Install Cumulus Linux in Cumulus mode
Contributors netapp-yvonneo
Cumulus Linux (CL) OS can be installed either when the switch is running Cumulus Linux or ONIE.
Before you begin
The following assumptions are made:
  • You have intermediate-level Linux knowledge.
  • You are familiar with basic text editing, UNIX file permissions, and process monitoring. A variety of text editors are pre-installed, including vi and nano.
  • You must have access to a Linux or UNIX shell. If you are running Windows, use a Linux environment as your command line tool for interacting with Cumulus Linux.
Note Each time Cumulus Linux is installed, the entire file system structure is erased and rebuilt.
Caution The default password for the cumulus user account is cumulus. The first time you log into Cumulus Linux, you must change this default password. Be sure to update any automation scripts before installing a new image. Cumulus Linux provides command line options to change the default password automatically during the installation process.
The baud rate requirement must be set to 115200 on the serial console switch for NVIDIA SN2100 switch console access, as follows:
  • 115200 baud
  • 8 data bits
  • 1 stop bit
  • parity: none
  • flow control: none
Steps
  1. Log in to the switch. First time log in to the switch requires username/password of cumulus/cumulus with sudo privileges:
    cumulus login: cumulus
    Password: cumulus
    You are required to change your password immediately (administrator enforced)
    Changing password for cumulus.
    Current password: cumulus
    New password: netapp1!
    Retype new password: netapp1!
  2. Check the Cumulus Linux version:
    cumulus@cumulus:mgmt:~$ net show system
    Hostname......... cumulus
    Build............ Cumulus Linux 4.4.2
    Uptime........... 0:08:20.860000
    Model............ Mlnx X86
    CPU.............. x86_64 Intel Atom C2558 2.40GHz
    Memory........... 8GB
    Disk............. 14.7GB
    ASIC............. Mellanox Spectrum MT52132
    Ports............ 16 x 100G-QSFP28
    Part Number...... MSN2100-CB2FC
    Serial Number.... MT2105T05177
    Platform Name.... x86_64-mlnx_x86-r0
    Product Name..... MSN2100
    ONIE Version..... 2019.11-5.2.0020-115200
    Base MAC Address. 04:3F:72:43:92:80
    Manufacturer..... Mellanox
  3. Configure the hostname, IP address, subnet mask, and default gateway. The new hostname only becomes effective after restarting the console/SSH session.
    Note A Cumulus Linux switch provides at least one dedicated Ethernet management port called eth0. This interface is specifically for out-of-band management use. By default, the management interface uses DHCPv4 for addressing.
    Caution Do not use an underscore (_), apostrophe ('), or non-ASCII characters in the hostname.
    cumulus@cumulus:mgmt:~$ net add hostname sw1
    cumulus@cumulus:mgmt:~$ net add interface eth0 ip address 10.233.204.71
    cumulus@cumulus:mgmt:~$ net add interface eth0 ip gateway 10.233.204.1
    cumulus@cumulus:mgmt:~$ net pending
    cumulus@cumulus:mgmt:~$ net commit
    This command modifies both the /etc/hostname and /etc/hosts files.
  4. Confirm that the hostname, IP address, subnet mask, and default gateway have been updated:
    cumulus@sw1:mgmt:~$ hostname sw1
    cumulus@sw1:mgmt:~$ ifconfig eth0
    eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
    inet 10.233.204.71  netmask 255.255.254.0  broadcast 10.233.205.255
    inet6 fe80::bace:f6ff:fe19:1df6  prefixlen 64  scopeid 0x20<link>
    ether b8:ce:f6:19:1d:f6  txqueuelen 1000  (Ethernet)
    RX packets 75364  bytes 23013528 (21.9 MiB)
    RX errors 0  dropped 7  overruns 0  frame 0
    TX packets 4053  bytes 827280 (807.8 KiB)
    TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0 device memory 0xdfc00000-dfc1ffff
    cumulus@sw1::mgmt:~$ ip route show vrf mgmt
    default via 10.233.204.1 dev eth0
    unreachable default metric 4278198272
    10.233.204.0/23 dev eth0 proto kernel scope link src 10.233.204.71
    127.0.0.0/8 dev mgmt proto kernel scope link src 127.0.0.1
  5. Configure the time zone using NTP interactive mode.
    1. On a terminal, run the following command:
      cumulus@sw1:~$ sudo dpkg-reconfigure tzdata
    2. Follow the on-screen menu options to select the geographic area and region.
    3. To set the time zone for all services and daemons, reboot the switch.
    4. Verify that the date and time on the switch are correct and update if necessary.
  6. Install Cumulus Linux 4.4.2:
    cumulus@sw1:mgmt:~$ sudo onie-install -a -i http://<web-server>/<path>/cumulus-linux-4.4.2-mlx-amd64.bin
    The installer starts the download. Type y when prompted.
  7. Reboot the NVIDIA SN2100 switch:
    cumulus@sw1:mgmt:~$ sudo reboot
  8. The installation starts automatically, and the following GRUB screens appear. Do not make any selections:
    • Cumulus-Linux GNU/Linux
    • ONIE: Install OS
    • CUMULUS-INSTALL
  9. Repeat steps 1 to 4 to log in.
  10. Verify that the Cumulus Linux version is 4.4.2:
    cumulus@sw1:mgmt:~$ net show version
    NCLU_VERSION=1.0-cl4.4.2u0
    DISTRIB_ID="Cumulus Linux"
    DISTRIB_RELEASE=4.4.2
    DISTRIB_DESCRIPTION="Cumulus Linux 4.4.2"
  11. Create a new user and add this user to the sudo group. This user only becomes effective after the console/SSH session is restarted:
    cumulus@sw1:mgmt:~$ sudo adduser --ingroup netedit admin
    [sudo] password for cumulus:
    Adding user `admin’ ...
    Adding new user `admin’ (1001) with group `netedit' ...
    Creating home directory `/home/admin’ ...
    Copying files from `/etc/skel' ...
    New password:
    passwd: password updated successfully
    Changing the user information for admin
    Enter the new value, or press ENTER for the default
    Full Name []:
    Room Number []:
    Work Phone []:
    Home Phone []:
    Other []:
    Is the information correct? [Y/n] y
    cumulus@sw1:mgmt:~$ sudo adduser admin sudo
    Adding user `admin' to group `sudo' ...
    Adding user admin to group sudo
    Done.
    cumulus@sw1:mgmt:~$ exit
    logout
    Connection to 10.233.204.71 closed.
    [admin@cycrh6svl01 ~]$ ssh admin@10.233.204.71
    admin@10.233.204.71's password:
    Linux sw1 4.19.0-cl-1-amd64 #1 SMP Cumulus 4.19.206-1+cl4.4.2u1 (2021-09-09) x86_64
    Welcome to NVIDIA Cumulus (R) Linux (R)
    For support and online technical documentation, visit
    http://www.cumulusnetworks.com/support
    The registered trademark Linux (R) is used pursuant to a sublicense from LMI, the exclusive licensee of Linus Torvalds, owner of the mark on a world-wide basis.
    admin@sw1:mgmt:~$
