Boot node1 with the replacement system modules
Node1 with the replacement modules is now ready to boot. The supported replacement modules are listed in the supported systems matrix.
When replacing controller modules, move all connections from the old to the replacement controller module. When replacing the controller and NVRAM modules, move only the console and management connections. |
(AFF A250, AFF C250, AFF A800, or AFF C800 upgrade only) At the LOADER prompt, enter maintenance mode:
boot_ontap maint-
Answer
yto the mixed platform confirmation prompt. -
Answer
yesto the confirmation prompt. -
Show the state of the 100GbE interfaces:
storage port show.All 100GbE ports connected to NS224 shelves or storage switches should report as
storageports, as shown in the example output below.*> storage port show Port Type Mode Speed(Gb/s) State Status VLAN ID ---- ---- ------- ----------- -------- ------- ------- e8a ENET storage 100 Gb/s enabled online 30 e8b ENET storage 100 Gb/s enabled online 30 e11a ENET storage 100 Gb/s enabled online 30 e11b ENET storage 100 Gb/s enabled online 30
Exit maintenance mode:
halt
If you have NetApp Storage Encryption (NSE) drives installed, perform the following steps:
If you have not already done so earlier in the procedure, see the Knowledge Base article How to tell if a drive is FIPS certified to determine the type of self-encrypting drives that are in use. -
Set
bootarg.storageencryption.supporttotrueorfalse:If the following drives are in use… Then… NSE drives that conform to FIPS 140-2 Level 2 self-encryption requirements
setenv bootarg.storageencryption.support trueNetApp non-FIPS SEDs
setenv bootarg.storageencryption.support falseYou cannot mix FIPS drives with other types of drives on the same node or HA pair.
You can mix SEDs with non-encrypting drives on the same node or HA pair. -
Go to the special boot menu and select option
(10) Set Onboard Key Manager recovery secrets.Enter the passphrase and the backup information that you recorded earlier in the procedure. See Manage storage encryption using the Onboard Key Manager.
Boot the node into the boot menu:
boot_ontap menu -
When the node stops at the boot menu, reassign the old node1 disks to the replacement node1 by running the following command on node1:
boot_after_controller_replacementAfter a short delay, you are prompted to enter the name of the node that is being replaced. If there are shared disks (also called Advanced Disk Partitioning (ADP) or partitioned disks), you are prompted to enter the node name of the HA partner.
These prompts might get buried in the console messages. If you do not enter a node name or enter an incorrect name, you are prompted to enter the name again.
If
[localhost:disk.encryptNoSupport:ALERT]: Detected FIPS-certified encrypting driveand, or,[localhost:diskown.errorDuringIO:error]: error 3 (disk failed) on diskerrors occur, perform the following steps:-
Halt the node at the LOADER prompt.
Check and reset the storage encryption bootargs mentioned in Step 2.
At the LOADER prompt, boot up:
boot_ontap
You can use the following example as a reference:
Expand the console output example
LOADER-A> boot_ontap menu . . <output truncated> . All rights reserved. ******************************* * * * Press Ctrl-C for Boot Menu. * * * ******************************* . <output truncated> . Please choose one of the following: (1) Normal Boot. (2) Boot without /etc/rc. (3) Change password. (4) Clean configuration and initialize all disks. (5) Maintenance mode boot. (6) Update flash from backup config. (7) Install new software first. (8) Reboot node. (9) Configure Advanced Drive Partitioning. (10) Set Onboard Key Manager recovery secrets. (11) Configure node for external key management. Selection (1-11)? 22/7 (22/7) Print this secret List (25/6) Force boot with multiple filesystem disks missing. (25/7) Boot w/ disk labels forced to clean. (29/7) Bypass media errors. (44/4a) Zero disks if needed and create new flexible root volume. (44/7) Assign all disks, Initialize all disks as SPARE, write DDR labels . . <output truncated> . . (wipeconfig) Clean all configuration on boot device (boot_after_controller_replacement) Boot after controller upgrade (boot_after_mcc_transition) Boot after MCC transition (9a) Unpartition all disks and remove their ownership information. (9b) Clean configuration and initialize node with partitioned disks. (9c) Clean configuration and initialize node with whole disks. (9d) Reboot the node. (9e) Return to main boot menu. The boot device has changed. System configuration information could be lost. Use option (6) to restore the system configuration, or option (4) to initialize all disks and setup a new system. Normal Boot is prohibited. Please choose one of the following: (1) Normal Boot. (2) Boot without /etc/rc. (3) Change password. (4) Clean configuration and initialize all disks. (5) Maintenance mode boot. (6) Update flash from backup config. (7) Install new software first. (8) Reboot node. (9) Configure Advanced Drive Partitioning. (10) Set Onboard Key Manager recovery secrets. (11) Configure node for external key management. Selection (1-11)? boot_after_controller_replacement This will replace all flash-based configuration with the last backup to disks. Are you sure you want to continue?: yes . . <output truncated> . . Controller Replacement: Provide name of the node you would like to replace:<nodename of the node being replaced> Controller Replacement: Provide High Availability partner of node1: <nodename of the partner of the node being replaced> Changing sysid of node node1 disks. Fetched sanown old_owner_sysid = 536940063 and calculated old sys id = 536940063 Partner sysid = 4294967295, owner sysid = 536940063 . . <output truncated> . . varfs_backup_restore: restore using /mroot/etc/varfs.tgz varfs_backup_restore: attempting to restore /var/kmip to the boot device varfs_backup_restore: failed to restore /var/kmip to the boot device varfs_backup_restore: attempting to restore env file to the boot device varfs_backup_restore: successfully restored env file to the boot device wrote key file "/tmp/rndc.key" varfs_backup_restore: timeout waiting for login varfs_backup_restore: Rebooting to load the new varfs Terminated <node reboots> System rebooting... . . Restoring env file from boot media... copy_env_file:scenario = head upgrade Successfully restored env file from boot media... Rebooting to load the restored env file... . System rebooting... . . . <output truncated> . . . . WARNING: System ID mismatch. This usually occurs when replacing a boot device or NVRAM cards! Override system ID? {y|n} y . . . . Login:The system IDs shown in the preceding example are example IDs. The actual system IDs of the nodes that you are upgrading will be different.
Between entering node names at the prompt and the login prompt, the node reboots a few times to restore the environment variables, update firmware on the cards in the system, and for other ONTAP updates.
After booting node1 with the replacement system modules, verify the node1 installation.
