Install FASTPATH software
When you install the FASTPATH software on your NetApp switches, you must begin the upgrade with the second switch, cs2.
If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all - message MAINT=xh
x is the duration of the maintenance window in hours.
The AutoSupport message notifies technical support of this maintenance task so that automatic case creation is suppressed during the maintenance window. -
Log into the switch as admin. There is no password by default. At the
(cs2) #
prompt, enter theenable
command. Again, there is no password by default. This gives you access to Privileged EXEC mode, which allows you to configure the network interface.(cs2) # enable Password (Enter) (cs2) #
On the console of each node, migrate clus2 to port e1a:
network interface migrate
cluster::*> network interface migrate -vserver vs1 -lif clus2 -source-node node1 -destnode node1 -dest-port e1a cluster::*> network interface migrate -vserver vs2 -lif clus2 -source-node node2 -destnode node2 -dest-port e1a
On the console of each node, verify that the migration took place:
network interface show
The following example shows that clus2 has migrated to port e1a on both nodes:
cluster::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Open Address/Mask Node Port Home -------- ---------- ---------- -------------- -------- ------- ---- vs1 clus1 up/up 10.10.10.1/16 node1 e1a true clus2 up/up 10.10.10.2/16 node1 e1a false vs2 clus1 up/up 10.10.10.1/16 node2 e1a true clus2 up/up 10.10.10.2/16 node2 e1a false
Shut down cluster port e2a on both nodes:
network port modify
The following example shows port e2a being shut down on both nodes:
cluster::*> network port modify -node node1 -port e2a -up-admin false cluster::*> network port modify -node node2 -port e2a -up-admin false
Verify that port e2a is shut down on both nodes:
network port show
cluster::*> network port show -role cluster Auto-Negot Duplex Speed (Mbps) Node Port Role Link MTU Admin/Oper Admin/Oper Admin/Oper ------ ---- -------- ---- ----- ---------- ---------- ------------ node1 e1a cluster up 9000 true/true full/full auto/10000 e2a cluster down 9000 true/true full/full auto/10000 node2 e1a cluster up 9000 true/true full/full auto/10000 e2a cluster down 9000 true/true full/full auto/10000
Shut down the Inter-Switch Link (ISL) ports on cs1, the active NetApp switch:
(cs1) # configure (cs1)(config) # interface 0/13-0/16 (cs1)(Interface 0/13-0/16) # shutdown (cs1)(Interface 0/13-0/16) # exit (cs1)(config) # exit
Back up the current active image on cs2.
(cs2) # show bootvar Image Descriptions . active: backup: Images currently available on Flash ---------------------------------------------------------------------- unit active backup current-active next-active ---------------------------------------------------------------------- 1 1.1.0.3 1.1.0.1 1.1.0.3 1.1.0.3 (cs2) # copy active backup Copying active to backup Copy operation successful (cs2) #
Download the image file to the switch.
Copying the image file to the active image means that when you reboot, that image establishes the running FASTPATH version. The previous image remains available as a backup.
(cs2) # copy tftp://10.0.0.1/NetApp_CN1610_1.1.0.5.stk active Mode...................................... TFTP Set Server IP............................. 10.0.0.1 Path...................................... ./ Filename.................................. NetApp_CN1610_1.1.0.5.stk Data Type................................. Code Destination Filename...................... active Management access will be blocked for the duration of the transfer Are you sure you want to start? (y/n) y TFTP Code transfer starting... File transfer operation completed successfully.
Verify the running version of the FASTPATH software.
(cs2) # show version Switch: 1 System Description.................. Broadcom Scorpion 56820 Development System - 16 TENGIG, 1.1.0.3, Linux 2.6.21.7 Machine Type........................ Broadcom Scorpion 56820 Development System - 16TENGIG Machine Model....................... BCM-56820 Serial Number....................... 10611100004 FRU Number.......................... Part Number......................... BCM56820 Maintenance Level................... A Manufacturer........................ 0xbc00 Burned In MAC Address............... 00:A0:98:4B:A9:AA Software Version.................... 1.1.0.3 Operating System.................... Linux 2.6.21.7 Network Processing Device........... BCM56820_B0 Additional Packages................. FASTPATH QOS FASTPATH IPv6 Management
View the boot images for the active and backup configuration.
(cs2) # show bootvar Image Descriptions active : backup : Images currently available on Flash ---------------------------------------------------------------------- unit active backup current-active next-active ---------------------------------------------------------------------- 1 1.1.0.3 1.1.0.3 1.1.0.3 1.1.0.5
Reboot the switch.
(cs2) # reload Are you sure you would like to reset the system? (y/n) y System will now restart!
Log in again, and verify the new version of the FASTPATH software.
(cs2) # show version Switch: 1 System Description................... Broadcom Scorpion 56820 Development System - 16 TENGIG, 1.1.0.5, Linux 2.6.21.7 Machine Type......................... Broadcom Scorpion 56820 Development System - 16TENGIG Machine Model........................ BCM-56820 Serial Number........................ 10611100004 FRU Number........................... Part Number.......................... BCM56820 Maintenance Level.................... A Manufacturer......................... 0xbc00 Burned In MAC Address................ 00:A0:98:4B:A9:AA Software Version..................... 1.1.0.5 Operating System..................... Linux 2.6.21.7 Network Processing Device............ BCM56820_B0 Additional Packages.................. FASTPATH QOS FASTPATH IPv6 Management
Bring up the ISL ports on cs1, the active switch.
(cs1) # configure (cs1) (config) # interface 0/13-0/16 (cs1) (Interface 0/13-0/16) # no shutdown (cs1) (Interface 0/13-0/16) # exit (cs1) (config) # exit
Verify that the ISLs are operational:
show port-channel 3/1
The Link State field should indicate
Up
.(cs2) # show port-channel 3/1 Local Interface................................ 3/1 Channel Name................................... ISL-LAG Link State..................................... Up Admin Mode..................................... Enabled Type........................................... Static Load Balance Option............................ 7 (Enhanced hashing mode) Mbr Device/ Port Port Ports Timeout Speed Active ------ ------------- --------- ------- 0/13 actor/long 10G Full True partner/long 0/14 actor/long 10G Full True partner/long 0/15 actor/long 10G Full True partner/long 0/16 actor/long 10G Full True partner/long
Copy the
running-config
file to thestartup-config
file when you are satisfied with the software versions and switch settings.(cs2) # write memory This operation may take a few minutes. Management interfaces will not be available during this time. Are you sure you want to save? (y/n) y Config file 'startup-config' created successfully . Configuration Saved!
Enable the second cluster port, e2a, on each node:
network port modify
cluster::*> network port modify -node node1 -port e2a -up-admin true cluster::*> **network port modify -node node2 -port e2a -up-admin true**
Revert clus2 that is associated with port e2a:
network interface revert
The LIF might revert automatically, depending on your version of ONTAP software.
cluster::*> network interface revert -vserver Cluster -lif n1_clus2 cluster::*> network interface revert -vserver Cluster -lif n2_clus2
Verify that the LIF is now home (
true
) on both nodes:network interface show -role cluster
cluster::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home -------- ---------- ---------- -------------- -------- ------- ---- vs1 clus1 up/up 10.10.10.1/24 node1 e1a true clus2 up/up 10.10.10.2/24 node1 e2a true vs2 clus1 up/up 10.10.10.1/24 node2 e1a true clus2 up/up 10.10.10.2/24 node2 e2a true
View the status of the nodes:
cluster show
cluster::> cluster show Node Health Eligibility -------------------- ------- ------------ node1 true true node2 true true
Repeat step 1 through step 18 to upgrade the FASTPATH software on the other switch, cs1.
If you suppressed automatic case creation, re-enable it by invoking an AutoSupport message:
