Set up NetApp Volume or Aggregate Encryption on the new controller module
Contributors netapp-pcarriga
If the replaced controller or high availability (HA) partner of the new controller uses NetApp Volume Encryption (NVE) or NetApp Aggregate Encryption (NAE), you must configure the new controller module for NVE or NAE.
About this task
This procedure includes steps that are performed on the new controller module. You must enter the command on the correct node.
Onboard Key Manager
Configure NVE or NAE using the Onboard Key Manager.
Steps
  1. Restore authentication keys from all linked key management servers to the new node:
    security key-manager onboard sync
External Key Management
Configure NVE or NAE using External Key Management.
Steps
  1. Verify that the key management servers are still available, their status, and their authentication key information:
    security key-manager key query -node node
  2. Add the key management servers listed in the previous step to the key management server list in the new controller:
    1. Add the key management server:
      security key-manager external add-servers -key-servers key_management_server_ip_address
    2. Repeat the previous step for each listed key management server. You can link up to four key management servers.
    3. Verify the that the key management servers were added successfully:
      security key-manager external show
  3. On the new controller module, run the key management setup wizard to set up and install the key management servers.
    You must install the same key management servers that are installed on the existing controller module.
    1. Launch the key management server setup wizard on the new node:
      security key-manager external enable
    2. Complete the steps in the wizard to configure key management servers.
  4. Restore authentication keys from all linked key management servers to the new node:
    security key-manager external restore
    This command needs the OKM passphrase
    For more information, see the Knowledge Base article How to restore external key manager server configuration from the ONTAP boot menu.
After you finish
Check if any volumes were taken offline because authentication keys were not available or EKM servers could not be reached. Bring those volumes back online by using the volume online command.
What's next?
After setting up NetApp Volume or Aggregate Encryption on the new controller module, decommission the old system.
