Worksheet: Information to record before moving NAS data LIFs to node4
To help verify that you have the correct configuration after moving SAN LIFs from node3 to node4, you can use the following worksheet to record the adapter and switch-port information for each LIF.
Record the LIF adapter information from the network interface show -data-protocol fc* command output and the switch-port information from the fcp adapter show -fields switch-port,fc-wwpn command output for node3.
After you complete the migration to node4, record the LIF adapter and switch-port information for the LIFs on node4 and verify that each LIF is still connected to the same switch-port.
| Node3 | Node4 | ||||
LIF |
LIF |
