Remove the original nodes from the cluster
After moving the volumes from the original to the new nodes and moving or deleting data LIFs, you remove the original nodes from the cluster. When you remove a node, the node's configuration is erased and all disks are initialized.
Change the privilege level to advanced:
set -privilege advanced -
Identify the node in the cluster that has epsilon:
cluster showIn the following example, "node0" currently holds epsilon:
cluster::*> Node Health Eligibility Epsilon -------------------- ------- ------------ ------------ node0 true true true node1 true true false node2 true true false node3 true true false
If the node that you are removing holds epsilon:
Move epsilon from the node you are removing:
cluster modify -node <name_of_node_to_be_removed> -epsilon false -
Move epsilon to a node that you are not removing:
cluster modify -node <node_name> -epsilon true
Identify the current primary node:
cluster ring showThe primary node is the node that holds processes such as
mgmt,vldb,vifmgr,bcomd, andcrs. -
If the node you are removing is the current primary node, enable another node in the cluster to be elected as the primary node:
Make the current primary node ineligible to participate in the cluster:
cluster modify -node <node_name> -eligibility falseThe node is marked unhealthy until eligibility is restored. When the primary node becomes ineligible, one of the remaining nodes is elected by the cluster quorum as the new primary.
If you are performing this step on the first node in an HA pair, you should mark only that node as ineligible. Do not modify the status of the HA partner.
If the partner node is selected as the new primary, you need to verify if it holds epsilon before making it ineligible. If the partner node holds epsilon, you need to move epsilon to a different node that is remaining in the cluster before making it ineligible. You do this when you repeat these steps to remove the partner node.
Make the previous primary node eligible to participate in the cluster again:
cluster modify -node <node_name> -eligibility true
Log into the remote node management LIF or the cluster-management LIF on a node that you are not removing from the cluster.
Remove the nodes from the cluster:
For this ONTAP version… Use this command… ONTAP 9.3
cluster unjoinONTAP 9.4 and later
With node name:
cluster remove-node -node <node_name>With node IP:
cluster remove-node -cluster_ip <node_ip>If you have a mixed version cluster and you are removing the last lower version node, use the
-skip-last-low-version-node-checkparameter with these commands.The system informs you of the following:
You must also remove the node's failover partner from the cluster.
After the node is removed and before it can rejoin a cluster, you must use boot menu option (4) Clean configuration and initialize all disks or option (9) Configure Advanced Drive Partitioning to erase the node's configuration and initialize all disks.
A failure message is generated if you have conditions that you must address before removing the node. For example, the message might indicate that the node has shared resources that you must remove or that the node is in a cluster HA configuration or storage failover configuration that you must disable.
If the node is the quorum primary, the cluster will briefly lose and then return to quorum. This quorum loss is temporary and does not affect any data operations.
If a failure message indicates error conditions, address those conditions and rerun the
cluster remove-nodeorcluster unjoincommand.The node automatically reboots after it is successfully removed from the cluster.
If you are repurposing the node, erase the node configuration and initialize all disks:
During the boot process, press Ctrl-C to display the boot menu when prompted to do so.
Select the boot menu option (4) Clean configuration and initialize all disks.
Return to admin privilege level:
set -privilege admin
After removing the original nodes, complete the move volumes upgrade.
