Move non-root aggregates and NAS data LIFs back to node2
After verifying the network configuration on node2, you need to relocate the NAS data LIFs owned by node2 from node1 to node2 and confirm that the SAN LIFs exist on node2.
Remote LIFs handle traffic to SAN LUNs during the upgrade procedure. Moving SAN LIFs is not necessary for cluster or service health during the upgrade. SAN LIFs are not moved unless they need to be mapped to new ports.
You verify that the LIFs are healthy and located on the correct ports after you bring node2 online.
Resume the relocation operation:
system controller replace resumeThe system performs the following tasks:
Cluster quorum check
System ID check
Image version check
Target platform check
Network reachability check
The system pauses the operation at this stage in the network reachability check
system controller replace resumeThe system performs the following checks:
Cluster health check
Cluster LIF status check
After performing these checks, the system relocates the non-root aggregates and NAS data LIFs back to node2, which is now running on the replacement controller.
The controller replacement operation pauses after the resource relocation is complete.
Check the status of the aggregate relocation and NAS data LIF move operations:
system controller replace show-detailsIf the controller replacement procedure is paused, check and correct the error, if any, and then issue
resumeto continue the operation. -
If necessary, restore and revert displaced LIFs or manually migrate and modify the node2 LIFs that failed to relocate automatically to node2.
Restore and revert displaced LIFs-
List any displaced LIFs:
cluster controller-replacement network displaced-interface show -
If any LIFs are displaced, restore the home node back to node2:
cluster controller-replacement network displaced-interface restore-home-node -node <node2_nodename> -vserver <vserver name> -lif-name <lif_name>
Manually migrate and modify LIFs-
Migrate the LIFs that failed to relocate automatically to node2:
network interface migrate -vserver <vserver name> -lif <lif_name> -destination-node <node2_nodename> -destination-port <port_on_node2> -
Modify the home node and home port for the migrated LIFs:
network interface modify -vserver <vserver_name> -lif <data_lif_name> -home-node <node2_nodename> -home-port <home_port>
Resume the operation to prompt the system to perform the required post-checks:
system controller replace resumeThe system performs the following post-checks:
Aggregates reconstruction check
Aggregate status check
Disk status check
Volume check
After moving non-root aggregates and NAS data LIFs back to node2, manage authentication using KMIP servers.
