Replace a NVIDIA SN2100 storage switch
Contributors netapp-yvonneo
You must be aware of certain configuration information, port connections and cabling requirements when you replace NVIDIA SN2100 storage switches.
Before you begin
You must verify that the following conditions exist before installing the Cumulus software and RCFs on a NVIDIA SN2100 storage switch:
  • Your system can support NVIDIA SN2100 storage switches.
  • You must have downloaded the applicable RCFs.
  • The Hardware Universe provides full details of supported ports and their configurations.
About this task
The existing network configuration must have the following characteristics:
  • Ensure that all troubleshooting steps have been completed to confirm that your switch needs replacing.
  • Management connectivity must exist on both switches.
    Note Make sure that all troubleshooting steps have been completed to confirm that your switch needs replacing.
The replacement NVIDIA SN2100 switch must have the following characteristics:
  • Management network connectivity must be functional.
  • Console access to the replacement switch must be in place.
  • The appropriate RCF and Cumulus operating system image must be loaded onto the switch.
  • Initial customization of the switch must be complete.
Procedure summary
This procedure replaces the second NVIDIA SN2100 storage switch sw2 with the new NVIDIA SN2100 switch nsw2. The two nodes are node1 and node2.
Steps to complete:
  • Confirm the switch to be replaced is sw2.
  • Disconnect the cables from switch sw2.
  • Reconnect the cables to switch nsw2.
  • Verify all device configurations on switch nsw2.
Steps
  1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message: system node autosupport invoke -node * -type all - message MAINT=xh
    x is the duration of the maintenance window in hours.
  2. Change the privilege level to advanced, entering y when prompted to continue: set -privilege advanced
  3. Check on the health status of the storage node ports to make sure that there is connection to storage switch S1:
    storage port show -port-type ENET
    cluster1::*> storage port show -port-type ENET
                                      Speed                     VLAN
    Node           Port Type  Mode    (Gb/s) State    Status      ID
    node1
                   e3a  ENET  storage 100    enabled  online      30
                   e3b  ENET  storage   0    enabled  offline     30
                   e7a  ENET  storage   0    enabled  offline     30
                   e7b  ENET  storage 100    enabled  online      30
    node2
    cluster1::*>
  4. Verify that storage switch sw1 is available: network device-discovery show
    cluster1::*> network device-discovery show protocol lldp
    Node/      Local Discovered
    Protocol   Port	 Device (LLDP: ChassisID)  Interface   Platform
    node1/lldp
               e3a   sw1 (b8:ce:f6:19:1b:42)   swp3        -
    node2/lldp
               e3a   sw1 (b8:ce:f6:19:1b:42)   swp4        -
    cluster1::*>
  5. Run the net show interface command on the working switch to confirm that you can see both nodes and all shelves: net show interface
    cumulus@sw1:~$ net show interface
    State  Name    Spd   MTU    Mode        LLDP                  Summary
    UP     swp1    100G  9216   Trunk/L2   node1 (e3a)             Master: bridge(UP)
    UP     swp2    100G  9216   Trunk/L2   node2 (e3a)             Master: bridge(UP)
    UP     swp3    100G  9216   Trunk/L2   SHFFG1826000112 (e0b)   Master: bridge(UP)
    UP     swp4    100G  9216   Trunk/L2   SHFFG1826000112 (e0b)   Master: bridge(UP)
    UP     swp5    100G  9216   Trunk/L2   SHFFG1826000102 (e0b)   Master: bridge(UP)
    UP     swp6    100G  9216   Trunk/L2   SHFFG1826000102 (e0b)   Master: bridge(UP))
  6. Verify the shelf ports in the storage system: storage shelf port show -fields remote-device, remote-port
    cluster1::*> storage shelf port show -fields remote-device, remote-port
    shelf   id  remote-port   remote-device
    3.20    0   swp3          sw1
    3.20    1   -             -
    3.20    2   swp4          sw1
    3.20    3   -             -
    3.30    0   swp5          sw1
    3.20    1   -             -
    3.30    2   swp6          sw1
    3.20    3   -             -
    cluster1::*>
  7. Remove all cables attached to storage switch sw2.
  8. Reconnect all cables to the replacement switch nsw2.
  9. Recheck the health status of the storage node ports: storage port show -port-type ENET
                                        Speed                     VLAN
    node1
    node2
    cluster1::*>
  10. Verify that both switches are available: net device-discovery show
    node1/lldp
              e3a  sw1 (b8:ce:f6:19:1b:96)    swp1        -
              e7b  nsw2 (b8:ce:f6:19:1a:7e)   swp1        -
    node2/lldp
              e3a  sw1 (b8:ce:f6:19:1b:96)    swp2        -
              e7b  nsw2 (b8:ce:f6:19:1a:7e)   swp2        -
    cluster1::*>
  11. Verify the shelf ports in the storage system: storage shelf port show -fields remote-device, remote-port
    3.20    0     swp3            sw1
    3.20    1     swp3            nsw2
    3.20    2     swp4            sw1
    3.20    3     swp4            nsw2
    3.30    0     swp5            sw1
    3.20    1     swp5            nsw2
    3.30    2     swp6            sw1
    3.20    3     swp6            nsw2
    cluster1::*>
  12. Enable the Ethernet switch health monitor log collection feature for collecting switch-related log files, using the two commands: system switch ethernet log setup-password and system switch ethernet log enable-collection
    Enter: system switch ethernet log setup-password
    cluster1::*> system switch ethernet log setup-password
    Enter the switch name: <return>
    The switch name entered is not recognized.
    Choose from the following list:
    sw1
    nsw2
    Enter the switch name: sw1
    RSA key fingerprint is e5:8b:c6:dc:e2:18:18:09:36:63:d9:63:dd:03:d9:cc
    Do you want to continue? {y|n}::[n] y
    Enter the password: <enter switch password>
    Enter the password again: <enter switch password>
    Enter the switch name: nsw2
    RSA key fingerprint is 57:49:86:a1:b9:80:6a:61:9a:86:8e:3c:e3:b7:1f:b1
    Do you want to continue? {y|n}:: [n] y
    Followed by: system switch ethernet log enable-collection
    cluster1::*> system  switch ethernet log enable-collection
    Do you want to enable cluster log collection for all nodes in the cluster?
    {y|n}: [n] y
    Enabling cluster switch log collection.
    cluster1::*>
    Note If any of these commands return an error, contact NetApp support.
  13. Initiate the switch log collection feature: system switch ethernet log collect -device *
    Wait for 10 minutes and then check that the log collection was successful using the command: system switch ethernet log show
    cluster1::*> system switch ethernet log show
    Log Collection Enabled: true
    Index  Switch                       Log Timestamp        Status
    1      sw1 (b8:ce:f6:19:1b:42)      4/29/2022 03:05:25   complete
    2      nsw2 (b8:ce:f6:19:1b:96)     4/29/2022 03:07:42   complete
  14. Change the privilege level back to admin: set -privilege admin
  15. If you suppressed automatic case creation, re-enable it by invoking an AutoSupport message: system node autosupport invoke -node * -type all -message MAINT=END
