Relocate non-root aggregates and NAS data LIFs owned by node1 to node2
Contributors netapp-pcarriga
Before you can replace node1 with the replacement modules for your system upgrade, you must move the non-root aggregates and NAS data LIFs from node1 to node2 before eventually restoring the node1 resources back on node1 running on the replacement system. This process is largely automated; the operation pauses to enable you to check its status.
Before you begin
The operation should already be paused when you begin the task; you must manually resume the operation.
About this task
Remote LIFs handle traffic to SAN LUNs during the upgrade procedure. You are not required to move SAN LIFs for cluster or service health during the upgrade. You must verify that the LIFs are healthy and located on appropriate ports after you bring node1 online as the replacement system.
Note The home owner for the aggregates and LIFs is not modified; only the current owner is modified.
Steps
  1. Resume the aggregate relocation and NAS data LIF move operations:
    system controller replace resume
    All the non-root aggregates and NAS data LIFs are migrated from node1 to node2.
    The operation pauses to enable you to verify whether all node1 non-root aggregates and non-SAN data LIFs have been migrated to node2.
  2. Check the status of the aggregate relocation and NAS data LIF move operations:
    system controller replace show-details
  3. With the operation still paused, verify that all the non-root aggregates are online for their state on node2:
    storage aggregate show -node <node2> -state online -root false
    The following example shows that the non-root aggregates on node2 are online:
    cluster::> storage aggregate show -node node2 -state online -root false
    Aggregate  Size     Available  Used%  State  #Vols  Nodes  RAID Status
    aggr_1     744.9GB  744.8GB    0%     online     5  node2  raid_dp,normal
    aggr_2     825.0GB  825.0GB    0%     online     1  node2  raid_dp,normal
    2 entries were displayed.
    If the aggregates have gone offline or become foreign on node2, bring them online by using the following command on node2, once for each aggregate:
    storage aggregate online -aggregate <aggregate_name>
  4. Verify that all the volumes are online on node2 by using the following command on node2 and examining its output:
    volume show -node <node2> -state offline
    If any volumes are offline on node2, bring them online by using the following command on node2, once for each volume:
    volume online -vserver <vserver_name> -volume <volume_name>
    The vserver_name to use with this command is found in the output of the previous volume show command.
  1. If any LIFs are down, set the administrative status of the LIFs to up by using the following command, once for each LIF:
    network interface modify -vserver vserver_name -lif LIF_name -home-node nodename -status-admin up
What's next?
After relocating non-root aggregates and NAS data LIFs owned by node1 to node2, relocate failed or vetoed aggregates to node2.
