Required tools and documentation
PDF of this doc site
Upgrade by using ARL
Use "system controller replace" commands to upgrade controller models in the same chassis
Creating your file...
Your file is ready
You must have specific tools to install the new hardware, and you need to reference other documents during the upgrade process.
You need the following tools to perform the upgrade:
Grounding strap
#2 Phillips screwdriver
Go to the References section to access the list of reference documents and reference sites required for this upgrade
