluster Auto-Negot Duplex Speed (Mbps) Node Port Role Link MTU Admin/Oper Admin/Oper Admin/Oper ------ ---- -------- ---- ---- ----------- ---------- ------------ node1 e1a cluster up 9000 true/true full/full auto/10000 e2a cluster up 9000 true/true full/full auto/10000 node2 e1a cluster up 9000 true/true full/full auto/10000 e2a cluster up 9000 true/true full/full auto/10000
On both nodes, revert clus2 that is associated with port e2a:
network interface revert
The LIF might revert automatically, depending on your version of ONTAP.
cluster::*> network interface revert -vserver node1 -lif clus2 cluster::*> network interface revert -vserver node2 -lif clus2
Verify that the LIF is now home (
true
) on both nodes:network interface show -role cluster
cluster::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ------- ---------- ---------- -------------- -------- ------- ---- vs1 clus1 up/up 10.10.10.1/24 node1 e1a true clus2 up/up 10.10.10.2/24 node1 e2a true vs2 clus1 up/up 10.10.10.1/24 node2 e1a true clus2 up/up 10.10.10.2/24 node2 e2a true
View the status of the node members:
cluster show
cluster::> cluster show Node Health Eligibility -------------- ------- ------------ node1 true true node2 true true
Copy the
running-config
file to thestartup-config
file when you are satisfied with the software versions and switch settings.(cs2) # write memory This operation may take a few minutes. Management interfaces will not be available during this time. Are you sure you want to save? (y/n) y Config file 'startup-config' created successfully. Configuration Saved!
Repeat step 1 through step 22 to upgrade the RCF on the other switch, cs1.
Related information
