• Upgrade by using ARL
    • Use "system controller replace" commands to upgrade controller hardware introduced in ONTAP 9.15.1 and later
      • Stage 1. Prepare for upgrade
      • Stage 2. Relocate and retire node1
      • Stage 3. Install and boot node3
      • Stage 4. Relocate and retire node2
      • Stage 5. Install and boot node4
      • Stage 6. Complete the upgrade
      • Troubleshoot
    • Use "system controller replace" commands to upgrade controller models in the same chassis
      • Stage 2. Relocate resources and retire node1
        • Replace the node1 system modules
      • Stage 3. Boot node1 with the replacement system modules
      • Stage 4. Relocate resources and retire node2
      • Stage 5. Install the replacement system modules on node2
        • Install the replacement system modules on node2
      • Stage 6. Boot node2 with the replacement system modules
      • Stage 7. Complete the upgrade
      • Troubleshoot
    • Use "system controller replace" commands to upgrade controller hardware running ONTAP 9.8 or later
      • Troubleshoot
    • Use "system controller replace" commands to upgrade controller hardware running ONTAP 9.5 to 9.7
      • Troubleshoot
    • Manually upgrade controller hardware running ONTAP 9.8 or later
      • Stage 4. Record information and retire node2
      • Troubleshoot
    • Manually upgrade controller hardware running ONTAP 9.7 or earlier
      • Reconfigure the FC switch layout for ONTAP 9.1 or later
      • Troubleshoot
  • Upgrade by moving volumes or storage
    • Upgrade by moving storage
      • Optional - Move internal storage or convert to drive shelf
      • Complete upgrade
        • Complete in ONTAP 9.8 or later
        • Complete in ONTAP 9.7 or earlier
    • Upgrade AFF A250 to AFF A400
    • Upgrade from FAS2820
