Migrate from a Cisco storage switch to a NVIDIA SN2100 storage switch
Contributors netapp-yvonneo
You must be aware of certain configuration information, port connections and cabling requirements when you are replacing some older Cisco switches with NVIDIA SN2100 storage switches.
  • The following storage switches are supported:
    • Cisco Nexus 9336C-FX2
    • Cisco Nexus 3232C
  • See the Hardware Universe for full details of supported ports and their configurations.
Before you begin
You can migrate nondisruptively older Cisco storage switches for an ONTAP cluster to NVIDIA SN2100 storage switches.
  • The existing cluster must be properly set up and functioning.
  • All storage ports must be in the up state to ensure nondisruptive operations.
  • The NVIDIA SN2100 storage switches must be configured and operating under the proper version of Cumulus Linux installed with the reference configuration file (RCF) applied.
  • The existing storage network configuration must have the following:
    • A redundant and fully functional NetApp cluster using both older Cisco switches.
    • Management connectivity and console access to both the older Cisco switches and the new switches.
    • All cluster LIFs in the up state with the cluster LIfs are on their home ports.
    • ISL ports enabled and cabled between the older Cisco switches and between the new switches.
  • You have configured some of the ports on NVIDIA SN2100 switches to run at 100 GbE.
  • You have planned, migrated, and documented 100 GbE connectivity from nodes to NVIDIA SN2100 storage switches.
    Note In this procedure, Cisco Nexus 9336C-FX2 storage switches are used for example commands and outputs.
About this task
The examples in this procedure use the following switch and node nomenclature:
  • The existing Cisco Nexus 9336C-FX2 storage switches are S1 and S2.
  • The new NVIDIA SN2100 storage switches are sw1 and sw2.
  • The nodes are node1 and node2.
  • The cluster LIFs are node1_clus1 and node1_clus2 on node 1, and node2_clus1 and node2_clus2 on node 2 respectively.
  • The cluster1::*> prompt indicates the name of the cluster.
  • The network ports used in this procedure are e5a and e5b.
  • Breakout ports take the format: swp1s0-3. For example four breakout ports on swp1 are swp1s0, swp1s1, swp1s2, and swp1s3.
  • Switch S2 is replaced by switch sw2 first and then switch S1 is replaced by switch sw1.
    • Cabling between the nodes and S2 are then disconnected from S2 and reconnected to sw2.
    • Cabling between the nodes and S1 are then disconnected from S1 and reconnected to sw1.
Steps
  1. If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message: system node autosupport invoke -node * -type all -message MAINT=xh
    where x is the duration of the maintenance window in hours.
  2. Change the privilege level to advanced, entering y when prompted to continue: set -privilege advanced
    The advanced prompt (*>) appears.
  3. Determine the administrative or operational status for each storage interface:
    Each port should display enabled for Status.
    Display the network port attributes: storage port show
    cluster1::*> storage port show
                                      Speed                     VLAN
    Node           Port Type  Mode    (Gb/s) State    Status      ID
    node1
                   e0c  ENET  storage  100   enabled  online      30
                   e0d  ENET  storage    0   enabled  offline     30
                   e5a  ENET  storage    0   enabled  offline     30
                   e5b  ENET  storage  100   enabled  online      30
    node2
    cluster1::*>
  4. The storage ports on each node are connected to existing storage switches in the following way (from the nodes' perspective) using the command: network device-discovery show -protocol lldp
    cluster1::*> network device-discovery show -protocol lldp
    Node/       Local  Discovered
    Protocol    Port   Device (LLDP: ChassisID)  Interface       Platform
    node1      /lldp
                e0c    S1 (7c:ad:4f:98:6d:f0)    Eth1/1           -
                e5b    S2 (7c:ad:4f:98:8e:3c)    Eth1/1           -
    node2      /lldp
                e0c    S1 (7c:ad:4f:98:6d:f0)    Eth1/2           -
                e5b    S2 (7c:ad:4f:98:8e:3c)    Eth1/2           -
  5. On switch S1 and S2, the storage ports and switches are connected in the following way (from the switches' perspective) using the command: show lldp neighbors
    S1# show lldp neighbors
    Capability Codes: (R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device,
                      (W) WLAN Access Point, (P) Repeater, (S) Station (O) Other
    Device-ID             Local Intf     Holdtime    Capability           Port ID
    node1                 Eth1/1         121         S                    e0c
    node2                 Eth1/2         121         S                    e0c
    SHFGD1947000186       Eth1/10        120         S                    e0a
    SHFGD1947000186       Eth1/11        120         S                    e0a
    SHFGB2017000269       Eth1/12        120         S                    e0a
    SHFGB2017000269       Eth1/13        120         S                    e0a
    S2# show lldp neighbors
    node1                 Eth1/1         121         S                   e5b
    node2                 Eth1/2         121         S                   e5b
    SHFGD1947000186       Eth1/10        120         S                   e0b
    SHFGD1947000186       Eth1/11        120         S                   e0b
    SHFGB2017000269       Eth1/12        120         S                   e0b
    SHFGB2017000269       Eth1/13        120         S                   e0b
  6. On switch sw2, shut down the ports connected to the storage ports and nodes of the disk shelves.
    cumulus@sw2:~$ net add interface swp1-16 link down
    cumulus@sw2:~$ net pending
    cumulus@sw2:~$ net commit
  7. Move the node storage ports of the controller and disk shelves from the old switch S2 to the new switch sw2, using appropriate cabling supported by NVIDIA SN2100.
  8. On switch sw2, bring up the ports connected to the storage ports of the nodes and the disk shelves.
    cumulus@sw2:~$ net del interface swp1-16 link down
  9. The storage ports on each node are now connected to the switches in the following way, from the nodes' perspective:
    node1      /lldp
                e5b    sw2 (b8:ce:f6:19:1a:7e)   swp1           -
    node2      /lldp
                e5b    sw2 (b8:ce:f6:19:1a:7e)   swp2           -
  10. Verify the network port attributes: storage port show
                                      Speed                     VLAN
    node1
    node2
    cluster1::*>
  11. On switch sw2, verify that all node storage ports are up:
    cumulus@sw2:~$ net show interface
    State  Name    Spd   MTU    Mode        LLDP                  Summary
    UP     swp1    100G  9216   Trunk/L2   node1 (e5b)             Master: bridge(UP)
    UP     swp2    100G  9216   Trunk/L2   node2 (e5b)             Master: bridge(UP)
    UP     swp3    100G  9216   Trunk/L2   SHFFG1826000112 (e0b)   Master: bridge(UP)
    UP     swp4    100G  9216   Trunk/L2   SHFFG1826000112 (e0b)   Master: bridge(UP)
    UP     swp5    100G  9216   Trunk/L2   SHFFG1826000102 (e0b)   Master: bridge(UP)
    UP     swp6    100G  9216   Trunk/L2   SHFFG1826000102 (e0b)   Master: bridge(UP))
  12. On switch sw1, shut down the ports connected to the storage ports of the nodes and the disk shelves.
    cumulus@sw1:~$ net add interface swp1-16 link down
    cumulus@sw1:~$ net pending
    cumulus@sw1:~$ net commit
  13. Move the node storage ports of the controller and the disk shelves from the old switch S1 to the new switch sw1, using appropriate cabling supported by NVIDIA SN2100.
  14. On switch sw1, bring up the ports connected to the storage ports of the nodes and the disk shelves.
    cumulus@sw1:~$ net del interface swp1-16 link down
  15. The storage ports on each node are now connected to the switches in the following way, from the nodes' perspective:
    node1      /lldp
                e0c    sw1 (b8:ce:f6:19:1b:96)   swp1            -
    node2      /lldp
                e0c    sw1  (b8:ce:f6:19:1b:96)  swp2            -
  16. Verify the final configuration: storage port show
    Each port should display enabled for State and enabled for Status.
                                      Speed                     VLAN
    node1
    node2
    cluster1::*>
  17. On switch sw2, verify that all node storage ports are up:
  18. Verify that both nodes each have one connection to each switch: net show lldp
    The following example shows the appropriate results for both switches:
    cumulus@sw1:~$ net show lldp
    LocalPort  Speed  Mode      RemoteHost             RemotePort
    swp1       100G   Trunk/L2  node1                  e0c
    swp2       100G   Trunk/L2  node2                  e0c
    swp3       100G   Trunk/L2  SHFFG1826000112        e0a
    swp4       100G   Trunk/L2  SHFFG1826000112        e0a
    swp5       100G   Trunk/L2  SHFFG1826000102        e0a
    swp6       100G   Trunk/L2  SHFFG1826000102        e0a
    cumulus@sw2:~$ net show lldp
    swp1       100G   Trunk/L2  node1                  e5b
    swp2       100G   Trunk/L2  node2                  e5b
    swp3       100G   Trunk/L2  SHFFG1826000112        e0b
    swp4       100G   Trunk/L2  SHFFG1826000112        e0b
    swp5       100G   Trunk/L2  SHFFG1826000102        e0b
    swp6       100G   Trunk/L2  SHFFG1826000102        e0b
  19. Enable the Ethernet switch health monitor log collection feature for collecting switch-related log files, using the two commands: system switch ethernet log setup-password and system switch ethernet log enable-collection
    Enter: system switch ethernet log setup-password
    cluster1::*> system switch ethernet log setup-password
    Enter the switch name: <return>
    The switch name entered is not recognized.
    Choose from the following list:
    sw1
    sw2
    Enter the switch name: sw1
    RSA key fingerprint is e5:8b:c6:dc:e2:18:18:09:36:63:d9:63:dd:03:d9:cc
    Do you want to continue? {y|n}::[n] y
    Enter the password: <enter switch password>
    Enter the password again: <enter switch password>
    Enter the switch name: sw2
    RSA key fingerprint is 57:49:86:a1:b9:80:6a:61:9a:86:8e:3c:e3:b7:1f:b1
    Do you want to continue? {y|n}:: [n] y
    Followed by: system switch ethernet log enable-collection
    cluster1::*> system  switch ethernet log enable-collection
    Do you want to enable cluster log collection for all nodes in the cluster?
    {y|n}: [n] y
    Enabling cluster switch log collection.
    cluster1::*>
    Note If any of these commands return an error, contact NetApp support.
  20. Initiate the switch log collection feature: system switch ethernet log collect -device *
    Wait for 10 minutes and then check that the log collection was successful using the command: system switch ethernet log show
    cluster1::*> system switch ethernet log show
    Log Collection Enabled: true
    Index  Switch                       Log Timestamp        Status
    1      sw1 (b8:ce:f6:19:1b:42)      4/29/2022 03:05:25   complete
    2      sw2 (b8:ce:f6:19:1b:96)      4/29/2022 03:07:42   complete
  21. Change the privilege level back to admin: set -privilege admin
  22. If you suppressed automatic case creation, reenable it by invoking an AutoSupport message: system node autosupport invoke -node * -type all -message MAINT=END
