Move non-root aggregates and NAS data LIFs owned by node1 from node2 to the upgraded node1
Contributors netapp-pcarriga
After you verify network configuration on node1 and before you relocate aggregates from node2 to node1, you must verify that the NAS data LIFs belonging to node1 that are currently on node2 are relocated from node2 to node1. You must also verify that the SAN LIFs exist on node1.
About this task
Remote LIFs handle traffic to SAN LUNs during the upgrade procedure. Moving SAN LIFs is not necessary for cluster or service health during the upgrade. SAN LIFs are not moved unless they need to be mapped to new ports. After you bring node1 online, you must verify that the LIFs are healthy and located on the appropriate ports.
Steps
  1. Resume the relocation operation:
    system controller replace resume
    The system performs the following tasks:
    • Cluster quorum check
    • System ID check
    • Image version check
    • Target platform check
    • Network reachability check
    The operation pauses at this stage in the network reachability check.
  2. Perform a network reachability check:
    network port reachability -show-detail -node node1
    Confirm that all connected ports, including the interface group and VLAN ports, show their status as OK.
  3. Resume the relocation operation:
    The system performs the following checks:
    • Cluster health check
    • Cluster LIF status check
    After performing these checks, the system relocates the non-root aggregates and NAS data LIFs owned by node1 to the new node1.
    The controller replacement operation pauses after the resource relocation is complete.
  4. Check the status of the aggregate relocation and NAS data LIF move operations:
    system controller replace show-details
    If the controller replacement procedure is paused, check and correct the error, if any, and then issue resume to continue the operation.
  5. If necessary, restore and revert any displaced LIFs. List any displaced LIFs:
    cluster controller-replacement network displaced-interface show
    If any LIFs are displaced, restore the home node back to node1:
    cluster controller-replacement network displaced-interface restore-home-node
  6. Resume the operation to prompt the system to perform the required post-checks:
    The system performs the following post-checks:
    • Aggregates reconstruction check
    • Aggregate status check
    • Disk status check
    • Volume check
