Worksheet: Information to record before moving NAS data LIFs to node3
To help verify that you have the correct configuration after moving SAN LIFs from node2 to node3, you can use the following worksheet to record the adapter
and switch-port
information for each LIF.
Record the LIF adapter
information from the network interface show -data-protocol fc*
command output and the switch-port
information from the fcp adapter show -fields switch-port,fc-wwpn
command output for node2.
After you complete the migration to node3, record the LIF adapter
and switch-port
information for the LIFs on node3 and verify that each LIF is still connected to the same switch-port
Node2 | Node3 | ||||
LIF |
LIF |
