Verify the upgrade hardware
Before starting the upgrade, verify that you have the correct modules for your replacement system. If there are parts missing, contact technical support or your NetApp sales representative for assistance.
| If you're upgrading from … | Replacement system must have … |
AFF A250, AFF C250 |
AFF A800, AFF C800 |
Two controller modules, two NVRAMs, and new IO modules |
Two controller modules If you're converting the existing system to a storage shelf so you can attach it to another system, the replacement system must also have two IO modules. |
Two controller and two NVRAM modules |
After verifying the upgrade hardware, prepare the nodes for upgrade.
