Move non-root aggregates and NAS data LIFs back to node2
Contributors netapp-pcarriga
After you verify network configuration on node2 and before you relocate aggregates from node1 to node2, you must verify that the NAS data LIFs belonging to node2 that are currently on node1 are relocated from node1 to node2. You must also verify that the SAN LIFs exist on node2.
About this task
Remote LIFs handle traffic to SAN LUNs during the upgrade procedure. Moving SAN LIFs is not necessary for cluster or service health during the upgrade. SAN LIFs are not moved unless they need to be mapped to new ports. After you bring node2 online, you must verify that the LIFs are healthy and located on the appropriate ports.
Steps
  1. Resume the relocation operation:
    system controller replace resume
    The system performs the following tasks:
    • Cluster quorum check
    • System ID check
    • Image version check
    • Target platform check
    • Network reachability check
    The operation pauses at this stage in the network reachability check.
  2. Resume the relocation operation:
    The system performs the following checks:
    • Cluster health check
    • Cluster LIF status check
    After performing these checks, the system relocates the non-root aggregates and NAS data LIFs back to node2 which is now running on the AFF A900 controller.
    The controller replacement operation pauses after the resource relocation is complete.
  3. Check the status of the aggregate relocation and NAS data LIF move operations:
    system controller replace show-details
    If the controller replacement procedure is paused, check and correct the error, if any, and then issue resume to continue the operation.
  4. If necessary, restore and revert any displaced LIFs. List any displaced LIFs:
    cluster controller-replacement network displaced-interface show
    If any LIFs are displaced, restore the home node back to node2:
    cluster controller-replacement network displaced-interface restore-home-node
  5. Resume the operation to prompt the system to perform the required post-checks:
    The system performs the following post-checks:
    • Aggregates reconstruction check
    • Aggregate status check
    • Disk status check
    • Volume check
