Relocate non-root aggregates and NAS data LIFs from node2 to node1
Contributors netapp-pcarriga
Before you can replace node2 with the replacement system module, you must first relocate the non-root aggregates that are owned by node2 to node1.
Before you begin
After the post-checks from the previous stage complete, the resource release for node2 starts automatically. The non-root aggregates and non-SAN data LIFs are migrated from node2 to the new node1.
About this task
After the aggregates and LIFs are migrated, the operation is paused for verification purposes. At this stage, you must verify that all the non-root aggregates and non-SAN data LIFs are migrated to the new node1.
The home owner for the aggregates and LIFs are not modified; only the current owner is modified.
Steps
  1. Verify that all the non-root aggregates are online and their state on node1:
    storage aggregate show -node node1 -state online -root false
    The following example shows that the non-root aggregates on node1 are online:
    cluster::> storage aggregate show -node node1 -state online -root false
    Aggregate     Size        Available   Used%   State	  #Vols	 Nodes	 RAID	  Status
    aggr_1	      744.9GB     744.8GB	  0%	  online	  5	 node1   raid_dp  normal
    aggr_2	      825.0GB	  825.0GB	  0%	  online	  1	 node1   raid_dp  normal
    2 entries were displayed.
    If the aggregates have gone offline or become foreign on node1, bring them online by using the following command on the new node1, once for each aggregate:
    storage aggregate online -aggregate aggr_name
  2. Verify that all the volumes are online on node1 by using the following command on node1 and examining its output:
    volume show -node node1 -state offline
    If any volumes are offline on node1, bring them online by using the following command on node1, once for each volume:
    volume online -vserver vserver-name -volume volume-name
    The vserver-name to use with this command is found in the output of the previous volume show command.
  3. Verify that the LIFs have been moved to the correct ports and have a status of up. If any LIFs are down, set the administrative status of the LIFs to up by entering the following command, once for each LIF:
    network interface modify -vserver vserver_name -lif LIF_name -home-node nodename - status-admin up
  4. Verify that there are no data LIFs remaining on node2 by using the following command and examining the output:
    network interface show -curr-node node2 -role data
What's next?
After relocating non-root aggregates and NAS data LIFs from node2 to node1, relocate failed or vetoed aggregates to node1.
