Reassign drives from node1 to node3
Contributors netapp-pcarriga
Reassign the drives that were previously assigned to AFF A150, AFF A220, or FAS2820 node1 to node3.
Steps
Perform these steps on node3.
  1. At the LOADER prompt, boot node3 into Maintenance Mode:
    boot_ontap maint
    The Maintenance Mode prompt appears.
  2. Display all attached drives:
    disk show -v
  3. Record the local system ID value; this is the system ID of node3. Also record the system IDs of node1 and node4 from the "OWNER" column.
  4. Reassign all drives from node1 to node3:
    If you're using whole disks
    Run the following command:
    disk reassign -s <node1_system_ID> -d <node3_system_ID>
    If you're using partitioned disks
    disk reassign -s <node1_system_ID> -d <node3_system_ID> -p <node4_system_ID>
  5. Verify that all reassigned drives are viewable to the new system ID:
    disk show -s <node3_system_ID>
    Caution If drives are not viewable, stop and contact technical support for assistance.
  6. Exit Maintenance Mode:
    halt
