Issues that can arise in multiple stages of the procedure
Some issues can occur during different stages of the procedure.
Unexpected "storage failover show" command output
During the procedure, if the node that hosts all data aggregates panics or is rebooted accidentally, you might see unexpected output for the storage failover show command before and after the reboot, panic, or power cycle.
You might see unexpected output from the storage failover show command in Stage 2, Stage 3, Stage 4, or Stage 5.
The following example shows the expected output of the storage failover show command if there are no reboots or panics on the node that hosts all the data aggregates:
cluster::> storage failover show
Takeover
Node Partner Possible State Description
node1 node2 false Unknown
node2 node1 false Node owns partner aggregates as part of the non-disruptive head upgrade procedure. Takeover is not possible: Storage failover is disabled.
The following example shows the output of the storage failover show command after a reboot or panic:
Takeover
node1 node2 - Unknown
node2 node1 false Waiting for node1, Partial giveback, Takeover is not possible: Storage failover is disabled
Although the output says that a node is in partial giveback and that storage failover is disabled, you can disregard this message.
No action is required; continue with the node-pair upgrade procedure.
