Decommission the old system
Contributors netapp-aoife netapp-pcarriga netapp-aherbin
After upgrading, you can decommission the old system through the NetApp Support Site. Decommissioning the system tells NetApp that the system is no longer in operation and removes it from support databases.
Steps
  1. Refer to References to link to the NetApp Support Site and log in.
  2. Select Products > My Products from the menu.
  3. On the View Installed Systems page, choose which Selection Criteria you want to use to display information about your system.
    You can choose one of the following to locate your system:
    • Serial Number (located on the back of the unit)
    • Serial Numbers for My Location
  4. Select Go!
    A table displays cluster information, including the serial numbers.
  5. Locate the cluster in the table and select Decommission this system from the Product Tool Set drop-down menu.
What's next?
After decommissioning the old system, resume SnapMirror operations.
