Review configuration requirements for NVIDIA SN2100 storage switches
Review the configuration requirements for NVIDIA SN2100 storage switches before installation or upgrade.
Installation requirements
If you want to build ONTAP clusters with more than two nodes, you need two supported cluster network switches. You can use additional management switches, which are optional.
You install the NVIDIA SN2100 switch (X190006/X190106) in the NVIDIA dual/single switch cabinet with the standard brackets that are included with the switch.
For cabling guidelines, refer to Cabling and configuration considerations.
ONTAP and Linux support
The NVIDIA SN2100 switch is a 10/25/40/100 Gb Ethernet switch running Cumulus Linux. The switch supports the following:
ONTAP 9.10.1P3. The SN2100 switch serves Cluster and Storage applications in ONTAP 9.10.1P3 over different switch-pairs. From ONTAP 9.10.1P3, you can use NVIDIA SN2100 switches to combine storage and cluster functionality into a shared switch configuration.
Cumulus Linux (CL) OS version 4.4.3. For current compatibility information, refer to NVIDIA Ethernet Switches.
You can install Cumulus Linux when the switch is running Cumulus Linux or ONIE.
After you've reviewed the configuration requirements, you can confirm your components and part numbers.
