Netboot node2
After swapping the corresponding replacement node2 system modules, you might need to netboot them. The term netboot means that you are booting from an ONTAP image stored on a remote server. When preparing for netboot, you put a copy of the ONTAP 9 boot image onto a web server that the system can access.
It isn't possible to check the version of ONTAP installed on the boot media of the replacement controller module unless it is installed in a chassis and powered ON. The ONTAP version on the replacement system boot media must be the same as the ONTAP version running on the old system that you are upgrading and both the primary and backup boot images must match. You can configure the images by performing a netboot followed by the wipeconfig command from the boot menu. If the controller module was previously used in another cluster, the wipeconfig command clears any residual configuration on the boot media.
You can also use the USB boot option to perform the netboot. See the Knowledge Base article How to use the boot_recovery LOADER command for installing ONTAP for initial setup of a system.
Verify that you can access a HTTP server with the system.
Download the necessary system files for your system and the correct version of ONTAP from the NetApp Support Site. Refer to References to link to the NetApp Support Site.
You must netboot the new controllers if they do not have the same version of ONTAP 9 installed on them that is installed on the original controllers. After you install each new controller, you boot the system from the ONTAP 9 image stored on the web server. You can then download the correct files to the boot media device for subsequent system boots.
Refer to References to link to the NetApp Support Site to download the files used for performing the netboot of the system.
Download the appropriate ONTAP software from the software download section of the NetApp Support Site and store the
<ontap_version>_image.tgzfile on a web-accessible directory. -
Change to the web-accessible directory and verify that the files you need are available.
Your directory listing should contain
<ontap_version>_image.tgz. -
Configure the netboot connection by choosing one of the following actions.
You must use the management port and IP as the netboot connection. Do not use a data LIF IP or a data outage might occur while the upgrade is being performed. If Dynamic Host Configuration Protocol (DHCP) is… Then… Running
Configure the connection automatically by using the following command at the boot environment prompt:
ifconfig e0M -autoNot running
Manually configure the connection by using the following command at the boot environment prompt:
ifconfig e0M -addr=filer_addr -mask=netmask -gw=gateway -dns=dns_addr -domain=dns_domainfiler_addris the IP address of the storage system (mandatory).
netmaskis the network mask of the storage system (mandatory).
gatewayis the gateway for the storage system (mandatory).
dns_addris the IP address of a name server on your network (optional).
dns_domainis the Domain Name Service (DNS) domain name (optional).Other parameters might be necessary for your interface. Enter help ifconfigat the firmware prompt for details. -
Perform netboot on node2:
netboot http://<web_server_ip/path_to_web_accessible_directory>/netboot/kernelDo not interrupt the boot. -
Wait for the node2 now running on the replacement controller module to boot and display the boot menu options as shown in the following output:
Please choose one of the following: (1) Normal Boot. (2) Boot without /etc/rc. (3) Change password. (4) Clean configuration and initialize all disks. (5) Maintenance mode boot. (6) Update flash from backup config. (7) Install new software first. (8) Reboot node. (9) Configure Advanced Drive Partitioning. (10) Set Onboard Key Manager recovery secrets. (11) Configure node for external key management. Selection (1-11)?
From the boot menu, select option
(7) Install new software first.This menu option downloads and installs the new ONTAP image to the boot device.
Disregard the following message:
This procedure is not supported for Non-Disruptive Upgrade on an HA pairThis note applies to nondisruptive ONTAP software upgrades, and not controller upgrades.
Always use netboot to update the new node to the desired image. If you use another method to install the image on the new controller, the incorrect image might install. This issue applies to all ONTAP releases. The netboot procedure combined with option (7) Install new softwarewipes the boot media and places the same ONTAP version on both image partitions. -
If you are prompted to continue the procedure, enter
y, and when prompted for the package, enter the URL:
http://<web_server_ip/path_to_web-accessible_directory>/<ontap_version>_image.tgzThe
<path_to_the_web-accessible_directory>should lead to where you downloaded the<ontap_version>_image.tgzin Step 2. -
Complete the following substeps to reboot the controller module:
Enter
nto skip the backup recovery when you see the following prompt:Do you want to restore the backup configuration now? {y|n} -
Enter
yto reboot when you see the following prompt:The node must be rebooted to start using the newly installed software. Do you want to reboot now? {y|n}The controller module reboots but stops at the boot menu because the boot device was reformatted, and the configuration data must be restored.
Clear any previous configuration on the boot media.
At the following prompt, run the
wipeconfigcommand. Then select Enter:Please choose one of the following: (1) Normal Boot. (2) Boot without /etc/rc. (3) Change password. (4) Clean configuration and initialize all disks. (5) Maintenance mode boot. (6) Update flash from backup config. (7) Install new software first. (8) Reboot node. (9) Configure Advanced Drive Partitioning. (10) Set Onboard Key Manager recovery secrets. (11) Configure node for external key management. Selection (1-11)? wipeconfig
When you see the message below, answer
yes:This will delete critical system configuration, including cluster membership. Warning: do not run this option on a HA node that has been taken over. Are you sure you want to continue?:
The node reboots to finish the
wipeconfigand then stops at the boot menu.Wait until the node stops at the boot menu after completing the wipeconfigoperation.
Select maintenance mode
5from the boot menu and enterywhen you are prompted to continue with the boot. -
Verify that the controller and chassis are configured as
ha:ha-config showThe following example shows the output of the
ha-config showcommand:Chassis HA configuration: ha Controller HA configuration: ha
If the controller and chassis are not configured as
ha, use the following commands to correct the configuration:ha-config modify controller haha-config modify chassis ha -
Halt node2:
haltNode2 should stop at the LOADER> prompt.
On node1, check the system date, time, and time zone:
date -
On node2, check the date by using the following command at the boot environment prompt:
show date -
If necessary, set the date on node2:
set date mm/dd/yyyySet the corresponding UTC date on node2. -
On node2, check the time by using the following command at the boot environment prompt:
show time -
If necessary, set the time on node2:
set time hh:mm:ssSet the corresponding UTC time on node2. -
Set the partner system ID on node2:
setenv partner-sysid node1_sysidFor node2, the
partner-sysidmust be that of the node1 that you are upgrading.-
Save the settings:
saveenv
On node2, at the LOADER prompt, verify the
partner-sysidfor node2:printenv partner-sysid
After netbooting node2, cable node2 for shared cluster-HA and storage.
